IBM 75GXP weird performance - write cahce problem?
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hello all,
I noticed one type of operation where the performance
is very low, it occurs when reading and writing lots of data
simultaneously.
For example, I had a RAR archive of a 235MB avi file.
Extracting the archive from and to this drive took
1 minute 46.
I copied the RAR files to a second drive, a Maxtor 53073h4
and repeated the test, it took 60 seconds.
I used the IBM feature tool utility and disabled the
write cache. Repeating the test above in this
condition, it still took 1 minute 46.
Write cache non-operative?
Dave
3 answers Last reply
More about 75gxp weird performance write cahce problem
  1. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    "davexnet02" <davexnetzerotwo@hooya!.com> wrote in message news:v0vcr0debdd8cst84bsneoset51he1evd2@4ax.com
    > Hello all,
    > simultaneously.
    > 1 minute 46.
    2MB cache, 40MB/s transfer rate, or write cache filled in 1/40 second.
    Gee, on a 1 minute 46 sec operation how much difference do you think that
    will make?
    > Dave
  2. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    On Wed, 8 Dec 2004 21:27:58 +0100, "Folkert Rienstra"
    >> Hello all,
    >> simultaneously.
    >> 1 minute 46.
    >will make?
    Obviously I had no idea. If it really works as you describe,
    I can see not much at all.
    Since most HD accesses in a typical desktop scenario are pretty
    small reads and writes, then what's the point of the cache at all?
    However, if some of the problem is to do with timing, and the
    cache having an effect of smoothing out the operation,
    the benefit could be greater than the sum of the parts.
    OR so I thought.
    Dave
  3. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    "davexnet02" <davexnetzerotwo@hooya!.com> wrote in message news:q3gfr0trsb24lmb96sdmcm7ku6oguj3f4b@4ax.com
    > On Wed, 8 Dec 2004 21:27:58 +0100, "Folkert Rienstra" <see_reply-to@myweb.nl> wrote:
    > > > Hello all,
    > > > simultaneously.
    > > > Extracting the archive from and to this drive took 1 minute 46.
    > > will make?
    > If it really works as you describe, I can see not much at all.
    1. Being just that: cache.
    2. Being an extension to the buffer so that several commands can be queued.
    It probably does somewhat do that but it may be only noticable on pure
    sequential operations.
    And do note that the buffer is already 128 kB and may take more than one
    command of less than 128 kB transfer size.
    > OR so I thought.
    > Dave
Performance IBM Storage
