G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hi, i've bought myself a new motherboard, and pc case, built a new pc, and
put my 2 hard drives from the old pc in (just put 1 in whilst i re-installed
xp).
When i put the second hard drive in, it shows 0 bytes used, 0 bytes
available, yet this drive was full of data when removed from the old pc. the
option i get is - the drive is not formatted - do you want to format the
drive
i've tried using Restorer2000 Professional and this app see's all the data,
but when i try to recover to my other hard drive, it doesnt recover full
files, and i get error code 801
this is what customer services at bitmart said :-
Dear Customer,
"Can't read file to be recovered completely (801)" means that the file
being recovered extends beyond the partition it resides on. That means
either severe data loss or that you use wrong Recognized partition to
recover the file. Please explore all such partitions.
The success of recovery depends on many factors and there is no way to
determine in advance whether a file can be recovered to its original
form other than to retrieve it and try to open with appropriate
application. Presence of file name (even proper sized) in the listing
does not imply 100 success of recovery.
If the file system has been damaged the possibility of recovery is
greatly affected by what parts of the drive and file system were
involved in the damage. In case if only the file's data has been
corrupted then there will not be problems with the whole system.
Therefore if there is a problem with the file system it means that
some important auxiliary data were damaged. Thus it is almost
inevitable that some data, or in other words files, cannot be
restored, these files are lost forever. However, there are always
chances that some data still can be recovered.
Best regards,
Support Team
BitMart Inc.
support@bitmart.net
The drive only has i partition
xp).
drive
Dear Customer,
Best regards,
Support Team
BitMart Inc.
support@bitmart.net
