Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have a laptop with XP and a Linksys WPC11 ver 3 card. I can connect with
no problem when I have the WEP disabled (using windows to configure the
wireless network settings versus the linksys configuration utility), however,
I am having an icompatibility issue with the encryption level. Windows is
offering me a choice of 40 bits or 104 bits for my WEP setting instead of 64
bits or 128 bits. Here is the error message:
The network password needs to be 40bits or 104bits depending on your network
configuragtion. This can be entered as 5 or 13 ascii characters of 10 or 26
hexadeciamal characters.
I am admittedly new to XP, I have not had these issues with Win 2k. How do
I get XP to offer the 128bits (or 64bits for that matter) that my wireless
NIC offers?
Thank you in advance
40 is the same as 64
104 is the same as 128
(add 24 to 40 or 104)
1 ASCII Character=8 Bits
1 HEX Character=4 Bits
40 or 64 bit ASCII WEP code has 5 characters
40 or 64 bit HEX WEP code has 10 characters
104 or 128 bit ASCII WEP code has 13 characters
104 or 128 bit HEX WEP code has 26 characters
On Sun, 22 Aug 2004 18:21:01 -0700, "scott b"
>NIC offers?
Barb Bowman
Expert Zone Columnist
http://www.microsoft.com/windowsxp/expertzone
MS-MVP (Windows)
Barb,
I've seeen this data posted by your good self on various replies. Can you
explain why whatever one enters in the key field with WinXP SP1 or SP2,
whether 5, 10,13 or 26 characters, when you go back and check it afterwards
WIndows just shows 8 'blobs'. So.,.....is it actually taking notice of
what you're entering, is it corrupting it or.....?
I ask because I am using a Netgear WG121 USB adapter on my XP SP2 PC,
talking to a Draytek Vigor 2600G ADSL router. I use WEP 128 bit encryption.
When I use the Netgear smart Wizard utility, everything works fine. (and
it's quite obvious what format to enter the key in with the Netgear
utility). However, when I prevent the Netgear utility from starting up (by
removing it from my startup group), and I configure the 128 bit WEP key
using WZC instead, it never connects to the router. In fact, WIndows tells
me it doesnt even SEE the network. I've tried entering my 26 hex digits
many times - every time it doesn't connect, and I can only see 8 blobs when
I look at the properties for the connection. Start up the Netgear utility
again and all connects fine.
My conclusion - the WIndows support is not driving the network adapter
properly and/or not using the key I'm entering.
Why is the WIndows key support so awkward? Are there any known bugs in the
WEP key support - even with SP2 applied? I had hoped that with the changes
to wireless support in SP2 that I'd be able to use WZC instead of the
Netgear utility, but no....BTW, I;m using the very latest Netgear WG121
drivers and utility (V2.0 from their web site).
Rgds,
Mike
"Barb Bowman [MVP-Windows]" <barb@nospam.com> wrote in message
news:2ffji01pfnpqjtc84kmghhp8vqs6g3h2im@4ax.com...
>>with
>>however,
>>64
>>network
>>26
>>do
>>NIC offers?
> Barb Bowman
> MS-MVP (Windows)
As far as I know, the amount of "blobs" is not indicative of the WEP key
length and is used to hide the true length.
I have not used WEP for a while and not under SP2. Under SP1, there was
this problem with pasting WEP keys using formatted text (e.g. text copied
out of programs like Word) while unformatted text (e.g. text copied out of
Notepad) would work fine. Thus, the solution was to either type in the key
by hand or to copy and paste the key from Notepad. Keep in mind that when
entering non-hex keys, case does matter. Also, some routers use passphrases
to generate a WEP key. Unlike WPA-PSK, there is no standard for generating
a WEP key from a passphrase and this approach does not work with WZC. If
you use WEP, you need to enter the final key into WZC.
Finally, WZC usually does not work if you are both using encryption and are
not broadcasting the access point's SSID.
-Yves
"Mike Ball" <m.j.ball@xtrainame.xtracom> wrote in message
news:4130f40d$0$20246$cc9e4d1f@news-text.dial.pipex.com...
> Barb,
> you explain why whatever one enters in the key field with WinXP SP1 or
> SP2, whether 5, 10,13 or 26 characters, when you go back and check it
> afterwards WIndows just shows 8 'blobs'. So.,.....is it actually taking
> notice of what you're entering, is it corrupting it or.....?
> encryption. When I use the Netgear smart Wizard utility, everything works
> fine. (and it's quite obvious what format to enter the key in with the
> Netgear utility). However, when I prevent the Netgear utility from
> starting up (by removing it from my startup group), and I configure the
> 128 bit WEP key using WZC instead, it never connects to the router. In
> fact, WIndows tells me it doesnt even SEE the network. I've tried
> entering my 26 hex digits many times - every time it doesn't connect, and
> I can only see 8 blobs when I look at the properties for the connection.
> Start up the Netgear utility again and all connects fine.
> the WEP key support - even with SP2 applied? I had hoped that with the
> changes to wireless support in SP2 that I'd be able to use WZC instead of
> the Netgear utility, but no....BTW, I;m using the very latest Netgear
> WG121 drivers and utility (V2.0 from their web site).
> Rgds,
> Mike
>>>with
>>>however,
>>>is
>>>64
>>>network
>>>26
>>>do
>>>wireless
>>>NIC offers?
>> Barb Bowman
>> MS-MVP (Windows)
Well hiding the true length of the key from the person who has just entered
it seems pretty pointless to me and just makes problem determination more
uncertain - which given the variable nature of wireless connections is the
last thing one wants. None of the APs, routers or adapter utilities I've
used so far hide the length of the key - only the digits themselves. Then at
least you're pretty sure it's using what you've just typed in. And I've
seen nothing in the help, nor found any article on the Windows support site
so far which states that this is what it does, which just causes
uncertainty.
Take all your points about entering the key, and they've been well
communicated in the past - I only ever type my key in (26 hex digits) or
copy and paste from Notepad. Windows is not helping diagnose the problem by
'hiding' things from me.
The AP is broadcasting the SSID.
I'm beginning to suspect that maybe the Netgear WG121 driver may not be
fully compatible with WZC (whatever SP). After all, it's one of many
drivers for which at installation you get a message saying that it hasn't
gone through the Windows Logo scheme but continue anyway. Does make you
wonder how extensively its been tested with the several patches that have
been produced for XP Wireless over the last year or so.
Mike
"Yves Konigshofer" <ykoniREMOVEgshofer@hotmail.com> wrote in message
news:uZW252UjEHA.2524@TK2MSFTNGP11.phx.gbl...
> key by hand or to copy and paste the key from Notepad. Keep in mind that
> when entering non-hex keys, case does matter. Also, some routers use
> passphrases to generate a WEP key. Unlike WPA-PSK, there is no standard
> for generating a WEP key from a passphrase and this approach does not work
> with WZC. If you use WEP, you need to enter the final key into WZC.
> are not broadcasting the access point's SSID.
> -Yves
>> Barb,
>> Rgds,
>> Mike
>>>>with
>>>>however,
>>>>is
>>>>of 64
>>>>network
>>>>or 26
>>>>do
>>>>wireless
>>>>NIC offers?
>>> Barb Bowman
>>> MS-MVP (Windows)
In addition to the other replies, you might want to check out the new
wireless network wizard in XP SP2 and see the differences in entering
a WEP key or WPA passphrase. As for Netgear and signed drivers, you
should speak with Netgear's tech support.
On Sun, 29 Aug 2004 10:03:43 +0100, "Mike Ball"
>uncertainty.
>Mike
>> -Yves
>>> Barb,
>>> Rgds,
>>> Mike
>>>>>with
>>>>>however,
>>>>>is
>>>>>of 64
>>>>>network
>>>>>or 26
>>>>>do
>>>>>wireless
>>>>>NIC offers?
>>>> Barb Bowman
>>>> MS-MVP (Windows)
Barb Bowman
MS-MVP (Windows)
Barb,
I did try the new networking wizard already, tried entering the key using
it - same thing, no connection.
I'd rather stick pins in my eyes than contact Netgear tech support :-)
Mike
news:8nf3j0dikcj21pegskdbk08gh042botd5j@4ax.com...
>>entered
>>at
>>site
>>uncertainty.
>>by
>>Mike
>>> copied
>>> of
>>> that
>>> work
>>> -Yves
>>>> Barb,
>>>> taking
>>>> works
>>>> and
>>>> connection.
>>>> of
>>>> Rgds,
>>>> Mike
>>>>>>with
>>>>>>the
>>>>>>however,
>>>>>>Windows
>>>>>>is
>>>>>>of 64
>>>>>>network
>>>>>>or 26
>>>>>>How
>>>>>>do
>>>>>>wireless
>>>>>>NIC offers?
>>>>> Barb Bowman
>>>>> MS-MVP (Windows)
> Barb Bowman
> MS-MVP (Windows)
Have you unchecked 802.1x authentication?
On Sun, 29 Aug 2004 15:10:29 +0100, "Mike Ball"
>Barb,
>Mike
>>>entered
>>>at
>>>site
>>>uncertainty.
>>>by
>>>Mike
>>>> copied
>>>> of
>>>> that
>>>> work
>>>> -Yves
>>>>> Barb,
>>>>> taking
>>>>> works
>>>>> and
>>>>> connection.
>>>>> of
>>>>> Rgds,
>>>>> Mike
>>>>>>>with
>>>>>>>the
>>>>>>>however,
>>>>>>>Windows
>>>>>>>is
>>>>>>>of 64
>>>>>>>network
>>>>>>>or 26
>>>>>>>How
>>>>>>>do
>>>>>>>wireless
>>>>>>>NIC offers?
>>>>>> Barb Bowman
>>>>>> MS-MVP (Windows)
>> Barb Bowman
>> MS-MVP (Windows)
Barb Bowman
MS-MVP (Windows)
Absolutely.
It is unchecked.
Mike
news:rue4j0d0jm3qv0bm1blhdehf7cr1k09nus@4ax.com...
>>Barb,
>>Mike
>>>>entered
>>>>more
>>>>the
>>>>I've
>>>>Then
>>>>at
>>>>site
>>>>uncertainty.
>>>>problem
>>>>by
>>>>hasn't
>>>>have
>>>>Mike
>>>>> key
>>>>> was
>>>>> copied
>>>>> out
>>>>> of
>>>>> the
>>>>> that
>>>>> standard
>>>>> work
>>>>> and
>>>>> -Yves
>>>>>> Barb,
>>>>>> Can
>>>>>> or
>>>>>> taking
>>>>>> works
>>>>>> the
>>>>>> the
>>>>>> In
>>>>>> and
>>>>>> connection.
>>>>>> adapter
>>>>>> in
>>>>>> the
>>>>>> instead
>>>>>> of
>>>>>> Rgds,
>>>>>> Mike
>>>>>>>>connect
>>>>>>>>with
>>>>>>>>the
>>>>>>>>however,
>>>>>>>>Windows
>>>>>>>>is
>>>>>>>>instead
>>>>>>>>of 64
>>>>>>>>network
>>>>>>>>10
>>>>>>>>or 26
>>>>>>>>How
>>>>>>>>do
>>>>>>>>wireless
>>>>>>>>NIC offers?
>>>>>>> Barb Bowman
>>>>>>> MS-MVP (Windows)
>>> Barb Bowman
>>> MS-MVP (Windows)
> Barb Bowman
> MS-MVP (Windows)
If you have the latest Netgear drivers and are having this problem,
I'm afraid I have to send you to Netgear support. If it isn't WHQL'd,
as you say, ask them for WHQL's drivers.
On Mon, 30 Aug 2004 21:13:04 +0100, "Mike Ball"
>Absolutely.
>It is unchecked.
>Mike
>>>Barb,
>>>Mike
>>>>>entered
>>>>>more
>>>>>the
>>>>>I've
>>>>>Then
>>>>>at
>>>>>site
>>>>>uncertainty.
>>>>>problem
>>>>>by
>>>>>hasn't
>>>>>have
>>>>>Mike
>>>>>> key
>>>>>> was
>>>>>> copied
>>>>>> out
>>>>>> of
>>>>>> the
>>>>>> that
>>>>>> standard
>>>>>> work
>>>>>> and
>>>>>> -Yves
>>>>>>> Barb,
>>>>>>> Can
>>>>>>> or
>>>>>>> taking
>>>>>>> works
>>>>>>> the
>>>>>>> the
>>>>>>> In
>>>>>>> and
>>>>>>> connection.
>>>>>>> adapter
>>>>>>> in
>>>>>>> the
>>>>>>> instead
>>>>>>> of
>>>>>>> Rgds,
>>>>>>> Mike
>>>>>>>>>connect
>>>>>>>>>with
>>>>>>>>>the
>>>>>>>>>however,
>>>>>>>>>Windows
>>>>>>>>>is
>>>>>>>>>instead
>>>>>>>>>of 64
>>>>>>>>>network
>>>>>>>>>10
>>>>>>>>>or 26
>>>>>>>>>How
>>>>>>>>>do
>>>>>>>>>wireless
>>>>>>>>>NIC offers?
>>>>>>>> Barb Bowman
>>>>>>>> MS-MVP (Windows)
>>>> Barb Bowman
>>>> MS-MVP (Windows)
>> Barb Bowman
>> MS-MVP (Windows)
Barb Bowman
MS-MVP (Windows)
Thanks Barb.
Next plan is to check it with a different manufacturer's USB adapter instead
of the Netgear.
I have my doubts about Netgear in general (bad experience with a DG834G
router, now replaced by a Draytek)
Mike
news
gh8j0ht565rmjmjj4frapq7v5cve3m2mq@4ax.com...
>>Absolutely.
>>It is unchecked.
>>Mike
>>>>Barb,
>>>>using
>>>>Mike
>>>>>>entered
>>>>>>more
>>>>>>the
>>>>>>I've
>>>>>>Then
>>>>>>at
>>>>>>I've
>>>>>>site
>>>>>>uncertainty.
>>>>>>or
>>>>>>problem
>>>>>>by
>>>>>>be
>>>>>>hasn't
>>>>>>you
>>>>>>have
>>>>>>Mike
>>>>>>> key
>>>>>>> was
>>>>>>> copied
>>>>>>> out
>>>>>>> of
>>>>>>> the
>>>>>>> that
>>>>>>> use
>>>>>>> standard
>>>>>>> not
>>>>>>> work
>>>>>>> and
>>>>>>> -Yves
>>>>>>>> Barb,
>>>>>>>> Can
>>>>>>>> or
>>>>>>>> it
>>>>>>>> taking
>>>>>>>> PC,
>>>>>>>> works
>>>>>>>> the
>>>>>>>> from
>>>>>>>> the
>>>>>>>> In
>>>>>>>> connect,
>>>>>>>> and
>>>>>>>> connection.
>>>>>>>> adapter
>>>>>>>> bugs
>>>>>>>> in
>>>>>>>> the
>>>>>>>> instead
>>>>>>>> of
>>>>>>>> Netgear
>>>>>>>> Rgds,
>>>>>>>> Mike
>>>>>>>>>>connect
>>>>>>>>>>with
>>>>>>>>>>configure
>>>>>>>>>>the
>>>>>>>>>>utility),
>>>>>>>>>>however,
>>>>>>>>>>Windows
>>>>>>>>>>is
>>>>>>>>>>instead
>>>>>>>>>>of 64
>>>>>>>>>>your
>>>>>>>>>>network
>>>>>>>>>>of
>>>>>>>>>>10
>>>>>>>>>>or 26
>>>>>>>>>>2k.
>>>>>>>>>>How
>>>>>>>>>>do
>>>>>>>>>>wireless
>>>>>>>>>>NIC offers?
>>>>>>>>> Barb Bowman
>>>>>>>>> MS-MVP (Windows)
>>>>> Barb Bowman
>>>>> MS-MVP (Windows)
>>> Barb Bowman
>>> MS-MVP (Windows)
> Barb Bowman
> MS-MVP (Windows)
There are 567 identified and unidentified users. To see the list of identified users, Click here.
