Archived from groups: microsoft.public.pocketpc (More info?)
Hello! I understand i may not be posting in the correct
group but I am in need of direction and hope someone can
help. 1- When i synch my handspring, it send me a message
saying it needs to access my email and needs to open a
connection there. I say no becasue i don't use microsoft
office on my home computer. It pops up a few times and
then the synch finishes. 2- Nothing form my calander is
visible on the handspring after i synch. It is there but
I can't view it. I know it is there becasue i have
removed it from the computer and synched and it appears.
What do I do? I need this to work!!!
I would post in comp.sys.palmtops.pilot if I were you...
Good luck...
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com This posting is provided "AS IS" with no warranties, and confers no rights...
"Meg" <anonymous@discussions.microsoft.com> wrote in message
news:90d701c43364$b8ff9400$a401280a@phx.gbl...
I am so not tech savy... where are you telling me to post
the question?
>-----Original Message-----
>Good luck...
>The MS-MVP Program - http://mvp.support.microsoft.com >This posting is provided "AS IS" with no warranties, and
If you don't use MS Office at home - I will for this case assume that for
your home computer, you would wish to sync with the Palm Desktop software,
instead of Chapura's Pocket Mirror or PumaTech's IntelliSync to sync with
Outlook.
I would simply re-install the Palm Desktop software, and change the option
from MS Outlook to Palm Desktop. Then - check it that way.
I have successfully synchronized with Outlook at work, Palm Desktop at home
in the past.
Hope this helps.
On Fri, 7 May 2004 00:00:12 +0200,
anonymous@discussions.microsoft.com wrote
(in article <989601c433b5$815b54c0$a101280a@phx.gbl> ):
> the question?
The referred group is a usenet group, to be found on your
newsserver. Since I noticed that you've posted your message
through the web front of this newsgroup, you might want to try
Google Groups to access the referred group. Just click this link
(http://groups.google.com/groups?group=comp.sys.palmtops.pilot)
to find a group dealing with PDAs that are based on the PalmOS.
