Archived from groups: comp.sys.ibm.pc.hardware.storage (
More info?)
Previously Falco <johnyfalco@bigfoot.com> wrote:
> Laplink Used Serial as well as parallel.
Yes, true. I completely forgot about the parallel variant.
Arno
> "Jan van Wijk" <jvw.no.spam@dfsee.com> wrote in message
> news:W1d6fUB5m4qH-pn2-ddxrZ7nk4Wd5@merlin...
>> Hi Paul, Arno
>> On Sat, 25 Sep 2004 23:19:42 UTC, Arno Wagner <me@privacy.net> wrote:
>>> > Is a Null modem cable the same as a laplink cable?
>>> > If not, whats the difference?
>>> Haha, good question! Unfortunalely there is no correct answer.
>>> The problem is that there are different ways to connect the
>>> handshaking lines. All these can be called a "null-modem cable".
>>> All might be called a "laplink cable" by some vendor or other.
>> That comment is directed at SERIAL cables only I would say.
>> The "Laplink cable" which was some defacto-standard years ago
>> was actually a cable for the parallel port on PC's that implemented
>> bi-directional capabilities using 4-bits in each direction.
>> So, this is definately NOT the same thing or compatible
>> with regular serial NULL-MODEM cables.
>> (allthough the Laplink data-transfer program could use these as well
>> Laplink cables used to be available from computer stores,
>> perhaps they still are.
>> A wire diagram for such a cable can be found in the document at:
http://www.dfsee.com/lptool/lptool.txt
>> Which is the user-guide for a data-transfer utility I once
>> made that uses that cable.
>> Regards, JvW
>> Jan van Wijk; Author of DFSee:
For email address: lastname AT tik DOT ee DOT ethz DOT ch
GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
"The more corrupt the state, the more numerous the laws" - Tacitus
