G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage,alt.comp.hardware (More info?)
Looking for some hints on possible ways to recover data from a HD that
has been damaged by a faulty power supply that blew on me (PSU produced
a spark then died).
The disk in question is a Seagate Barracuda SATA V (80gb), firmware
3.01. It was connected to a Q-TEC noise quiet power supply (via a
converter that makes a normal ATX power lead into SATA drive power
connection). I powered on the machine, the power supply blew, I swapped
in another power supply to find that my machine would not power on - the
PSU fan wouldn´t even budge - if the SATA drive was attached to the PSU.
If I disconnect the SATA drive from the PSU, bingo, my machine starts up
and the other hard disk (IDE), still connected, is found.
So, the question is, given that the circuitry on the SATA drive is
probably blown, is there a way to recover my data? Say, by buying
another drive of the same type and transplanting the circuit board or
controller etc? I´ve heard of such things working before... and AFAICT
the platters/disk surface are unharmed so the data is still there.
I'm techy and not afraid to get my hands dirty, but what is possible?
I´t would be great to recover the data, but not worth 600UKP or whatever
it would cost for professional recovery service!
thanks
alex
a spark then died).
thanks
alex
