Archived from groups: microsoft.public.windowsxp.video (More info?)
Monitor used to work with Medion hard drive, using Windows
XP Home. Moved downstairs; worked for a time, then
stopped. Now on power up, the monitor light turns green
for a few seconds, then clicks to yellow. No picture or
message, except a fleeting (less than 1/2 second) message
that no signal received. When I checked the monitor by
plugging it in to my laptop, it displays what's on my LCD
screen fine.
When I plugged in my laptop - before hitting the key which
toggles between displaying the external CRT, the laptop
LCD, or both - the monitor made the same noises (green
then yellow light, with accompanying clicks) as when only
the CRT is plugged in to the Medion desktop. Pressing
function-F8 toggled to display my laptop on the CRT. Is
there a keyboard command which is telling the monitor not
to display? Tried holding down F* at startup, to no avail.
My Dell Inspiron 1100 laptop doesn't have a video in port
(so far as I know), so I can't see if the desktop would
display on my LCD screen.
What would be the symptoms if the room was too humid/damp?
Any suggestions would be greatly appreciated.
Mark
screen fine.
Mark
