Archived from groups: alt.comp.periphs.dcameras (More info?)
Have had this camera a long time but all of a sudden, it started giving me
the "battery empty" message right after I install 4 new batteries. It's not
the batteries -- I have tried 4 different NEW packs and same result with
each one. Nothing special happened the day it started -- I had taken about
100 photos with no problem, then when the batteries ran out, I put in 4 new
ones and got 2 photos before "battery empty" message came up. Same ever
since.
Wonder if anyone had this problem come up on this or a similar model?
Thanks!!
Fred
Did you just switch to NiCad or NiMh?
"Fred" <testing@testing1212mouse.com> wrote in message
news:cNfGc.20473$6e7.13506@nwrddc03.gnilink.net...
not
about
new
> since.
> Thanks!!
> Fred
No, same batteries as always - alkaline. Same brand and everything...
"Gymmy Bob" <nospamming@bite.me> wrote in message
news:j5udnWCMHIrsfHTd4p2dnA@golden.net...
me
> not
> about
> new
> > since.
> > Thanks!!
> > Fred
Try cleaning all the contacts on the batteries and the camera metal contacts
with contact cleaner. Short (pun not intended) of that use a cotton swab
with medical alcohol (isopropyl with the most pure content you can find).
After that?????
news:lXMHc.44409$qw1.25740@nwrddc01.gnilink.net...
giving
> me
It's
> > not
with
> > about
4
> > new
ever
> > > since.
> > > Thanks!!
> > > Fred
Archived from groups: alt.comp.periphs.dcameras,aus.photo,rec.photo.digital,rec.photo.equipment.35mm,de.alt.rec.digitalfotografie (More info?)
"J?rg Preddimann" <preddimann@skinheads.zzn.com> wrote in message
news:b9b4c103.0407102345.3c88dbf7@posting.google.com...
news:<cNfGc.20473$6e7.13506@nwrddc03.gnilink.net>...
me
not
about
new
> > since.
> I've heard numerous accounts of the same exact thing from other
> Olympus, Canon, Minolta, Nikon, and Sony digital camera owners. Switch
> to the Sigma SD10. This camera gives you the best battery life of any
> camera with zero reports of errors to my knowledge. In addition, you
> can not beat the image quality of the Foveon sensor.
> Jörg Preddimann
There are two possibilities. Either it works with the bad battery
indication, or it doesn't. If it works with it, then there are two
possibilities. Either you elect to live with the problem, or you decide to
get it fixed. Your choice.
I have found that (considering how much of a rush people are in) nimh
batteries (I assume that's what you are using) don't do as well when
fast-charged. I get much longer life between charges when I use a slow
charger.
_________________________________
John
Thanks, GB. I took your advice and cleaned the contacts good. Springs are
OK, too. Top contact piece also makes good contact. Still same problem.
Looks like it's time to check out the cost of Olympus service.
Appreciate all the comments.
news:k7Odndt83tUm-23dRVn-gw@golden.net...
contacts
> After that?????
> giving
> > me
> It's
> > > not
> with
taken
> > > about
in
> 4
> > > new
> ever
> > > > since.
model?
> > > > Thanks!!
> > > > Fred
Archived from groups: alt.comp.periphs.dcameras,aus.photo,rec.photo.digital,rec.photo.equipment.35mm (More info?)
http://www.olympusamerica.com/cpg_ [...] C%2DSeries
FYI, there are several good and comprehensive manuals for this Camera here.
I would sure appreciate hearing from someone who had this problem and FIXED
it. A quick check of google and ebay and I see that this is a common
problem with this model.
NOTE: It is not a battery problem or bad contacts. I have already
isolated the problem to the camera itself.
I have a C-700 which is about 18 months old. My problem isn't
ordinary battery drain, rather what I suspect to be some kind of short
circuit. Newly inserted batteries, alkaline or (brand new, fully
charged NiMH) re-chargeables only work for a picture or two. I can
open the compartment door, rub the contacts a bit, and get maybe one
more picture, maybe not.
I posted this query about a month ago, and got a suggestion clean the
contacts, check the springs, etc. I have done this and the contact points
are all good & clean. No change in performance.
Already checked the obvious -- tried several new batteries and all act the
same, batteries are not in backwards, etc. The problem is with the camera,
I know that for sure.
Thanks in advance!
Fred
Anyone know how to get a service manual or schematic on this? (Please...
don't say call Olympus, etc... I'll like to find a 3rd party.)
Problem is isolated to a short, but that's as far as I can get without a
schematic.
I just contacted Olympus about this and the best they can do is "fix
anything wrong with the camera for $155." Good deal if you ran over it with
your Mack truck, but not much of a deal if it just takes a minor service or
parts replacement. Thanks for the lead on the camera shop -- but they said
they would just send it in to Olympus for an estimate ($155).
Thanks in advance!
Fred
> schematic.
Hi...
I can't tell where you are; but I *think* verizon is the
southern USA.
If you'll send me an email I'll send you back the name of
a fellow in california usa who does good and inexpensive
work. And is an Olympus repair depot.
Ken
news:KuxMc.1787$qT3.1205@nwrddc03.gnilink.net...
> schematic.
with
or
FIXED
points
the
camera,
> Thanks in advance!
> Fred
Have you changed memory cards? Some Fuji have battery drain over night due
to a cap on the CF card.
> (Please... don't say call Olympus, etc... I'll like to find a 3rd
> party.)
Are you sure you really wanted to post this to rec.photo.equipment.35mm?
Joseph E. Meehan
26 + 6 = 1 It's Irish Math
> schematic.
with
or
FIXED
points
the
camera,
> Thanks in advance!
> Fred
I have also heard this short from the power supply is a problem. I also herd
the clamshell design (mju in Aus) had the door taken from the film version
of the camera. The door saw use every 15 or so rolls, now it does for
everytime you download images or recharge your batttery.
While the design was excellent for film cameras... apparently it does not
put up with the wear and tear required from the digi version.
Just what I heard..... from a tech.
kosh
"Jack-of-the-Dust" <WillieWhizBang@cod.org> wrote in message
news:UyAMc.131891$OB3.63755@bgtnsc05-news.ops.worldnet.att.net...
No, I haven't. Only used the same one. I'm wondering though if that would
help. The batteries are OK -- they don't drain. The camera just doesn't
see that they are fully charged, and the problem occurs right away, when new
batteries are first installed.
Thanks, will check it out.
Fred
"kosh" <spam@bigpond.net.au> wrote in message
news:gnHMc.15290$K53.2439@news-server.bigpond.net.au...
(Please...
> > schematic.
> with
> or
> FIXED
> points
> the
> camera,
> > Thanks in advance!
> > Fred
herd
> kosh
That's right. Another case study! The C50 is a little beauty. But the
metal pins of the sliding cover ride in a plastic track. After average to
heavy use, the pins cut through the track, the door jams or falls off.
John Hermanson
Camtech Photo Services, Inc.
21 South Lane,
Huntington, NY, 11743-4714,
631-424-2121, www.zuiko.com
(Please...
> > schematic.
> with
> or
> FIXED
> points
> the
> camera,
> > Thanks in advance!
> > Fred
herd
> kosh
Digital service is a common problem as most if not all Japanese camera
manufacturers decided (in unison?) that they would simply refuse to sell
digital camera service manuals to independent repair shops or end users.
John Hermanson
21 South Lane,
> schematic.
with
or
FIXED
points
the
camera,
> Thanks in advance!
> Fred
Thanks for the contact, Ken. He replied but doesn't work on Olympus C-700
or know any referrals or documentation. Very good contact for future
though. Thanks again!!
"Ken Weitzel" <kweitzel@shaw.ca> wrote in message
news:cHyMc.108352$ek5.86614@pd7tw2no...
(Please...
> > schematic.
with
or
> Hi...
> southern USA.
> Ken
On Sunday, July 25, 2004 at 08:53:24 Sunday, 25 July 2004 (where I live), "Joseph Meehan" wrote:
Or aus.photo. "aus" being "Australia", which is a long way from where you
are!
Anyone who is popular is bound to be disliked.
Archived from groups: alt.comp.periphs.dcameras,aus.photo,rec.photo.digital (More info?)
news:r7IMc.3738$Nu4.2990@nwrddc01.gnilink.net...
due
would
new
I just tried a 2nd memory card and no change in camera - eliminated that
possibility. Thanks for the idea. I did talk to a half dozen repair shops
last week and no one in the greater Los Angeles works on the Olympus C700.
They all send it to Olympus for a "quote". With minimum charges, etc., the
bare minimum to get it fixed would be $130 and dealing thru a 3rd party.
I'll just go direct to Olympus and bite the bullet.
Archived from groups: alt.comp.periphs.dcameras,aus.photo,rec.photo.digital,rec.photo.equipment.35mm,sci.electronics.repair (More info?)
since.
Thanks!!
Fred
Fred wrote:
I have a 730 and have never had that problem, though I have another Olympus,
the c-350 which always says battery is empty, but it goes on shooting
normally.
> not the batteries -- I have tried 4 different NEW packs and same result
> with
> about 100 photos with no problem, then when the batteries ran out, I put
> in 4 new ones and got 2 photos before "battery empty" message came up.
> Same ever since.
> Thanks!!
> Fred
al-Farrob
"16 photographs by al-Farrob"
http://www.al-farrob.com
> giving me the "battery empty" message right after I install 4 new
> batteries.
On the off chance you are not using "Heavy Duty" batteries instead of
Alkalines are you?
Have seen this on many brands/models with "Heavy Duty" batts.
Regards, Ken
No, I'm always using alkaline. Thx though.
"Ken Chandler" <news(at)kenchandler_com> wrote in message
news:412077e3$0$8211$afc38c87@news.optusnet.com.au...
> > batteries.
> Alkalines are you?
> Regards, Ken
Hmmm... sounds like there may be a common problem here. Thx.
"al-Farrob" <al001NOSPAM@al-farrob.com> wrote in message
news:2oa8qqF8e6c5U1@uni-berlin.de...
Olympus,
> normally.
me
> > with
> > Same ever since.
> > Thanks!!
> > Fred
> al-Farrob
try using some NiMH rechargable batteries, if problem persists see
manufacturer
news:qQeUc.9656$Kf4.7562@nwrddc02.gnilink.net...
> > > batteries.
> > Alkalines are you?
> > Regards, Ken
news:eURTc.13487$SC1.8077@nwrddc03.gnilink.net...
not
about
new
> since.
> Thanks!!
> Fred
assuming they are rechargeables, this is a common sypton when there is short
in the camera.
take it to a tech, they will be able to tell you for sure.
kosh
news:26DWc.4966$D7.217@news-server.bigpond.net.au...
> short
> in the camera.
This thread started out in the electronics repair newsgroup. He knows
Olympus can fix it, for a price about equal to a new camera. He's wondering
how an ordinary mortal, skilled in electronics, can fix it.
the answer is NO.
"Michael A. Covington" <look@ai.uga.edu.for.address> wrote in message
news:412b4507$1@mustang.speedfactory.net...
> > short
> > in the camera.
wondering
Olympus will not sell repair parts for digital cameras to non-authorized
service shops.
"Sofie" <sofie@olypen.com> wrote in message
news:10in0pabfeh6d0c@corp.supernews.com...
> the answer is NO.
> > > short
> > > in the camera.
> wondering
> service shops.
Hi...
With all due respect Darrell; yes they will. Or they
will to me anyways.
That's assuming you're prepared and willing to pay
absolutely unbelievable prices for them.
Ken
I'm still looking for a way to repair my Olympus C-700 digital camera
without having to send it to Olympus with a check for $150. (Power
problem -- NOT battery related.)
So I'm keeping the posting going - hoping the right person will eventually
stumble into it.
Over the past few days, I have called 20+ shops in the LA area and none work
on Olympus digital cameras.
Fred
Ken is right. I had to buy replacement battery doors for s 340L. Seems like
they were $5 or so each and got them right away. The hinge posts on this
door are weak and easy to break off. I bought a couple of doors.
news:gXLWc.198326$M95.2897@pd7tw1no...
> > service shops.
> Hi...
> will to me anyways.
> Ken
IT'S NOT THE BATTERIES OR THE BATTERY CONNECTIONS.
since.
Thanks!!
Fred
>since.
>Thanks!!
>Fred
In my experience, they're very sensitive to battery voltage. Even one
soft cell among "new" batteries will trigger that message. I've even
seen it happen with lithium cells. Suggest you switch out cells, and
see if you can identify the bad one.
IT'S NOT THE BATTERIES!!! IT'S NOT THE BATTERIES!!!
Any other suggestions would be appreciated.
"RWM" <RWM@RWMann.com> wrote in message news:419742D5.1010905@RWMann.com...
me
new
> >since.
> >Thanks!!
> >Fred
One other thing...
the batteries and battery contacts have ALREADY BEEN THOROUGHLY CHECKED
OUT!! So we can pretty much discount the "PROBLEM WITH THE BATTERIES" line
of troubleshooting.
Thanks just the same.
B^)
news:LXKld.4359$GV5.3522@trnddc04...
> me
> new
> > >since.
> > >Thanks!!
> > >Fred
How about a faulty camera then?
LOL! I know I'm probably asking the same thing over and over, but I have
gotten much good info by posting. Although I'd still like to find some kind
of service documentation, schematics, etc., that choice is probably not
going to happen. But that doesn't stop me from trying. If I can actually
troubleshoot to the component, there are boxes full of C700's and others in
that same series out there that could be fixed and save the user $150. I
plan to create a site and post the how-to-fix-it info I get -- if I ever get
anything usable.
Nothing irks me more than these big companies selling expensive items and
then not making service documentation available to the purchaser. Smacks of
monopoly to me.
And, no, I'm not running for office. B^)
Fred
"Harvey" <harvey@not.ntlworld.com> wrote in message
news:qhLld.106$2O5.83@newsfe5-win.ntli.net...
news:w0Lld.4363$GV5.3244@trnddc04...
| One other thing...
line
| of troubleshooting.
Unless you hook it up to a good power supply and test to see what voltage it
cuts out at, you haven't truly checked this out IMO.
N
news:_pLld.3970$N_5.1750@trnddc03...
of
| monopoly to me.
It's possibly a violation of law, depending on the country/state you are in.
Some have consumer protection laws or court decisions about such matters
requiring them to deliver the info to you.
I know that Radio Shack produced such manuals even for the most trivial
items and for those so unusual that few would tackle them.
N
>| One other thing...
>line
>| of troubleshooting.
>N
No kidding, but hey, he's made up his mind, LIT UP THE CAPS and moved on...
On Sun, 14 Nov 2004 05:42:26 GMT, "Fred"
>since.
>Thanks!!
>Fred
Fred, I've worked as a mechanic,and now I work on computers.
POne thing I've learned doing this is to ask: "How do you KNOW it's
not the batteries?"
The reason I ask is this: when experience says *this* is the problem,
and customer says *this* isn't the problem, *this* is the first thing
I check. And guess what? *This* is usually the problem.
So when you're asked, "How do you know it's not the batteries", you're
being asked because bad or marginal batteries cause exactly the
problems you present.
Yes, there are other things that can cause this. And Oly cameras in
particular seem to have a problem with their power systems on their
PCBs. But still, even on Olys, it *usually* the batteries, and unless
you can assure us that you've actually done some tests that will
remove batteries as the problem, that question will still be asked.
If you were to take the camera to an Oly service center, and assure
them that IT'S NOT THE BATTERIES, the first thing they will do is
insert known good batteries. It's the way troubleshooting goes. First,
you eliminate the obvious. Second, never listen to the customer when
he insists the obvious isn't the problem, *especially* when it's so
trivial to check anyway.
Hope this helps!
Bill Funk
Change "g" to "a"
Well, if the camera works otherwise OK, then you have two choices. Either
live with the problem, or send it off to the Olympus repair facility, and
have them fix it. I would probably live with the problem unless and until
the camera failed in some other way, and then, when it was due for a Cal
and/or other service anyway, I would get the battery checking circuit
repaired along with.....I know that I never use the battery test circuit on
my camera, so I could care less if it works....I just carry spare batteries
around with me in case I should ever need them.
"NSM" <nowrite@to.me> wrote in message news:5uNld.85524$E93.5211@clgrps12...
> and
> Smacks
> of
> | monopoly to me.
I agree, and that's why I usually require the salesman to dig one up for
me.....The last new car I bought came with a complete factory service manual
because I did that, by the way.........
In article <ZZTld.40579$5K2.35694@attbi_s03>, weg9@comcast.net says...
> > and
> > Smacks
> > of
> > | monopoly to me.
about a $500 extra if bought after the sale for my fairly ordinary wagon.
Good point. Will try to find an adapter.
news:brNld.85523$E93.57387@clgrps12...
> | One other thing...
> line
> | of troubleshooting.
it
> N
Good for you! I also try to get service docs when I buy something, but
unfortunately Olympus doesn't make them available to anyone outside the
company.
"William Graham" <weg9@comcast.net> wrote in message
news:ZZTld.40579$5K2.35694@attbi_s03...
> > and
> > Smacks
> > of
> > | monopoly to me.
manual
news:iUTld.40543$5K2.14161@attbi_s03...
on
batteries
Yes, but in this case, I can't live with the problem - the camera is not
usable as is. And can't send to Olympus because I'm sure this problem will
come up again in a year or so - based on email and postings from others.
This is a common problem. Yet, I don't want to throw about the $$ I spent
on it, so I'll keep trying to find out a method of troubleshooting it
myself.
There are 1288 identified and unidentified users. To see the list of identified users, Click here.
