Help - drive letters scrambled
Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
I'll keep this as brief as possible. After using Drive Image
(carefully, I thought) to copy my system drive C to a partition of
identical size on an identical second hard disk, my drive letters have
now been scrambled! C is E and E is C. So by default XP is booting
into the 'copied' version, the one without all my software installed,
my broadband, etc. (And presumably all my hundred of shortcuts screwed
up.)
This is what the setup NOW looks like:
http://www.terrypin.dial.pipex.com/Misc/Mess1.gif
And this is what it SHOULD look like (as it did a few hours ago):
http://www.terrypin.dial.pipex.com/Misc/XPDiskMgmt.gif
Can someone step me through how I can get these drive letters returned
to their former state please?
BTW, I have Drive Image 2002 and PM 7.0, as well as whatever
facilities are offered by XP Home itself with Disk Management.
All help and advice will be warmly appreciated please.
Terry, West Sussex, UK
7 answers Last reply
More about help drive letters scrambled
  1. Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
    On Sun, 10 Oct 2004 15:36:32 +0100, Terry Pinnell
    >up.)
    You can change the drive lette easily using the Registry editor
    (regedit)
    Just go to HKEY_LOCALE_MACHINE/System/Mounted device
    There you have the list of al the drive, and you can change them and
    reboot
    Be careful into doing it
    Good luck
    Nick
  2. Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
    Well, I'm darned! Somehow XP has automagically returned the partition
    names to their correct original labels:
    http://www.terrypin.dial.pipex.com/Misc/LookingGood.gif
    It's also for some reason removed that 'Boot' annotation.
    All I did was what I'd done a couple of times before, change the
    default boot drop down box I described.
    Anyway, not worried how it happened, just happy to have normality
    back.
    Terry Pinnell
    Hobbyist, West Sussex, UK
  3. Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
    Terry, not to make lite of the problem (at least it's fixed) but you have more darn problems than any one person I know of.
    Just my 2¢ worth,
    Jeff
    __________In response to__________
    "Terry Pinnell" <terrypinDELETE@THESEdial.pipex.com> wrote in message news:q7bjm0l4vkm0vjcnn8t57q09tjbn6ni2uj@4ax.com...
    | back.
    | Terry Pinnell
  4. Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
    I was premature saying it was fixed ;-(
    I feel very close to sorting it, yet still can't quite get there. Any
    further help would be much appreciated please. I'll try to spell out
    all the details.
    This 'system' to which I'm presently booted, in which I'm composing
    this message, is called 'XP Home Edition #2'. That's what appears in
    the drop-down box I've since discovered at XP System
    Properties>Advanced>Startup & Recovery>Settings>System Startup.
    And it's the line that was selected by default for a few seconds
    during the last boot up process.
    In XP Disk Mgmt I see this:
    http://www.terrypin.dial.pipex.com/Misc/AnotherBootOption.gif
    So that seems to confirm that I'm in C.
    Note the annotation 'Boot' against C.
    BUT I don't follow why C is now shown on HD2 ?? I want it to be on
    HD1, where it was until I copied C (on HD1) to E (on HD2). IOW, I want
    C to always mean the physical partition on HD 1, and I want it to be
    my normal 'system'. Only in an emergency, or to experiment, would I
    want to boot up to the alternative system, which I copied to E.
    Now, I'll save this post while I reboot to the other option.
    OK, I've done that. In XP Disk Mgmt I now see this:
    http://www.terrypin.dial.pipex.com/Misc/OneBootOption.gif
    The arrangement here is the one I've become used to over the last
    couple of years.
    BUT it shows that E is now 'Active'. (Why not 'Boot' BTW?)
    And, the files I found under the C:\ path while in the other system
    are now under E:\. Anyway, I am now thoroughly confused!
    Can anyone suggest a simple, risk-free way of getting to what I had
    before please: Boot to C, C physically on HD1.
  5. Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
    Terry, it (in my experience) wont be quick or easy.
    You need to delete and format the C and E partitions. Reinstall XP to the freshly formated C on HDD 0 (1). Install your programs. Get imaging software, I use TrueImage from www.acronis.com, and create an image of C.
    Do your experimentation on C and if it goes bad restore the image. Just copying XP to another primary partition doesn't work, as you found out.
    Just my 2¢ worth,
    Jeff
    "Terry Pinnell" <terrypinDELETE@THESEdial.pipex.com> wrote in message news:ml2lm0hnns5abh0d9f12dpu3nnbo12q62n@4ax.com...
    | all the details.
    | couple of years.
  6. Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
    news:hshim05jkrvonfefr1uathheerup0qsma1@4ax.com...
    > have
    > installed,
    > screwed
    > up.)
    > returned
    a) Drive image 7 is needed for WXP.
    b) You made a copy of your drive instead of a backup.
    c) It does not make sense to make a back up of your
    drive and then leave the backup/copy in the machine.
    d) Things may be FUBAR by now.
  7. Archived from groups: microsoft.public.windowsxp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
    "Frank" <bbunny@bqik.net> wrote in message
    news:uvVymhVsEHA.2128@TK2MSFTNGP11.phx.gbl...
    > > have
    > > installed,
    > > screwed
    > > up.)
    > > returned
    It can still be fixed
    Print this in case it doesn't work as planned
    1. Start-->Run
    2. Type MSCONFIG
    3. select the BOOT.INI tab
    4. IF there is more than one line, remove the one that points to the wrong
    partitions. (it will be listed strange but look for the one that does NOT
    say partition 1) If there is only one line then you'll need to alter it
    another way.
    1. My Computer-->C:\
    2. Go to Tools Menu-->folder options
    3. Select VIEW tab
    4. Find and select "Show hidden files and Folders" (may say "Show all
    files") then click OK
    5. Find a file named Boot.ini
    6. Right click it and select copy, then past the copy to the same area.
    7.now right click the copy and select rename. Name it something like
    Boot.bad
    8. open the original Boot.ini in wordpad or notepad.
    9. Locate the following line
    default=multi(0)disk(0)rdisk(0)partition(x)\WINDOWS
    Where (x) can be any number depending on the partition it is pointing the
    system to and how many partitions exist on your drive.
    10. Change the character from x to 1.
    Reboot and see if it works. If it does, congratulations
    If not. go back to the c: drive, rename boot.ini to boot.poo, then rename
    boot.bad to boot.ini so you are at least back where you started.
    Microsofts knowledgebase usually has helpful fixes for this kinda thing too.
    Search for something like XP boots to wrong partition.
    Kevin
Hardware Storage
