USB Imaging Problems! HELP!
Last response: in Applications
May 9, 2001 5:38:25 PM
Everytime I try and use a USB imaging device (scanner or digital camera), I get the blue screen of death. I've tracked it down to the windows program "stimon.exe". It causes the errors right away when windows boots. Here's my setup...
AMD - 1.1ghz,
Asus A7V
256 MB,
GeForce 2 Ultra,
Sound Blaster Live value II
Anyone know how I can fix this problem????
All things must surely have to end...
Functor
More about : usb imaging problems
May 10, 2001 4:04:20 PM
Heya Guy. The STIMON.exe is from HP goto their site and look up your scanner under support. Theres probably something in there under the Frequently Asked Questions about it. I know when I was tech support some Items had problems working on the same USB. So you had to disable in startup one of those programs. I can't remember quite which one. Hope this help ya.
Dantin
