G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hello, I have got an Asus A7V333 raid motherboard with a stripe array
of 2x60Gb Maxtor discs on the integrated Promise controller.
I need to change this motherboard: is there a way to do the job without
having to recreate the array? I can not loose any data from the array...
If I should buy a new motherboard equipped with a promise controller,
will my discs be recognized as an array? Or I'll loose all my data?
Thank you very much for the attention and sorry for my bad English.
Greetings.
Carlo.
Greetings.
Carlo.
