Tom's Hardware > Forum > Windows XP > Video > nv4_disp.dll problems and DirectX problems
Forum Windows XP : Video - nv4_disp.dll problems and DirectX problems
Archived from groups: microsoft.public.windowsxp.video (More info?)
I think I am losing what little sanity that I have left. I am having a couple
of problems and they seem to be linked. Let's see if I can explain this so
that it makes sense. I downloaded directx 9.oc last week don't know where it
went because when I try to run "dxdiag" it says that I have vers 8.1 then
everything crashes and all that I can do is push the reset button. Then when
everything comes back I get an error message about the nv4_disp.dll here is
what the log files says about this error:
Server=watson.microsoft.com
UI LCID=1033
Flags=622898
Brand=WINDOWS
TitleName=Microsoft Windows
DigPidRegPath=HKLM\Software\Microsoft\Windows
NT\CurrentVersion\DigitalProductId
ErrorText=The driver for the display device was unable to complete a drawing
operation. Please check with the device manufacturer for a driver update.
HeaderText=Computer restarted after an unexpected shutdown. Microsoft
Windows detected a possible device failure.
Plea=The display driver for NVIDIA Vanta/Vanta LT (Microsoft Corporation)
seems to be responsible for the system instability.
Stage1URL=
Stage1URL=/StageOne/Drivers_Display/10DE002C1500000000/nv4_disp_dll/6_13_10_2958/EA8706EA.htm
Stage2URL=
Stage2URL=/dw/StageTwo.asp?szAppName=Drivers.Display&szAppVer=10DE002C1500000000&szModName=nv4_disp.dll&szModVer=6.13.10.2958&Offset=EA8706EA
DataFiles=C:\WINDOWS\LogFiles\Watchdog\040819_1407_01.wdl
ErrorSubPath=\Drivers.Display\10DE002C1500000000\nv4_disp.dll\6.13.10.2958\EA8706EA
I understand that this is telling me that something is wrong with the Nvidia
driver, but it doesn't explain what is going on with DirectX.
Sponsored Links
Just a WAG, but reset your monitor refresh rate to
something a couple of steps BELOW what you have now. I
was at 85 Hz and had all kinds of wrrors on two cards I
know to be good. So far, when set to 72 Hz, I have no
problems with either.
Of course, not everybody can us a lower refresh rate
effectively, but this might help diagnose your problem.
David
>-----Original Message-----
can explain this so
don't know where it
have vers 8.1 then
>UI LCID=1033
>Flags=622898
>Brand=WINDOWS
a driver update.
shutdown. Microsoft
>Stage1URL=
>Stage2URL=
DirectX.
Reply to Anonymous
A standard refresh rate is 65Hz (which is what Safe Mode uses) so I don't
know anyone who cannot use it. Of course they may not like the horrible
'flickering' but the solution in that case is to get a better CRT.
Cari (MS-MVP Printing, Imaging & Hardware)
www.coribright.com
<anonymous@discussions.microsoft.com> wrote in message
news:044801c48dd2$2622f410$a401280a@phx.gbl...
> David
Reply to Anonymous
- 0 +
I was working just fine ever since installing the NIDIA GEFORCE FX 5500 on my XP system a year ago. In-fact all worked perfectly until yesterday when I made a boneheaded decision to answer yes to installing Internet Explorer 8.0. So after running IE8.0 for awhile and noticing that my video subsystem was running very slow, I uninstalled IE8.0. Then whenever I run any Java, even stuff that has worked perfectly for a year, I get flickering displays, locked computer (5-10 seconds) and Blue screen Stop errors for NV4_DISP. So, I am convinced that there is something in the IE 8.0 update and uninstall that changed my system.
Reply to stuartm
There are 1227 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 EChiasson won the Freshman badge
  • 01:00 Foxer57 won the Uniformed badge
  • 01:00 gregmo won the Freshman badge
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
