new hard drive + old hard drive
Archived from groups: comp.sys.ibm.pc.hardware.storage,freeserve.help.windows.misc,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
I think I need you guys help here.
My old custom-built computer's hard drive is running out of space and
it's messed up and registry doesn't look good.
I was given used 20GB and try to install as local(bootable) hard
drive(C:) and want to use old hard drive(13GB) as back-up storage(F:)
I have XP installed now and have a CD for XP and want to clean install
on new 20GB.
I know to how to hook up and set up master and slave and configure
bios etc and install XP with clean installation.
What I want to find out is I want to use the program in old hard
drive.
As far as I know,It must be re-installed onto new hard drive in order
to work.
But there are so many program and utility I do not have the CDs.
When most people upgrages their hard drive,I know they might use
harddrive package-come along-utility OR the prgram such as ghost and
drive copy or image in order to copy whole drive.
But my problem is I want clean installed XP on new hard drive and
still want to use the program in the slave-connected old hard drive
excluding XP.
Is it possible? Only way is re-install the program on new hard drive?
Or ghost or other program let me just copy the program and allow it to
work under clean-installed XP?
HELP~!
Thanks in advance.
18 answers Last reply
More about hard drive hard drive
  1. Archived from groups: comp.sys.ibm.pc.hardware.storage,freeserve.help.windows.misc,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
    sorry for top posting but think there is a wizard for setting and file
    transfer in xp take a look before you do install and might be what you are
    looking for.
    Larry
    "wonderboy" <barbecuesauce99@hotmail.com> wrote in message
    news:beff77c3.0411190647.5e3601c8@posting.google.com...
    > on new 20GB.
    > drive.
    > to work.
    > excluding XP.
    > HELP~!
    > Thanks in advance.
  2. Archived from groups: comp.sys.ibm.pc.hardware.storage,freeserve.help.windows.misc,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
    ----- Original Message -----
    Newsgroups:
    Sent: Friday, November 19, 2004 10:05 AM
    Subject: Re: new hard drive + old hard drive
    > looking for.
    The file and settings transfer wizard will move exactly that -- your files
    and settings. It will not, however, move your programs. Programs generally
    have an installer program that is separate from the actual program. That
    installer creates the files and sets the references needed for that program
    to work, and copying programs does not generally work without re-installing
    them. There is some software available, such as PC Relocator that is
    supposed to move programs, but I've not had good success with that working.
    I find that a clean OS install with clean installs of all programs is the
    best way to have a fast, reliable OS for the long run. In the future make
    sure to hang on to all those install disks and to archive any programs you
    download from the internet!
    >> on new 20GB.
    >> drive.
    >> to work.
    >> excluding XP.
    >> HELP~!
    >> Thanks in advance.
  3. Archived from groups: comp.sys.ibm.pc.hardware.storage,freeserve.help.windows.misc,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
    >drive.
    >to work.
    Forget about it. You'll need the installation CDs etc. for the
    programs.
  4. Archived from groups: comp.sys.ibm.pc.hardware.storage,freeserve.help.windows.misc,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
    Thank you for reply,guys.
    Guess I have to give up.
    I guess I have to re-install program that I have CDs for on new drive.
    Only way to use non-transferable program in old hard drive is set this
    hard drive as master,I guess
    Here is what I have now.
    I (will) have two hard drives and one CD-RW(master) and one
    DVD-ROM(slave).
    Each hard drive will have own XP since I will clean-install on new
    hard drive.
    So new hard drive will be master and old mess-up hard will be slave.
    Since I can't use the program in old hard drive,I will have to boot on
    old hard drive whenever I need to use the program in the old hard
    drive.
    It will be a big pain to open the case and switch the cable.
    Is there any program will allow me to choose which hard drive I want
    to boot on?
    I can set as
    new hard drive(master) and CD-RW(slave)
    old hard drive(master) and DVD-ROM(slave).
    this set up will make it easy?
    I am not looking partition since each drive has OS on it.
    Thanks in advance.
  5. Archived from groups: comp.sys.ibm.pc.hardware.storage,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
    "wonderboy" <barbecuesauce99@hotmail.com> wrote in message news:beff77c3.0411200551.97d7a5c@posting.google.com...
    > Thank you for reply, guys.
    Or export the program's registry entries from the old harddrive OS and
    import them to the new harddrive OS's registry.
    > hard drive as master, I guess
    Oh, what for? What exactly do you think that will accomplish?
    > DVD-ROM(slave).
    > hard drive.
    Yup, so?
    > Since I can't use the program in old hard drive, I will have to boot on
    > old hard drive whenever I need to use the program in the old hard drive.
    Or export the program's registry enties from the old harddrive OS and
    Uhuh, and what on earth would you want to do that for?
    > to boot on?
    Ever heard of a thing that goes under the name of 'BIOS'?
    What exactly do you think this entry 'BootSequence' in the BIOS setup
    is all about? Learn how to use your MainBoard Setup program.
    > I can set as
    Make easy what?
    > Thanks in advance.
  6. Archived from groups: comp.sys.ibm.pc.hardware.storage,freeserve.help.windows.misc,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
    No it won't make antdifference if you do a clean install, the o/s won't be
    associated with it.
    > DVD-ROM(slave).
    > hard drive.
    > drive.
    > to boot on?
    Windows XP will boot from either via the loader and boot.ini, you don't need
    anything else, just make sure both drives are connected as you intend to
    keep them when you set XP up.
    > I can set as new hard drive(master) and CD-RW(slave)
    Yes that will be the best layout imo.
  7. Archived from groups: comp.sys.ibm.pc.hardware.storage,freeserve.help.windows.misc,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
    On Sat, 20 Nov 2004 16:46:06 -0000, "Grimly Fiendish"
    >associated with it.
    You said your present installation, though it has problems, is
    runnable? If so, leave it completely alone and continue to run it
    when you need the programs on it.
    You don't need to mess with cable-changing. If you install a new XP
    on your new primary drive you just need a simple modification of the
    boot.ini file to allow a multi-boot option.
    I discover that there ARE programs that claim to extract complete
    program installations from one computer so they may be installed on
    another. Does anyone have more information?
    What are these irreplaceable programs, anyway? Can't you borrow the
    installation disks the same place you did before?
  8. Archived from groups: comp.sys.ibm.pc.hardware.storage,freeserve.help.windows.misc,microsoft.public.windowsxp.help_and_support,alt.comp.hardware.pc-homebuilt (More info?)
    > on new 20GB.
    A 20GB hard drive will disappear fast with Windows XP and modern software,
    unless you keep a very barebones system. Remember that a 20GB hard drive
    will net you about 18.5GB after formatting, and you should keep extra room
    on the disk to allow files to be manipulated by the filesystem. 20GBs of
    space does not mean you can put 20GB on it and be fine. Your hard drive
    will fragment so bad it will come to a crawl, if you do.
  9. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    "Ruel Smith" <NoWay@NoWhere.com> wrote in message
    news:Jbqqd.857$Xv.808@fe37.usenetserver.com...
    You will not fill a 20GB hard drive unless you are a high-speed internet pirate
    or a digital audio/video junkie. Lots of people still have under 20GB.
  10. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    On Sun, 28 Nov 2004 15:04:56 -0500, Ruel Smith <NoWay@NoWhere.com>
    >> on new 20GB.
    Because I had to image my 2001 dual PIII system's original 40 GB
    master HD with the same model, I now have a similar set-up.
    Here's what I've done, and as a method it has worked quite well.
    1st drive: 40 gb
    C: (root): 10 gb: Windows 2000 and all patches associated. Network
    stuff. AVG anti-virus. Any software (surprisingly few) that *must* be
    on C:
    Usage: About 48%, and that doesn't vary much.
    D: (programs) 13 GB: ALL programs, which means I do "custom" installs
    of everything. This drive gets about 80% full, but because it's
    programs, it doesn't get fragmented easily and is simple to manage.
    I keep all mail, browser and news apps here, and isolate ALL mail and
    downloads, patches, etc. in one folder, which is aggressively scanned.
    I also update my AV definitions two to three times a week. I have
    "trapped" several thousand viruses in these isolated folders; I
    haven't had a virus actually execute on my home system since 1993 or
    so, when I figured out one big C: drive was a poor policy.
    Isolating downloads and automating viral scanning of those downloads
    was the best thing I've done.
    E: (data) 14 GB or so: ALL data, with the exception of certain system
    management files, admin stuff, etc. left on C: This drive is regularly
    backed up and regularly defragmented. I allow very little
    "conversation" between E: and the other drives. I backup E: only to a
    second, larger drive in the same machine, and I back up current
    critical data files over a home office, router-based network to a
    legacy dual PII, which has all my current apps and settings, and can
    act as a (considerably slower) workstation if needed. Also, I plug my
    laptop into the network about once a month and update the archive
    there.
    Last week it was.
    A recent power-related event corrupted my C: drive.
    A reformat and reinstall took a few hours, mainly because I had to
    download all the patches and upgrades from Microsoft. None of my data
    was affected, however, and I am giving my business a good UPS for Xmas
    <G>.
    The only way I figure I could bulletproof my system even further
    (beyond the UPS I should have bought ages ago) would be to automate
    off-site archiving.
    So if the house burns down, I suppose I will be screwed, but the rest
    works well. You are on the right track by completely isolating your
    OS. Another suggestion is to partition a few GB for the paging file,
    and assigning that entire partition for that purpose.
    R.
  11. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    Ruel Smith <NoWay@NoWhere.com> wrote:
    >wonderboy wrote:
    >> ...I have XP installed now and have a CD for XP and want
    >> to clean install on new 20GB.
    >software, ...
    Especially if you wish to take advantage of all that a disk manager
    can do for you.
  12. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    >>software, ...
    > can do for you.
    So in XP-speak, "manage" = "use up?"
    The e-mail address in our reply-to line is reversed in an attempt to
    minimize spam. Our true address is of the form che...@prodigy.net.
  13. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    >>>software, ...
    >> manager can do for you.
    If you are suggesting that I am a Windows advocate, you are horribly
    wrong. However, I tend to go with facts. Unless a personal computer
    user wants to live in a closet (I think some do), Windows is it. For
    my computer usage, Windows XP is remarkably better than Windows 9x.
    To me, a disk manager is almost important as the required operating
    system itself. PartitionMagic radically changed the way I use a
    personal computer.
    As far as the usage goes. I would think there would be little
    difference with any operating system. I use a disk manager to do
    incremental installations. That way, if something goes wrong, I can
    revert to a prior installation. Stuff like that requires additional
    disk space.
    >Path: newsdbm05.news.prodigy.com!newsdst02.news.prodigy.com!newsmst01a.news.prodigy.com!prodigy.com!postmaster.news.prodigy.com!newssvr31.news.prodigy.com.POSTED!9c3d6694!not-for-mail
    >Message-ID: <41ABCC4F.4090705@prodigy.net>
    >From: CJT <abujlehc@prodigy.net>
    >User-Agent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.8a5) Gecko/20041112
    >X-Accept-Language: en-us, en
    >MIME-Version: 1.0
    >Newsgroups: comp.sys.ibm.pc.hardware.storage
    >References: <beff77c3.0411190647.5e3601c8@posting.google.com> <Jbqqd.857$Xv.808@fe37.usenetserver.com> <Xns95B0C489FF5D4wisdomfolly@151.164.30.48>
    >In-Reply-To: <Xns95B0C489FF5D4wisdomfolly@151.164.30.48>
    >Content-Type: text/plain; charset=ISO-8859-1; format=flowed
    >Content-Transfer-Encoding: 7bit
    >Lines: 25
    >NNTP-Posting-Host: 67.67.222.243
    >X-Complaints-To: abuse@prodigy.net
    >X-Trace: newssvr31.news.prodigy.com 1101778000 ST000 67.67.222.243 (Mon, 29 Nov 2004 20:26:40 EST)
    >NNTP-Posting-Date: Mon, 29 Nov 2004 20:26:40 EST
    >Organization: SBC http://yahoo.sbc.com
    >X-UserInfo1: TSUGW_GDPBUGR\@YOBCDN_HAQB^H@IPDLXUNNH\KMAVNDQUBLNTC@AWZWDXZXQ[K\FFSKCVM@F_N_DOBWVWG__LG@VVOIPLIGX\\BU_B@\P\PFX\B[APHTWAHDCKJF^NHD[YJAZMCY_CWG[SX\Y]^KC\HSZRWSWKGAY_PC[BQ[BXAS\F\\@DMTLFZFUE@\VL
    >Date: Tue, 30 Nov 2004 01:26:40 GMT
    >Xref: newsmst01a.news.prodigy.com comp.sys.ibm.pc.hardware.storage:342435
  14. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    >>>>software, ...
    > personal computer.
    Windows XP has that built in.
    > disk space.
    >>Path:
    >>Message-ID: <41ABCC4F.4090705@prodigy.net> From: CJT
    >><abujlehc@prodigy.net> User-Agent: Mozilla/5.0 (Windows; U; Win98; en-US;
    >>rv:1.8a5) Gecko/20041112 X-Accept-Language: en-us, en
    >>MIME-Version: 1.0
    >><Xns95B0C489FF5D4wisdomfolly@151.164.30.48> In-Reply-To:
    >><Xns95B0C489FF5D4wisdomfolly@151.164.30.48> Content-Type: text/plain;
    >>charset=ISO-8859-1; format=flowed Content-Transfer-Encoding: 7bit Lines:
    >>25 NNTP-Posting-Host: 67.67.222.243
    >>29 Nov 2004 20:26:40 EST) NNTP-Posting-Date: Mon, 29 Nov 2004 20:26:40 EST
    >>X-UserInfo1:
    >>Date: Tue, 30 Nov 2004 01:26:40 GMT Xref: newsmst01a.news.prodigy.com
    --John
    Reply to jclarke at ae tee tee global dot net
    (was jclarke at eye bee em dot net)
  15. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    If you mean System Restore, it's not the same and it's not nearly as
    powerful IMO.
  16. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    > powerful IMO.
    Seems to work well enough though.
    --John
  17. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    >>>> do incremental installations. That way, if something goes
    >>>> wrong, I can revert to a prior installation.
    >> as powerful IMO.
    Not compared to a disk manager.
    >--John
    >Path: newssvr30.news.prodigy.com!newsdbm05.news.prodigy.com!newsdst02.news.prodigy.com!newsmst01a.news.prodigy.com!prodigy.com!newsfeed-00.mathworks.com!pln-e!spln!dex!extra.newsguy.com!newsp.newsguy.com!news3
    >From: "J. Clarke" <jclarke@nospam.invalid>
    >Date: Sat, 18 Dec 2004 00:20:13 -0500
    >Organization: http://newsguy.com
    >Lines: 21
    >Message-ID: <cq0f9301aoq@news3.newsguy.com>
    >References: <beff77c3.0411190647.5e3601c8@posting.google.com> <Jbqqd.857$Xv.808@fe37.usenetserver.com> <Xns95B0C489FF5D4wisdomfolly@151.164.30.48> <41ABCC4F.4090705@prodigy.net> <Xns95C2629126824wisdomfolly@151.164.30.48> <cpvj4n0ihi@news4.newsguy.com> <Xns95C2B90A28A8Cwisdomfolly@151.164.30.42>
    >NNTP-Posting-Host: p-580.newsdawg.com
    >Mime-Version: 1.0
    >Content-Type: text/plain; charset=us-ascii
    >Content-Transfer-Encoding: 7Bit
    >User-Agent: KNode/0.8.0 Hamster-Pg/1.13
    >Xref: newsmst01a.news.prodigy.com comp.sys.ibm.pc.hardware.storage:343192
  18. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    >>> as powerful IMO.
    So tell me in what ways the disk manager will show a significant
    superiority.
    >>--John
    >>Path:
    >>From: "J. Clarke" <jclarke@nospam.invalid> Newsgroups:
    >>comp.sys.ibm.pc.hardware.storage Subject: Re: new hard drive + old hard
    >>drive Date: Sat, 18 Dec 2004 00:20:13 -0500
    >>Lines: 21
    >><Xns95C2B90A28A8Cwisdomfolly@151.164.30.42> NNTP-Posting-Host:
    >>p-580.newsdawg.com Mime-Version: 1.0 Content-Type: text/plain;
    >>charset=us-ascii Content-Transfer-Encoding: 7Bit User-Agent: KNode/0.8.0
    >>Hamster-Pg/1.13 Xref: newsmst01a.news.prodigy.com
    --John
Hard Drives Windows XP Storage
