Recycle bin problem
There are certain PDF files and others on my desk top that after I put them in the recycle bin then empty it are back on the desk top when I restart the computer
2 answers Last reply
More about recycle problem
  1. -put them in you recycle bin and then empty your recycle bin.
    -or do this in one step: select the files and press shift+delete (warning: you cant get those files back from recycle bin)
  2. Do they dissapear from the desktop when you delete them? After you delete them, do a sort of the icons and see if they pop up again. Right-click on the files and check the location of them, make sure they point back to your profile.
    Are these files you created or did they get installed automatically when you installed some program?
PDF Computers Windows 7
