Tom's Hardware > Forum > Storage > General Storage > A hard drive issue (I think)
Forum Storage : General Storage - A hard drive issue (I think)
Archived from groups: comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.storage (More info?)
I was wondering if anyone could take a couple seconds and help me out.
I have a PC running Win XP Pro, AMD Athlon XP 1500, 1 GB of RAM, and
a 80 GB Maxtor HD. Over the last few months, my computer has started
to lock up on me with the HD light constantly lit. When my wife uses
the computer, she says it has never locked up. I actually reinstalled
Windows and have gotten the same problem. Can anybody lead me in a
direction to fix this?
Thanks.
Sponsored Links
"andrew" <andrew@andrewsteiger.com> wrote in message
news:2a46e1e2.0407081640.1a77ec3c@posting.google.com...
> Thanks.
I wouldn't be suprised if your wife is a key factor in this whole thing.
Joep
Reply to joeP
What programs are you running that your wife doesn't?
"Joep" <j o e p @ d i y d a t a r e c o v e r y . n l> wrote in message
news:a71db$40ee4966$3eddca68$31350@nf1.news-service-com...
out.
and
started
uses
reinstalled
> > Thanks.
thing.
> Joep
Reply to Anonymous
> Thanks.
Check what programs you running, particularly those that run in the
backround. Some rather worthless or trivial programs can be tremendous
hogs under Windows, constantly writing to the HD or using CPU cycles to
the point that it interfers with the programs you really want to run.
Hit CRTL-ALT-DEL and select "Task Manager" and then examine what processes
are running. (You'll have to do a google lookup on many of them to figure
out what they are doing and if they are legit.) You may want to uninstall
certain program or change your msconfig so they don't automatically load
when you start your computer. Also, don't overlook the possibility that
your PC might have a virus, worm, trojan, adware or sypware installed that
is causing the problem.
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Reply to wesley
>> out. I have a PC running Win XP Pro, AMD Athlon XP 1500, 1 GB of
>> RAM, and a 80 GB Maxtor HD. Over the last few months, my computer
>> has started to lock up on me with the HD light constantly lit. When
>> my wife uses the computer, she says it has never locked up. I
>> actually reinstalled Windows and have gotten the same problem. Can
>> anybody lead me in a direction to fix this?
>> Thanks.
> thing.
Joepie toch! :o)
M.f.G.
Michael Kimmer
"Ein Tag an dem Du nicht lächelst ist ein verlorener Tag"
"Eine Nacht in der Du nicht schläfst ist eine verschlafene Nacht"
Reply to Anonymous
Look at the contents of the Event Viewer for possible errors.
>Thanks.
Reply to Andy
There are 821 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
