Archived from groups: comp.sys.ibm.pc.hardware.storage (
More info?)
Previously terrancedrith@yahoo.com wrote:
> I'm finally building myself a newer PC and am confused about whether or
> not my 80gig WD 7200rpm S-ATA drive needs its own dedicated cooling.
> According to WD's site, not really. According to sites devoted to
> gaming PCs, yes.
Depends. If it has its own airstream from the outside, it will be
o.k. in most cases. If not, it depends on usage pattern, mounting
method, air-temperature, airflow in the case, etc.. You cannot cool a
HDD too much. But you can cool it too little, severely shortening its
life and many people do so without knowing or understanding the
problem.
> The case already has one intake fan, one exhaust fan, and a twin-fan
> power supply. It IS an older case, though, so there is no provision for
> mounting the drive directly in the airflow of the intake fan (like I
> see on most other cases).
The problem with that is that air from the outside is cool. Air alrerady
inside the case may not be.
> I'd _like_ to stay away from yet more fans. A lot of the "hard drive
> coolers" I see look like they just churn a bunch of already hot air.
> Others seem to be large heatsink/fan combinations that pull in air from
> the front bezel, but again it's more noise.
> Thoughts? Opinions? Will the drive live a shorter life if I just mount
> it in the 3-1/2 bay below the floppy?
Depends. Single drives firmly screwed into metal bays can be
surprisingly well cooled. The only good way to tell is to
measure:
- Run the drive at your expected maximum load. Personally I found
that modern drives don't take much more energy during seek than
during mixed r/w operation, so you can just copy a large number
of files around. Do this for at leat 10 minutes, better half an
hour.
- Measure temperature with a SMART utility (e.g. the smartmontools).
- Measure your room temperature and add the difference between current
temperature and maximum expected tempereature you want to run the
computer in to the measured HDD temperature.
If the result is over 55C you should definitely get better cooling.
Mosts HDDs will start to have significantly shorter lifes when run
over 55C...60C.
If you find this procedure is too complicated, the just get reasonable
airflow from the outside to your drive. Since most people are not
willing or able to do reasonable measurements, the general recomendation
is more cooling than strictly necessary.
Arno
For email address: lastname AT tik DOT ee DOT ethz DOT ch
GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
"The more corrupt the state, the more numerous the laws" - Tacitus
