Archived from groups: comp.sys.ibm.pc.hardware.storage (
More info?)
Boot your system to BIOS setup and verify settings. I also assume that you
have WindowsXP SP1 installed (>137GB Hard Disk 48-bit Logical Block
Addressing error fixed).
"MHenry" <MHenry@blank.net> wrote in message
news:usiao05rt90gg7i40hddpktn2lihe2pbaq@4ax.com...
> On Sun, 31 Oct 2004 17:46:12 +0100, "Michael Kimmer"
> <michaelkimmer@NOSPAM.xs4all.nl> wrote:
> >Joe Morris wrote:
> >> MHenry <MHenry@blank.net> writes:
> >>> I ran Norton Disk Doctor from DOS and it reported that "The extended
> >>> partition chain on hard disk 1 is invalid. It asked me if I wanted
> >>> NDD to fix it, but I declined, because I was afraid it would delete
> >>> all the data on the disk. NDD recognizes two volumes, C and D, but I
> >>> have three partitions, C, D and E. It seems like this may be the
> >>> problem with Norton Ghost on my system.
> >> Note that PARTINFO needs to be run from a DOS boot. If you don't have
> >> one handy, check
http://www.bootdisk.com for downloads.
> >Norton Ghost 9.0 comes with the Windows version of the PARTINFO tool
(what
> >the OP actually needs since the problems occur in Windows). Open the
SUPPORT
> >folder on the program CD and start the tool called PartInNT.exe (save the
> >output file by either clicking on the "Save As..." button or on the "Copy
to
> >Clipboard" button and pasting the contents in e.g. Notepad).
> I ran PartinNT.exe and got errors, including disk geometry errors.
> I don't understand what all of this means in terms of what I should
> do.
> Here is the output in case someone can help me interpret the results
> and draw the proper conclusions. That is, what now?
> PowerQuest PartitionInfo 8.0 -- Windows NT/2000 Version
> Date Generated: 10/31/04 12:29:16
> Copyright (c)1994-2002, PowerQuest Corporation
> Permission is granted for this utility to be freely copied so long
> as it is not modified in any way. All other rights are reserved.
> PowerQuest, makers of PartitionMagic(r), Drive Image(tm), and
> DriveCopy(tm), can be reached at:
> Voice: 801-437-8900
> Fax: 801-226-8941
> Web site: http://www.powerquest.com/support/
> E-mail: magic@powerquest.com
> General System Information:
> Total Physical Memory (bytes): 536,330,240
> Used Physical Memory: (bytes): 174,247,936
> Maximum Page File Size: (bytes): 1,306,468,352
> Current Page File Size: (bytes): 160,260,096
> Disk Geometry Information for Disk 1: 16709 Cylinders, 255 Heads,
> 63 Sectors/Track
> System PartSect # Boot BCyl Head Sect FS ECyl Head
> Sect StartSect NumSects
> 0 0 80 0 1 1 07 1023 254
> 63 63 163,846,872
> Info: End C,H,S values were large drive placeholders.
> Actual values are:
> 0 0 80 0 1 1 07 10198 254 63 63
> 163846872
> 0 1 00 1023 0 1 0F 1023 254
> 63 163,846,935 324,496,935
> Info: Begin C,H,S values were large drive placeholders.
> Actual values are:
> 0 1 00 10199 0 1 0F 30397 254 63 163846935
> 324496935
> Error #109: Partition ends after end of disk.
> ucEndCylinder (30397) must be less than 16709.
> 163,846,935 0 00 1023 1 1 07 1023 254
> 63 163,846,998 163,830,807
> Actual values are:
> 163846935 0 00 10199 1 1 07 20396 254 63 163846998
> 163830807
> ucEndCylinder (20396) must be less than 16709.
> 163,846,935 1 00 1023 0 1 05 1023 254
> 63 327,677,805 160,633,935
> Actual values are:
> 163846935 1 00 20397 0 1 05 30395 254 63 327677805
> 160633935
> Error #107: Partition begins after end of disk.
> ucBeginCylinder (20397) must be less than 16709.
> Warning #109: Partition ends after end of disk.
> ucEndCylinder (30395) must be less than 16709.
> 327,677,805 0 00 1023 1 1 07 1023 254
> 63 327,677,868 160,633,872
> Actual values are:
> 327677805 0 00 20397 1 1 07 30395 254 63 327677868
> 160633872
> Partition Information for Disk 1: 131,069.4 Megabytes
> Volume PartType Status Size MB PartSect #
> StartSect TotalSects
> C: NTFS Pri,Boot 80,003.4 0 0
> 63 163,846,872
> ExtendedX Pri 158,445.8 0 1
> EPBR Log 79,995.5 None --
> 163,846,935 163,830,870
> D: NTFS Log 79,995.5 163,846,935 0
> EPBR Log 78,434.5 163,846,935 1
> E: NTFS Log 78,434.5 327,677,805 0
> Unallocated Log 15.7 None --
> 488,311,740 32,130
> Boot Record for drive C: (Drive: 1, Starting sector: 63, Type: NTFS)
> 1. Jump: EB 52 90
> 2. OEM Name: NTFS
> 3. Bytes per Sector: 512
> 4. Sectors per Cluster: 8
> 5. Reserved Sectors: 0
> 6. Number of FATs: 0
> 7. Root Dir Entries: 0
> 8. Total Sectors: 0
> 9. Media Descriptor: 0xF8
> 10. Sectors per FAT: 0
> 11. Sectors per Track: 63 (0x3F)
> 12. Number of Heads: 255 (0xFF)
> 13. Hidden Sectors: 63 (0x3F)
> 14. Total Sectors (>32MB): 0 (0x0)
> 15. Unused: 0x80008000
> 16. Total NTFS Sectors: 163846871
> 17. MFT Start Cluster: 4
> 18. MFT Mirror Start Clust: 10240429
> 19. Clusters per FRS: 246
> 20. Clusters per Index Blk: 1
> 21. Serial Number: 0x4274591674590E53
> 22. Checksum: 0 (0x0)
> 23. Boot Signature: 0xAA55
> Boot Record for drive D: (Drive: 1, Starting sector: 163,846,998,
> Type: NTFS)
> 1. Jump: EB 52 90
> 2. OEM Name: NTFS
> 8. Total Sectors: 0
> 16. Total NTFS Sectors: 163830806
> 18. MFT Mirror Start Clust: 10239425
> 21. Serial Number: 0x1E74CF9274CF6ADB
> Boot Record for drive E: (Drive: 1, Starting sector: 327,677,868,
> Type: NTFS)
> 1. Jump: EB 52 90
> 2. OEM Name: NTFS
> 8. Total Sectors: 0
> 16. Total NTFS Sectors: 160633871
> 18. MFT Mirror Start Clust: 10039616
> 21. Serial Number: 0xC2A07F75A07F6F33
