Building a floppy drive interface
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hi
I'm looking for some docs about how PC/AT floppy interface works and
how can
I build a floppy drive interface to be attached to PC parallel port. I
know how
parallel port works, even built some circuits connected to it.
My interests are: pinout, levels (should be TTL), protocols, etc.
I've been searching at epannorama.net but those docs just explains
basically cabling.
This is my hardware project to a college class. :)
Can anybody please point me out to some good tecnical documentation
about it?
thanks a lot in advance.
Lucas Brasilino
2 answers Last reply
More about building floppy drive interface
  1. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    Previously Lucas Brasilino <brasilino@yahoo.com> wrote:
    > Hi
    > how can
    > know how
    > basically cabling.
    > about it?
    Best start by reading the docs of the controller chip. You should be
    able to get a discrete one. Some info here:
    http://home.swipnet.se/~w-68269/wd_fdc/wd_fdc.htm
    on using a WD chip. I believe the original floppy controller from the
    AT is the NEC µPD765. You might want to google for it.
    It might be difficult to get these chips today, since for a long time
    they have been integrated into multi-I/O chips.
    I think you should be able to read/write/format with a directly
    connected high-speed microcontoller, such as a 33Mhz DS 87C520 WCL,
    but that would mean implementing the whole FDC in software. That
    could be rather messy and take long.
    I think your best approcha is tho first find out what chips you
    can actually get and then selet the one that needs the
    easiest interface logic and the least programming.
    Arno
    For email address: lastname AT tik DOT ee DOT ethz DOT ch
    GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
    "The more corrupt the state, the more numerous the laws" - Tacitus
  2. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    "Lucas Brasilino" <brasilino@yahoo.com> wrote in message
    news:c30b20f8.0410260413.773dd1de@posting.google.com...
    > Hi
    > how can
    Buy one...
    http://www.ramplus.com/micsolbacpar2.html
Hardware Floppy Disk Parallel Port Storage
