Tom's Hardware > Forum > Storage > General Storage > Ok to leave slave HD cable connected with power off?
Forum Storage : General Storage - Ok to leave slave HD cable connected with power off?
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I want to use a slave hard drive occasionally as a Drive Image backup disk.
I don't like the idea of the backup hard drive always being powered on
because hard drives are rated for a certain number of on/off cycles. Can I
just unplug the power cable and leave the flat ribbon cable connected when I
don't need to use the backup drive or will that create some reliability
issues with my master hard drive on the end of the cable?
Sponsored Links
A neater solution would be a removeable HDD caddy - about £15 - fits into 5
1/4" bay and the HDD caddy slides in and out. You can't hot-swap ofcourse,
but when you wanted to access the drive you've only got to slide it in
before booting.
Will not cause any probs for your bootdrive.
"Mark" <news1@IntelligentSoftwareSystems.com> wrote in message
news:10dsl0j4i6q6n2c@corp.supernews.com...
disk.
I
I
Reply to GTS
> backup disk. I don't like the idea of the backup hard drive
> always being powered on because hard drives are rated for
> a certain number of on/off cycles. Can I just unplug the power
> cable and leave the flat ribbon cable connected when I don't
This has been discussed several times in the past year, and
although there are the usual specification freaks, no one had
any verifiable reason or data to indicate that having a "dead"
HD at the intermediate position of an IDE cable would hurt
the data in any way. I can't think of an obvious reason not
to have the "dead" HD at the *end* of the cable, either, since
I can't see why the "dead" circuitry (i.e. unpowered circuitry)
at the end of the cable would cause less or more signal
reflections than "live" circuitry.
The question does arise, though, why you can't unplug
the intermediate connector from the HD as well as the
power connector? Are you planning on controling the
HD power with a switch? If so, make that switch hard
to reach! :-)
*TimDaniels*
Reply to Anonymous
What about potential harm to the unpowered drive's interface
circuits?
> to reach! :-)
> *TimDaniels*
The e-mail address in our reply-to line is reversed in an attempt to
minimize spam. Our true address is of the form che...@prodigy.net.
Reply to cjt
"GTS" <gts123NOSPAM@ntlworld.com> wrote in message
news:cGDDc.469$m32.2@newsfe6-win...
5
> before booting.
Before power-on actually.
> disk.
Can
> I
when
> I
Reply to Anonymous
"Timothy Daniels" <TDaniels@NoSpamDot.com> wrote in message
news:c8ydnShARJWHnELdRVn-sQ@comcast.com...
Of course it will not proactively do anything since it's powered-off.
Middle of the cable, as what's being discussed is a slave drive. The
question is will unpowered circuitry behave well on an active/powered cable.
Will it load something or draw current...I don't know.
Reply to Anonymous
"CJT" <abujlehc@prodigy.net> wrote in message
news:40DF17C3.8060904@prodigy.net...
> circuits?
That's the question!
Reply to Anonymous
The question is whether data on its way to the end connector would
be absorbed or reflected in some way by the dead circuitry at the
intermediate position. I've tried it. The answer is that the data on
its way to the end connector is not corrupted.
*TimDaniels*
Reply to Anonymous
"CJT" asked:
> circuits?
Why should they be harmed when unpowered and not harmed
when powered?
*TimDaniels*
Reply to Anonymous
> > circuits?
Here's the answer: There's no harm. I've tried it.
*TimDaniels*
Reply to Anonymous
> "CJT" asked:
>>circuits?
> when powered?
> *TimDaniels*
Who knows what state they're in when they're unpowered?
Reply to cjt
>>>circuits?
> *TimDaniels*
Does the standard contain language requiring that they be designed to
not be harmed that way? Anecdotal evidence is just that -- it doesn't
necessarily carry over to drives on which it was not observed.
Reply to cjt
> be designed to not be harmed that way? Anecdotal
> evidence is just that -- it doesn't necessarily carry over
The "standards" don't say anything about that situation
that I know of. Of more importance to me is that it's
a "don't care" for my hard drives (Maxtor DiamondMax
Plus 9s). You are free to care and to fear as much as
you desire. For others, it's an easy experiment.
*TimDaniels*
Reply to Anonymous
1) Is there a "state" when the circuits are unpowered?
2) How is the "state" of an unpowered circuit going to
affect the signal passing by?
3) Why don't you try it and see?
*TimDaniels*
Reply to Anonymous
> to reach! :-)
No switch. I just don't want to wear out the connector/pins.
> *TimDaniels*
Reply to mark
5
> before booting.
I have a StarTech removable drive caddy (DRW115ATA) already on the end of
the cable. After reading prior discussions on this group, I would be
worried about signal reflections caused by a removable caddy in the middle
of the cable and making the total cable length too long.
> disk.
Can
> I
when
> I
Reply to mark
Of course.
Who knows unless it's specified by the designer?
Because it's an engineering question. Would you just build a
bridge and see if it stays up? If it stays up the first time
a car goes over it, is that good enough?
> *TimDaniels*
Reply to cjt
> Of course.
Relax and live life, CJT. Not everything is specified.
*TimDaniels*
Reply to Anonymous
news:10e0lhk8g88558f@corp.supernews.com...
into
> 5
ofcourse,
> > before booting.
The reflection issue appears more severly when there's nothing powered at
the end of the cable. The middle of the cable is much less important. The
design must include keeping the overall cable length in check.
> > disk.
> Can
> > I
> when
> > I
reliability
Reply to Anonymous
> nothing powered at the end of the cable.
You are correct in that there should be a device
connected at the end of the cable to avoid the
reflections (and the timing of those reflections as
they reach the intermediate device), but of what
significance is there in the end device being
powered or not? Implicit in your statement is
the assumption that the impedance looking into
the device from the connector is different
according to whether it was powered or not.
Why should the input impedance change with
power?
*TimDaniels*
Reply to Anonymous
news:iYWdndvfn7DfIn3d4p2dnA@comcast.com...
> powered or not?
Depends on what's there. Unpowered it may not supply what's needed to keep
the reflections down.
Exactly and frequently that is the case and there could also be a bias
issue.
> power?
Active devices may be involved.
Reply to Anonymous
> disk. I don't like the idea of the backup hard drive always being powered
> on
> I just unplug the power cable and leave the flat ribbon cable connected
> when I don't need to use the backup drive or will that create some
> reliability issues with my master hard drive on the end of the cable?
It won't always, but it _can_.
First DVD burner I ever had was an HP. At one point I had it installed in
the machine and had forgotten to attach the power cable. I ended up with
corrupted data on every disk in the machine, not only the slave but also
the ones on the other channel--the isolation there is not as great as one
might assume, or at least it wasn't with the Intel BX chipset.
This got me curious, so I reformatted everything and did some tests and
found out that with the DVD burner plugged into the signal cable but with
no power I did indeed get data corruption on the other attached drives, but
with it not plugged into the signal cable or with it connected to both the
signal and the power cables everything worked fine.
That's the only time I've ever had that happen or heard of it happening, so
it's unusual, but it _can_ happen and the only way to know for sure would
be to test.
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
Reply to Anonymous
"Ron Reaugh" wrote:
> "Timothy Daniels" asked:
> > but of what
> > powered or not?
> what's needed to keep the reflections down.
What might that be? That is, what active device might
there be that would function to suppress reflections from
itself or what it controlled?
*TimDaniels*
Reply to Anonymous
Archived from groups: comp.sys.ibm.pc.hardware.storage,aus.computers (More info?)
In article <a4idnRH42_jJ0X3d4p2dnA@comcast.com>,
Going back a few years, ISTR that the manual for the TRS-80 Model I
stated that peripherals should all be powered up before (or at least
simultaneously with) the computer to avoid damage to unpowered
circuits. Don't ask me why this was recommended; but I *assumed* it
had something to do with signal current paths that were perhaps "open"
when they shouldn't have been, and thus more susceptible.
Cheers, Phred.
ppnerkDELETE@THISyahoo.com.INVALID
Reply to Anonymous
>>> but of what
>>> powered or not?
> *TimDaniels*
transistors
Reply to cjt
> transistors
Any idea how transistors would control their input impedance?
*TimDaniels*
Reply to Anonymous
news:3JOdnaFBDoiJP3zdRVn-vg@comcast.com...
> > transistors
Have you ever studied the impedance of a diode. What do you think the input
of a transistor is and then the possibilities get more complicated from
there. You're outa your depth.
Reply to Anonymous
>>transistors
> *TimDaniels*
Sure. Ever hear of a virtual ground?
Reply to cjt
Is a virtual ground how an IDE device controls signal reflections?
*TimDaniels*
Reply to Anonymous
> think the input of a transistor is and then the possibilities get more
> complicated from there. You're outa your depth.
You're saying the input side of a transistor is a diode?
*TimDaniels*
Reply to Anonymous
Phred <ppnerkDELETETHIS@yahoo.com> wrote
in message news:2kdbfmFugvvU2@uni-berlin.de...
> I stated that peripherals should all be powered up before (or at least
> simultaneously with) the computer to avoid damage to unpowered circuits.
It was always much more complicated than that.
RS232 was designed right from the start to not only
handle that fine, but to hand shorts in the cable fine too.
In spades with USB and firewire now too.
> "open" when they shouldn't have been, and thus more susceptible.
To some extent. Not relevant now tho.
Reply to Anonymous
> *TimDaniels*
Not likely, although I haven't reviewed the input circuitry of every IDE
device and controller, so I can't rule out that possibility. It was
presented as one example of how a circuit might change impedance via
active circuitry, in response to your question (which had drifted away
from the original discussion, so maybe I shouldn't have bothered).
This wasn't just about impedance, or even reflections; at issue was
possible circuit damage to the unpowered drive.
Reply to cjt
> at issue was possible circuit damage to the unpowered drive.
Right. And circuit damage is even less likely than
data corruption. And before you dredge up some
arcane exception, let me restrict the following
comment to my own Maxtor DiamondMax Plus 9s:
It worked for me - no circuit damage!! I hooked 'em
up dead, first at the intermediate position, then at the
end position, and they both are still working.
*TimDaniels*
Reply to Anonymous
> *TimDaniels*
Good for you. I'm going to refrain from that sort of thing,
except perhaps with a drive that's spec'd for hot plugging.
Call me overly cautious if you like, but my data is important
to me.
Reply to cjt
In article <2kej0lF18gr2U1@uni-berlin.de>,
It always is. :-)
Getting back to the OP's original question then, I assume you're happy
to have a 2nd HDD unpowered but not unplugged? Or, perhaps more to
the point for convenience, which way would you do it -- disconnect the
power, or disconnect the interface? Or both?
Cheers, Phred.
Reply to Anonymous
> I assume you're happy to have a 2nd HDD
> it -- disconnect the power, or disconnect the interface?
> Or both?
For convenience, of course, put the power through
an externally operable switch. Arrange it so you can't
bump it accidentally and where you'd have to stop and
think before flipping it - maybe a rocker switch with
guards on either side of the rocker. Leave the data
connector permanently in place to avoid it getting loose
with wear and to avoid putting the signals through
another interface.
*TimDaniels*
Reply to Anonymous
in message news:2kfvk2F1kfedU2@uni-berlin.de...
> It always is. :-)
You're getting there, grasshopper |-)
Tad radical.
> I assume you're happy to have a 2nd HDD unpowered but not unplugged?
Nope, I dont think THAT is a good idea.
It usually does work, but not always, you can see some
problems with the bios working out what drives are present etc.
Thats a different issue to the damage question tho.
> Or, perhaps more to the point for convenience,
I always disconnect both.
And I dont like the major kludge that removable drive bays
involve, I prefer to use a proper formal standard like USB
or firewire or SATA that defines that behaviour fully.
Reply to Anonymous
In article <2kghjiF239vnU1@uni-berlin.de>, "Rod Speed" <rod_speed@yahoo.com> wrote:
>> It always is. :-)
>Tad radical.
And you reckon *I'm* a tad radical! 8-)
Incidentally, does the SATA spec make such things simpler than the
older ATA?
Cheers, Phred.
Reply to Anonymous
>> *TimDaniels*
> to me.
Ok, all this talk of reflections on IDE cables has me confused - what should I
be avoiding to minimise reflections? having a drive attached without power?
having a single drive in the middle connector of an IDE cable with nothing at
the end?
Reply to Anonymous
> what should I be avoiding to minimise reflections? having a
> drive attached without power? having a single drive in the
> middle connector of an IDE cable with nothing at the end?
Having an open connector (i.e. infinite and discontinuous
impedance) at the end of a transmission line (i.e. the data
cable) produces strong reflections. The open connector
at a mid-point is not as a drastic change in impedance since
the transmission line continues on past it. Since any connector
creates some degree of impedance discontinuity, the fewer
connectors in the signal path the better - which is an argument
against slide-in hard drive trays. The question is really how
far do you think your hardware will let you stray from IDE
specs before there's a data error problem. If you put a
removeable HD tray at the end of the cable with another HD
at the mid-point, the mid-point HD may have error problems
when the end tray is removed. If the removeable tray has the
only device on the channel, there probably won't be a problem.
If the removeable tray is at the mid-point, there probably won't
be a problem. But "probably" is a function of your hardware.
Personally, the only situation *I'd* avoid is the one with the
removeable tray at the end with another device at the mid-
point.
*TimDaniels*
Reply to Anonymous
"Alex Hunsley" <lard@tardis.ed.ac.molar.uk> wrote in message
news:10e887ip9gkaf44@corp.supernews.com...
> >> *TimDaniels*
> > to me.
should I
power?
at
> the end?
A single drive always goes at the far end of the cable(as master).
Reply to Anonymous
in message news:2kilf9F2jnpjU2@uni-berlin.de...
>>> It always is. :-)
>> Tad radical.
That aint radical, stupid |-(
> such things simpler than the older ATA?
Yep, it allows for hot plugging in the formal standard.
ATA never has.
Reply to Anonymous
"Ron Reaugh" <ron-reaugh@worldnet.att.net> wrote in message news:QOZEc.49337$OB3.35507@bgtnsc05-news.ops.worldnet.att.net
> > > > *TimDaniels*
> > > to me.
> > the end?
> (as master).
Nonsense. Can be slave as well.
Reply to Anonymous
"Timothy Daniels" <TDaniels@NoSpamDot.com> wrote in message news:8MmdnTqv6YUv3HndRVn-ug@comcast.com
> If you put a
So you either do not remove it or replace it with another one.
> be a problem.
A removeable tray at the 'mid-point' is a potential problem when the tray
is of the kind that uses a small cable between drive and tray connectors.
That plus maybe an inch (or 2) in tracks and pin lengths on the tray
connector assemblies will add a substantial stub to the IDE cable (the
forbidden Y connection) and that may cause reflections by its own.
> point.
> *TimDaniels*
Reply to Anonymous
"Folkert Rienstra" schreibt:
> > If you put a
> > be a problem.
Yup, the stub could be a reflection factory. Whether the timing
of the reflections over so short a distance would be a problem,
I have not idea. (That the timing of the reflections may be
significant may be the reason for the 18"/24" connector
positioning that is part of the IDE specs.) I guess the answer
for the removeable tray at the mid-point would be the same as
the answer for it being at the end - leave a tray with a HD in it
always plugged in to absorb the signal. But then the question
again arises about whether the tray (and the HD) must be powered
in order to absorb signal. If one wanted to limit the wear on a
removeable HD, the least risky way, IMHO, is to put the tray at
the end of the cable on a dedicated channel, even if it takes putting
in a PCI card with an added IDE controller to supply the extra
channel. Then removal of the tray wouldn't interfere with any
other device.
*TimDaniels*
Reply to Anonymous
There are 1183 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
