G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Yep.. been kickin' this one around for a while. I have a tall server
case with six 5" bays in front. With a Promise TX2 FastTrack adapter
in an upper PCI slot.. 18" cables will reach the two lower 5" bays..
but to connect four ATA-100 drives on two cables requires 22" or 24"
cables.
It really was a `drag' to learn the spec was 18" ribbon.. so I could
not `pack' my big expensive serve chassis with mirror arrays.
What is the consensus on slightly longer cables for Promise TX2 RAID
for TWO drives.. and FOUR drives on two-channel adapter?
cables.
