Sudden power loss causes damage?
- Hardware
- Hard Drives
- Power
Storage
Last response: in Storage
Anonymous
a
b
G
Storage
February 2, 2005 1:21:51 PM
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Are modern hard disk drives susceptible to hardware damage or data
corruption from sudden power loss?
By "sudden power loss", I mean like if you pull the power supply plug
out off the wall socket, or if the hard disk drive power cable is
disconnected.
Partly curious. Thank you.
disconnected.
More about : sudden power loss damage
Anonymous
a
b
G
Storage
February 2, 2005 2:17:32 PM
If the drive is writing, the current sector will be bad. Documented in many
drive manuals, and also the servo chipset docs.
The drive will always retract the heads to landing zone or offload ramp.
"John Doe" <jdoe@usenet.is.the.real.thing.com> wrote in message
news:Xns95F12C69A29D1wisdomfolly@151.164.30.42...
> disconnected.
> disconnected.
Anonymous
a
b
G
Storage
February 2, 2005 6:57:01 PM
Modern journalling file system are sufficiently robust against power loss,
but any unwritten DATA may be lost, causing corruption in the user's files
structure.
Don't take chances and buy an UPS.
> disconnected.
structure.
> disconnected.
- System Damage from Power Loss? - Forum
- Sudden power loss during gaming - Forum
- Sudden power loss with SSD, system now sluggish. - Forum
- AMD system sudden loss of power - Forum
- Sudden power loss and instant recovery - Forum
Anonymous
a
b
G
Storage
February 2, 2005 11:25:01 PM
> disconnected.
There was a time where certain drives suffered bad sectors when
this happens. The problem should be solved now.
Writing a sector takes something like 10-20 us. The drive buffer
capacitor should have enough power to keep the electronics working
that long. The disk will detect the power-fail a bit before
it has problems with the voltage levels.
If you short out the power leads, it may be a different story.
Arno
For email address: lastname AT tik DOT ee DOT ethz DOT ch
GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
"The more corrupt the state, the more numerous the laws" - Tacitus
> disconnected.
Arno
Anonymous
a
b
G
Storage
February 2, 2005 11:25:02 PM
"Arno Wagner" <me@privacy.net> wrote in message
news:36cr8tF4qap71U7@individual.net...
Delusional nonsense. Ronnie also claimed that. Manuals say otherwise.
There is a chipset doc online that says low voltage simply disables the write
head.
head.
cjt
February 3, 2005 1:59:22 AM
> structure.
I think that's expressed poorly, because I can interpret it to be either
true or a mis-statement. Vague terms include "unwritten" and "user's
file structure."
A Google of "two phase commitment" might be relevant.
>>disconnected.
The e-mail address in our reply-to line is reversed in an attempt to
minimize spam. Our true address is of the form che...@prodigy.net.
> structure.
file structure."
>>disconnected.
Anonymous
a
b
G
Storage
February 3, 2005 6:19:54 AM
>> working that long. The disk will detect the power-fail a bit
>> before it has problems with the voltage levels.
>otherwise.
>the write head.
Instead of a troll, why don't you post a link to that chipset dock.
>Path: newssvr30.news.prodigy.com!newsdbm05.news.prodigy.com!newsdst02.news.prodigy.com!newsmst01a.news.prodigy.com!prodigy.com!newscon06.news.prodigy.com!prodigy.net!newshub.sdsu.edu!logbridge.uoregon.edu!pln-w!spln!dex!extra.newsguy.com!newsp.newsguy.com!enews3
>From: "Eric Gisin" <ericgisin@hotmail.com>
>From: "Eric Gisin" <ericgisin @hotmail.com>
>Newsgroups: comp.sys.ibm.pc.hardware.storage
>Subject: Re: Sudden power loss causes damage?
>Date: Wed, 2 Feb 2005 14:34:04 -0800
>Organization: http://extra.newsguy.com
>Lines: 13
>Message-ID: <ctrkhk01sia@enews3.newsguy.com>
>Message-ID: <ctrkhk01sia @enews3.newsguy.com>
>References: <Xns95F12C69A29D1wisdomfolly@151.164.30.42> <36cr8tF4qap71U7@individual.net>
>NNTP-Posting-Host: p-247.newsdawg.com
>Mime-Version: 1.0
>Content-Type: text/plain; charset="Windows-1252"
>Content-Transfer-Encoding: 7bit
>X-Priority: 3
>X-MSMail-Priority: Normal
>X-Newsreader: Microsoft Outlook Express 6.00.2800.1106
>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
>Xref: newsmst01a.news.prodigy.com comp.sys.ibm.pc.hardware.storage:345379
>otherwise.
>the write head.
>Lines: 13
>Mime-Version: 1.0
>X-Priority: 3
Anonymous
a
b
G
Storage
February 3, 2005 6:19:55 AM
news:Xns95F1D90494E53wisdomfolly@151.164.30.42...
> >otherwise.
> >the write head.
The title is Texas Instruments Servo/MSC Product Line User's Guide (PDF).
This is over 5 years old, so things may have changed.
You are better of reading hard drive manuals. IBM's describe the "at most one
bad sector" behavior.
Arnie's "drive buffer capacitor" is a fabrication. You cannot store enough
energy on those dinky caps.
> >otherwise.
> >the write head.
Anonymous
a
b
G
Storage
February 3, 2005 8:22:46 AM
After 10 us, 100 uF, 1A, the voltage drops by 100 mV. 100 uF is not a
terribly big capacitor.
"Eric Gisin" <ericgisin@hotmail.com> wrote in message
news:ctsasd0sd4@enews1.newsguy.com...
>> >otherwise.
>> >the write head.
> one
>> >otherwise.
>> >the write head.
> one
Anonymous
a
b
G
Storage
February 3, 2005 9:52:19 AM
John Doe <jdoe@usenet.is.the.real.thing.com> wrote in
message news:Xns95F12C69A29D1wisdomfolly@151.164.30.42...
> damage or data corruption from sudden power loss?
Nope, they should all handle that with no data loss or damage.
> disconnected.
You know what that did to the cat dont you ?
> disconnected.
Anonymous
a
b
G
Storage
February 3, 2005 1:06:30 PM
Then you and Arnie can show us the picture of a HD controller with that
capacitor, right?
I have never seen an electolytic cap on a HD. They cost money, so you would
never see it on IDE.
"Alexander Grigoriev" <alegr@earthlink.net> wrote in message
news:GyiMd.5208$cl1.1273@newsread3.news.pas.earthlink.net...
capacitor, right?
Anonymous
a
b
G
Storage
February 3, 2005 3:27:09 PM
Also you just need to power the write amplifier and circuit
by it, so 1A is probably on the high side.
Personally I find it funny that people who don't know about buffer
capacitors presume to talk about how electronics work. It is one of
the most fundamental things you need to have to get digital
electronics to work right. (In analog electronics they more serve
as filters than as power storage, depending on the circuit
functionality.) I guess these people also never heard of
wire impedances...
Arno
wire impedances...
Arno
Anonymous
a
b
G
Storage
February 3, 2005 3:27:10 PM
news:36ejktF4qcgs3U1@individual.net...
> wire impedances...
Nobody uses the term "buffer capacitor".
I have a drive with two filter caps marked 6u8. 6.8uF is not going do anthing.
Besides, you also need a blocking diode. Never seen one of those either.
> wire impedances...
Anonymous
a
b
G
Storage
February 3, 2005 10:07:20 PM
Well, well, well, someone calling himself "John Doe", calling people troll,
is trying to redo a subject that last time this was discussed resulted
in a thread with a massive 180 posts.
"John Doe" <jdoe@usenet.is.the.real.thing.com> wrote in message news:Xns95F12C69A29D1wisdomfolly@151.164.30.42
> disconnected.
> disconnected.
Anonymous
a
b
G
Storage
February 4, 2005 3:32:40 AM
Off-topic troll.
"Folkert Rienstra" <see_reply-to@myweb.nl> wrote:
>Path: newssvr12.news.prodigy.com!newsdbm05.news.prodigy.com!newsdst02.news.prodigy.com!newsmst01a.news.prodigy.com!prodigy.com!newscon06.news.prodigy.com!prodigy.net!fu-berlin.de!uni-berlin.de!individual.net!not-for-mail
>From: "Folkert Rienstra" <see_reply-to@myweb.nl>
>From: "Folkert Rienstra" <see_reply-to @myweb.nl>
>Date: Thu, 3 Feb 2005 19:07:20 +0100
>Lines: 16
>Message-ID: <36f7lcF520d9vU2@individual.net>
>Message-ID: <36f7lcF520d9vU2 @individual.net>
>Reply-To: "Folkert Rienstra" <folkertdotrienstra@freeler.nl>
>Mime-Version: 1.0
>X-Trace: individual.net +vIPJhPb59PKhXV4aHwIKwNlunFGGRsamHYzJt2DiFms0yVRM=
>X-Priority: 3
>X-Newsreader: Microsoft Outlook Express 6.00.2800.1437
>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1441
>Xref: newsmst01a.news.prodigy.com comp.sys.ibm.pc.hardware.storage:345433
Off-topic troll.
>Lines: 16
>Mime-Version: 1.0
>X-Priority: 3
Anonymous
a
b
G
Storage
February 4, 2005 3:32:41 AM
No, you are the troll. Pretty evident from you fake name and address.
news:Xns95F2BCAAA3B5wisdomfolly@151.164.30.44...
> Off-topic troll.
> Off-topic troll.
Anonymous
a
b
G
Storage
February 4, 2005 3:48:28 AM
"Arno Wagner" <me@privacy.net> wrote in message news:36ejktF4qcgs3U1@individual.net
Yeah, no need to keep the heads tracking, obviously.
Who cares where that write goes, right Arnie?
Yes Arnie, that is so funny, especially coming from you.
> It is one of the most fundamental things you need to have to get digital
> (In analog electronics they more serve as filters than as power storage,
> depending on the circuit functionality.)
Gosh, makes one wonder where Power Amps get their power from and
how they can work with AC signals using asymetric power sourcing.
> I guess these people also never heard of wire impedances...
And then Arnie went from a rush into a delirium ....
> Arno
> Arno
Anonymous
a
b
G
Storage
February 4, 2005 2:16:08 PM
This is correct. There are comparators on the +5 and +12V supply lines.
As soon as one detects an out of limits supply, the write gate is
turned off, for fear that the head may go offtrack and eat into a
neighboring track since the actuator voice coil needs quite a bit of
current (several amps peak - no way you can buffer that with a
capacitor a disk drive manufacturer can afford.) Hence the currently
written sector is incomplete and will result in a read error. It isn't
bad per se, you can overwrite it and it will be fine.
The emergency retract (to the landing zone or load ramp) is powered by
the rotating disk stack, through windage or the motor's back EMF,
sometimes assisted by a spring or a magnet.
Ralf-Peter
Ralf-Peter
Anonymous
a
b
G
Storage
February 4, 2005 3:14:00 PM
I did google for some modern disk controller chips. The best I found is:
http://www.st.com/stonline/prodpres/dedicate/datastor/d...
I didn't find detailed info for the system-on-chip disk controllers. Their koi
servo controller does have a data sheet:
http://www.st.com/stonline/prodpres/dedicate/datastor/p...
"RPR" <rohbeck@yahoo.com> wrote in message
news:1107544568.508350.273780@o13g2000cwo.googlegroups.com...
> Ralf-Peter
> Ralf-Peter
Anonymous
a
b
G
Storage
February 4, 2005 3:54:29 PM
"John Doe" <jdoe@usenet.is.the.real.thing.com> wrote in message news:Xns95F2BCAAA3B5wisdomfolly@151.164.30.44
> Off-topic troll.
Says he who posts message headers containing email addresses left
right and center all over the internet for the spammers to see..
> > Path:
> > Lines: 16
> > Mime-Version: 1.0
> > X-Priority: 3
> Off-topic troll.
> > Path:
> > Lines: 16
> > Mime-Version: 1.0
> > X-Priority: 3
- ATX Power cable movement causes loss of power? Forum
- Sudden loss of power to monitor Forum
- Problems after sudden power loss Forum
- Sudden Power Loss Forum
- SolvedCould a power supply blow out cause damage to other components? Forum
- Sudden Power loss issue Forum
- XP sudden power loss Forum
- SolvedCan Power Loss to Hard Drive Cause Mechanical Problems? Forum
- SolvedSudden loss of all sound. Forum
- SolvedWin7 64bit, Wordpad/Paint/Microsoft Office causes computer to freeze. At a loss.... Forum
- PC worked, then loss of picture, power to keyboard/mouse suddenly. Forum
- SolvedSudden Network Speed Loss = Bad Router? Forum
- Can a overheated powersupply cause loss of power? Forum
- SolvedSudden Loss of Spare Internal Drive Access in Windows XP Forum
- Sudden FPS Drops in Games---->At a serious loss D: Forum
- More resources
Read discussions in other Storage categories
