iTask problems
Last response: in Cell Phones & Smartphones
Anonymous
May 7, 2004 5:51:00 AM
Archived from groups: microsoft.public.pocketpc (More info?)
Hi there. I'm new to this group but thought someone might have some
ideas in here
I've been using my Ipaq 3950 for a little while but only just
discovered itask. I have pocketplus installed but wanted a simple task
switcher. I thought iTask would work fine but
it doesn't work properly (I don't know if it ever did as I haven't
tried before - or if something else conflicts with it) I see there are
supposed to be pop up menus to work with in it but on mine the menus
are full of gibberish colours, or in one case 3 calculator icons. It's
guesswork as to which you would choose and for what. Also the system
tab which I assume would take you to the systems folder which could be
handy, when clicked adds a very tiny black box/dot just above it but
doesn't offer a menu or link.
Is there a way to fix this? I hate to a hard reset if there is a
simple solution. Also anyone know if there is any known program that
conflicts with itask
If not is there a 3rd party task switcher which does much the same
thing? I tried icbar but it keeps crashing my pocketpc (which is
running 2002 by the way)
last question. If I do a full backup and then a hard reset and then
reinstall from my backup will I simply reinstall any problems with
itask or does the backup restore not affect programs in ROM?
Thanks for any help with this issue
More about : itask problems
Anonymous
May 7, 2004 5:51:01 AM
iTask is quite configurable, though it is not the friendliest process. There
is an iTask Settings control panel under Settings/System. If you get into
that and then select the Help function, it does give some good info. Play
with it a bit and see if it will work for you.
Sven, MS-MVP Mobile Devices
"Jane Austin" <janeaustin376@hotmail.com> wrote in message
news:a8ql90ltv1seucb2itks3v5otq10k5188c@4ax.com...
> ideas in here
Anonymous
May 7, 2004 9:34:41 AM
Yes I've checked out the help section and the configurations but I
don't think it's just settings as the menus are so garbled. The
configuration settings simply don't work the way the help file says
they will. I think it's corrupted but I don't know how to fix it
On Thu, 6 May 2004 21:14:43 -0600, "Sven, MVP-Mobile Devices"
Anonymous
May 7, 2004 7:53:02 PM
If it's that corrupted, I'd be willing to bet you are looking at a hard
reset to fix it. That of course puts you back to a factory fresh condition,
so you would need to back up all your files, make sure your outlook sync is
up to date and be prepared to reload all your apps. I don't think doing a
backup, hard reset and restore would help, because you would likely end up
restoring the garble.
news:4o7m90tsj85sv69so7kkbutsd42jn4n183@4ax.com...
There
Play
Anonymous
May 8, 2004 9:47:36 AM
ok thanks I'll plan on a hard reset when I have the time to rebuild it
all.Time consuming that's all. Was hoping for something quicker but
that's life. Thanks for the help
On Fri, 7 May 2004 15:53:02 -0600, "Sven, MVP-Mobile Devices"
