Tom's Hardware > Forum > Storage > General Storage > Power supply fried my WD120JB. Can I rig it to recover data?
Forum Storage : General Storage - Power supply fried my WD120JB. Can I rig it to recover data?
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
My WD120JB won't spin up due to damage suffered during a power supply
failure. I have no backup (it failed), and I would like to recover
the data, but I don't want to pay the recovery firms high prices
($800+).
Would it be possible for me to buy an identical drive, replace the
circuit boards, and recover the data?
Any other suggestions for cheaper data recovery than the big,
expensive firms on the web? I'm desperate, but not desperate enough
to pay $1,000.
Thanks,
JM
Sponsored Links
> ($800+).
You have to take into account that most modern HDDs have a
pre-amplifier next to the heads inside the enclosure. If
that is fried too, replacing the main board will not help.
There may also be other problems if you do not get exactly the
same revision of the circuit board. Some modern HDDs store
part of the OS on the disk. If that does not match, the
disk will likely not work.
> to pay $1,000.
$1000 is a very reasonable fee. Part of that is for the huge
store of replacement parts a data-recovery company has to keep,
to have exactly the right circuit board available.
Arno
For email address: lastname AT tik DOT ee DOT ethz DOT ch
GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
"The more corrupt the state, the more numerous the laws" - Tacitus
Reply to Anonymous
- 0 +
> ($800+).
> to pay $1,000.
> Thanks,
> JM
I give it a 20% chance. Others may guess higher or lower, but we'll
all just be guessing.
It might be worth a try, but don't get your hopes up too much.
I am aware of it working at least once in history (although I
have no experience with your particular drive), so it's not a
ridiculous idea.
Suppose the motor is fried -- then changing the board won't help.
The e-mail address in our reply-to line is reversed in an attempt to
minimize spam. Our true address is of the form che...@prodigy.net.
Reply to cjt
"Arno Wagner" <me@privacy.net> wrote in message news:2n7a5fFtfqlrU1@uni-berlin.de
> > ($800+).
> Some modern HDDs store part of the OS on the disk.
Clueless.
If anything, modern HDDs may not store part of the firmware on the disks anymore now that flash memory gets cheaper/bigger every
day.
> If that does not match, the disk will likely not work.
> > to pay $1,000.
> Arno
Reply to Anonymous
"Jeff McAhren" <mcahren@gmail.com> wrote in message
news:54e41faf.0408020843.3d52556d@posting.google.com...
> ($800+).
> to pay $1,000.
> Thanks,
> JM
Not if the motor burned out!
Mike.
Reply to Anonymous
- 0 +
"Folkert Rienstra" <see_reply-to@myweb.nl> wrote in message news:<2n8h37Fujv3qU1@uni-berlin.de>...
> day.
Can you specify the name even one of ATA HDD (not older than 10
years), which does not store some parts of the firmware on the disk?
SMART modules, defect lists, event logs, adaptive tables, factory
process logs, etc. can not be stored in flash. And WD, as well as the
majority of other HDDs, have also some program overlays, loaded from a
disk as required.
Leonid
Reply to Leo
What happened to your terribly broken english all of sudden, Leo?
"Leo" <Leo@softjoys.ru> wrote in message news:c05abcbe.0408060648.3811b568@posting.google.com...
> > disks anymore now that flash memory gets cheaper/bigger every day.
> (not older than 10 years),
What is it with the "not older than 10 years" thing?
I certainly hope that you are not suggesting that HDs before that
did not use Firmware and therefor didn't need (flash e)proms.
I have no idea.
I do know, though, that my older IBM SCSIs (DFHS, DCHS, ca 1993)
had 2 sets of firmware, a RAM version and a socalled ROS (ROM) version.
ROS Revision Level = 41
RAM Load Revision Level = 4G
The firmware came in 2 files, a full version and a ROS only version.
The ROS only version could be used to only update the ROS firmware.
The RAM and ROS version parts were distinctly traceable in the full
firmware file (first half ROS, second half RAM).
Both would have the same revision level.
Both versions displayed in the identification line when spun-up.
If the disk was spun-up by the bios instead of PowerON it would
display only the ROS revision at the time of identification by the bios.
After spin-up it would display both the ROS and the saved-on-the-
platters RAM revision which could be different from the ROS revision.
The whole firmware was only 320KB, the ROS firmware was only 160KB
(uncompressed). The DFHS/DCHS has a 1 Mbit flash eeprom.
The firmware was flashed in 2 stages. First the drive was spun down and
the ROS version was uploaded, then the drive would spin-up again and the
RAM version was uploaded and saved on the platters.
My (slightly) newer IBMs (DMVS, ca '98,'99) have only one firmware,
it has grown a bit over 50% to 544KB.
There is only one file, although there are different files depending on
what size drive you have. It now says Microcode Revision Level = 0260
It displays this version whether it has spun-up or not. There are no more
distinct Rom and RAM parts traceable in the firmware file.
The DMVS has a 4 Mbit flash eprom.
In some 5 years flash eeprom size has grown a lot more than firmware
and become so affordable to not have a NEED to store the firmware
partially on the platters to keep the cost down.
I have no bullet-proof proof that firmware is not on the platters any-
more with current harddrives but my DMVSs suggest that the full firm-
ware is now in ROM when it has a 4 Mbit flash eprom to accomodate it.
Uhh, did I say logs, lists and tables? I must have meant firmware.
You know, code? Even Arnie said "OS". Pity that you misunderstood.
> And WD, as well as the majority of other HDDs, have also some
> program overlays, loaded from a disk as required.
Required by whom, or what, why?
> Leonid
Reply to Anonymous
In article <410EB0DD.7090407@prodigy.net>, abujlehc@prodigy.net says...
>ridiculous idea.
Is that counting me?
Of course, I fried the circut board directly when being careless where I
had it set up. The OP's situation sounds a bit more serious. I also now
have the data that I was so upset at losing on at least a half dozen
different CDs from periodic back-ups. Don't want to do that again.
-Tim
Reply to Anonymous
Your turn, Leo.
You called my bluf, now I call yours. Let's see your cards.
"Folkert Rienstra" <see_reply-to@myweb.nl> wrote in message news:2nitmkF1ceoeU1@uni-berlin.de
> I have no idea.
> > Leonid
Reply to Anonymous
Erm, Leo?
"Folkert Rienstra" <see_reply-to@myweb.nl> wrote in message news:2o224rF671dbU1@uni-berlin.de...
> Your turn, Leo.
Reply to Anonymous
There are 1155 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
