Archived from groups: microsoft.public.windowsxp.video (More info?)
What is wrong with my DVD drive or system? When I try to play a DVD through
PowerDVD it says "Internal Error." When I try in Windows Media Player it
says "Playing" But the timer doesn't start. And yesterday it said some
thing, "Your system is set to DVD region 1. Tp play the DVD, set your
system to region 1." When I try to play the movie in WinDVD, the picture
comes out, but really choppy, so is the sound. But when it gets to the main
menu, I can't select "Play Movie" or any other tabs. Whats wrong with my
DVD player? It used to work fine the last time I used it, which was about a
few months ago. Could someone try to help me? Thanks a lot.
"Ron R" <deltaforce3@earthlink.net> wrote in message
newsG7x8t%23cEHA.1644@tk2msftngp13.phx.gbl...
through
main
a
So mine are caused by a virus? Is that what you are trying to say? Well I
have the latest update of Norton AntiVirus and has no virus's detected. If
I do a reformat and re-install my XP, will the problem go away? Btw whats
XoftSpy?
"Advertiser" <advertiser@VideoClassified.com> wrote in message
news:zNwNc.47816$%t6.5641@roc.nntpserver.com...
> What say your antivirus and XoftSpy reports?
> Most of my video problems have disappeared after I cleaned my system.
> Regards, Aharon.
> VIDEO: http://www.videoclassified.com/pres1/ > E-Mail: advertiser@videoclassified.com
> Phone: 416-418-5127
> WEB: http://www.videoclassified.com/ >
> through
it
> main
my
about
> a
Hi there.
The reason why I've asked about BOTH antivirus AND XoftSpy is because
spyware and adware aren't considered by Norton Antivirus to be harmful and
aren't detected and consequently aren't removed. I've noticed significant
improvement in my video computer's performance after cleaning it up with
XoftSpy. There are many drawbacks, thought. I had to re-install quite a few
programs AND disconnect that computer from the Internet to keep it clean.
Formatting your HD will help until the moment you connect your computer to
the Internet. At the moment of connection you'll get same set of spyware and
adware bugs that you're likely to have now. XoftSpy cures your computer, but
doesn't protect it from repeated infection by the same spyware and adware.
After cleaning my computer I was getting same set of bugs on the first
re-boot even without me launching a WEB browser.
To find more information about XoftSpy just use Google. It is one of many
spyware protection programs and probably not the best. Another popular one
is called Spybot. Google on that one too.
news:%23rovtfAdEHA.3632@TK2MSFTNGP11.phx.gbl...
If
> XoftSpy?
> > Regards, Aharon.
> > VIDEO: http://www.videoclassified.com/pres1/ > > E-Mail: advertiser@videoclassified.com
> > Phone: 416-418-5127
> > WEB: http://www.videoclassified.com/ > >
> > through
> it
some
> picture
the
> > main
> my
> about
> > a
Hi there.
If
> XoftSpy?
> > Regards, Aharon.
> > Phone: 416-418-5127
> > through
> it
some
> picture
the
> > main
> my
> about
> > a
