G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hi
Drive Image is giving much grief on a clean install of XP Pro SP2. I
installed DI5.01 which used to work fine before I got my current m/b (Asus
A7N8X-E booting off SATA 0). If I either boot into Caldera DOS from Windows
or use the floppies, DI will start then finish OK /if/ I don't select Verify
& if I do so, I get error 1831 (Image not found).
If I try to read the resulting image files, I get access denied. I then
check the permissions which were set to System only - I add the
Administrators group then can then read, verify or restore them. The
partitions which being copied & the target partition are all NTFS. Anyone
any ideas? I've pasted this bit from the debug log which is from DI2002
which does the same:
BootExecute:
PDBoot.exe
autocheck autochk *
Batch File - D:\Program Files\PowerQuest\Drive Image
2002\DIDefs\PQ_DIWIN.pqb
pqLogLock (pqhandle == 0) ...
Locking file \\.\C:
ThreadedLock: failed retry 0, DeviceIoControl = 5
ThreadedLock: failed retry 1, DeviceIoControl = 5
ThreadedLock: failed retry 2, DeviceIoControl = 5
pqLogLock: FSCTL_LOCK_VOLUME failed = 0
IsLockable(C - pqLogLock failed.
Cannot Commit Changes Live.
Regards
Hi
BootExecute:
PDBoot.exe
autocheck autochk *
Locking file \\.\C:
Regards
