G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I've just had something bizarre happen to a 180GB WD disk which
Windows XP no longer thinks has a file system! This drive is composed
of a single NTFS partition (drive N and is about 50% full. Some of
that data is important to me.
Here's the sad tale. Yesterday I (re)formatted the drive using
PartitionMagic 8 set to 64K file clusters from 4K clusters - as
recommended by a PVR application (the drive is used primarily to store
video recordings). I restored my data to it from other drive locations
(unfortunately also erasing the duplicate data) and all appeared to be
fine. Today when I went to reboot the computer, shutdown appeared to
be stuck. This happens rarely but when it does I've had to resort to
pushing the reset button. When Windows started up, CHKDSK ran on
startup on Drive N: - it finished quickly and reported no errors.
However I can no longer access any data on N: Explorer says "N:\ is
not accessible. The file or directory is corrupted and unreadable."
Disk Management lists N: drive as having a healthy status and 100%
free and having NO FILE SYSTEM!
However, PartitionMagic 8 sees N: as having no problems whatsoever;
approx 50% of it is free, and it has an NTFS file system. Error
checking the drive with PM8 finds no errors. Neither does CHKDSK.
Could changing the cluster size to 64K have had something to do with
this? I'm reasonably sure the data is still intact but I have no way
to access it. Can someone recommend a utility that can fix this error
or recover my data? TIA!
