Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I just installed SP2 on my Dell 600m with Windows XP installed. When I turn
off my WiFi connection using the Fn-F2 key on my system, I get a balloon with
this message:
"Wireless Network Connection is not connected"
every 10 minutes. Needless to say, this is very annoying. I went to the
properties of my WiFi card and unchecked "Notify me when this connection has
limited or no connectivity" but that did not make a difference. Is there a
way to disable this from happening? This did not happen before I installed
SP2. I realize that I can turn off the wireless connection by going Start |
Control Panel | Internet Connections, right click on the wireless connection,
click on "disable" but that defeats the purpose of having a simple Fn-F2 key.
what did Dell's tech support say about this? do they have an update
available?
On Wed, 11 Aug 2004 15:43:05 -0700, "Mike McCollister"
>this message:
>Thanks,
>Mike
Barb,
I have not heard back from Dell yet. I just posted it on the community forum
which will probably give me better support than Dell directly .
Mike
> available?
> >this message:
> >Thanks,
> >Mike
> Barb Bowman
> Expert Zone Columnist
> http://www.microsoft.com/windowsxp/expertzone > MS-MVP (Windows)
The person who suggested this originally (can't remember name) said it
changes authentication from user to machine. It worked a treat for me.
Barb or any of the other knowledgeable ones, can you suggest why this works
for me and is there a downside.
Stu.
"Barb Bowman [MVP-Windows]" <barb@nospam.com> wrote in message
news:0vdmh05osllqfub2d9v55vrvlrij7g2sia@4ax.com...
> available?
>>turn
>>with
>>this message:
>>has
>>connection,
>>key.
>>Thanks,
>>Mike
> Barb Bowman
On Mon, 16 Aug 2004 19:26:48 +0100, "Stu" <me@home> wrote:
>I had this problem when using WPA but with Belkin hardware and solved it by
>entering the following
>reg key.
>[Hkey_LOCAL_MACHINE\SOFTWARE\Microsoft\EAPOL\Parameters\General\Global]
>"AuthMode"=dword:00000002
>Stu.
>> available?
>>>turn
>>>with
>>>this message:
>>>has
>>>connection,
>>>key.
>>>Thanks,
>>>Mike
>> Barb Bowman
>> http://www.microsoft.com/windowsxp/expertzone >> MS-MVP (Windows)
Interesting.
I used to get that message (with Microsoft gear) before I installed
SP2. Now it no longer disconnects.
The configuration software seems excellent. Let's hope
it is not only when using Microsft gear, although that is unlikely,
since the no longer sell the router, not the PCI adapter.
I have a Linksys PCI adapter that I have not tried. I will do it
and see.
>>>>has
>>>>a
>>>>installed
>>>>Start
>>>>connection,
>>>>key.
>>>>Thanks,
>>>>Mike
>>> Barb Bowman
>>> http://www.microsoft.com/windowsxp/expertzone >>> MS-MVP (Windows)
> Barb Bowman
This is still happening for me and so far Dell has been no help. Am I the
only one having this problem?
Since this happens every 10 minutes, could it be that some service is trying
to get out on the Internet? If so, is there some built-in utility that will
allow me to monitor who is trying to tickle my connection?
Thanks,
Mike
"Mike" wrote:
> Barb,
> Mike
> > available?
> > >this message:
> > >Thanks,
> > >Mike
> > Barb Bowman
> > http://www.microsoft.com/windowsxp/expertzone > > MS-MVP (Windows)
Since SP2 is released, is the checked wzcsvc available at last ?
It's debug spew could help a lot.
--PA
"Mike McCollister" <MikeMcCollister@discussions.microsoft.com> wrote in message
news:A6EA373A-BFA2-4BAD-BB28-694547501627@microsoft.com...
> this message:
> Thanks,
> Mike
OK. I figured it out. It turns out that I needed to select "Disable Wireless
Management by QuickSet" with the Dell QuickSet utility. Now it works.
Mike
> Thanks,
> Mike
> "Mike" wrote:
> > Barb,
> > Mike
> > > available?
> > > >this message:
> > > >Thanks,
> > > >Mike
> > > Barb Bowman
> > > http://www.microsoft.com/windowsxp/expertzone > > > MS-MVP (Windows)
The Fn-F2 feature is a switch to turn off the adapter radio, which does not
go through the OS, so the wireless service in XP is not aware that the radio
is off. The wireless service periodically scans for and attempts to connect
to wireless networks and when there are none around (or when the radio is
turned off and the card is not capable of finding any), you will see the
message below. If you really don't need wireless functionality, you can
disable the wireless adapter, which will eliminate all status balloons.
Thanks
Anton Krantz [MSFT]
This posting is provided AS IS with no warranties and confers no rights
message news:450B1504-8EC9-4F59-876F-6E84BFB0E661@microsoft.com...
> trying
> will
> Thanks,
> Mike
> "Mike" wrote:
>> Barb,
>> forum
>> Mike
>> > available?
>> > >turn
>> > >balloon with
>> > >this message:
>> > >the
>> > >connection has
>> > >there a
>> > >installed
>> > >Start |
>> > >connection,
>> > >Fn-F2 key.
>> > >Thanks,
>> > >Mike
>> > Barb Bowman
>> > http://www.microsoft.com/windowsxp/expertzone >> > MS-MVP (Windows)
