Tom's Hardware > Forum > Storage > General Storage > help: hard drive lost ntfs partition
Forum Storage : General Storage - help: hard drive lost ntfs partition
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I am having trouble with 120 GB NTFS drive in an external enclosure
(hybrid usb2/firewire), used with Windows XP.
Yesterday Windows popped up with an error like "could not write to
drive, bad block found". I tried to open the drive in My Computer and
although the drive letter was listed, the volume name was gone and I
could no longer browse the drive.
If you look at the Computer Management screenshot:
http://www.geocities.com/usenet_daughter/hdd1.jpg
drive F is the drive and is listed as Healthy, but no file system or
volume name is present. This should be an NTFS partition.
Any help recovering this volume would be most appreciated.
Thanks
PS I would prefer to use Svend's findpart utility:
http://www.partitionsupport.com/utilities.htm
which has worked like a charm in the past (with the author's help). I
am more comfortable using this than a commercial product like Norton
Diskdoctor. However I haven't been able to reach him - if anyone else
knows how to use Findpart to recover an NTFS partition, any help would
be appreciated.
Sponsored Links
In article <39jjp4F61f95cU1@individual.net>,
Rod Speed <rod_speed@yahoo.com> wrote:
>"Al Dykes" <adykes@panix.com> wrote in message
>news:d11u9q$a7d$1@panix5.panix.com...
>> In article <1110733926.724474.164100@f14g2000cwb.googlegroups.com>,
>>>Thanks
>>>be appreciated.
>> We need to know a little more about this guys problem before we can
>> make conculsion, maybe his disk died. but I've been watching usenet
>> groups for NTFS issues for about a year paying attention to people
>> reporting NTFS "failure" and my thoroughly unscientific poll shows
>> that a huge number of the people that have had these problems are
>> using external USB boxes. This guy's story is typical.
>> I (and many other sysadmins) have been using NTFS from the day it was
>> available. In my case for many thousands of systems. 99% of these are
>> IDE and the rest SCSI. Except for hardware failure it's 100%
>> reliable, IME.
>> I could conjecture that backpack problems
>> could be explained by one of these reasons:
>> - Problems with LBA48 issues and big disks.
>Nope, the drive isnt big enough to see those.
>> - Heat killing the disk. (not a USB problem, but
>> related to the cheapo case design and full time use.)
>Possible.
>> - Power fulction/problems caused by
>> the enclosure's wall wart being sub-par
>Possible but not that likely, it aint rocket science at that power level.
>> or subject to VAC fulctuation that the PC power supply deals with,
>Ditto.
>> or common mode ground problems.
>Very unlikely indeed. Its a digital system.
"digital" is really a very carefull analog simulation. It works great
until it stops. Look at digital signals with a o'scope for an example.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Reply to Anonymous
news:d12rii$6iv$1@panix5.panix.com...
>>>>Thanks
>>>>be appreciated.
>>> reliable, IME.
>>Possible.
>>Ditto.
Nope.
> It works great until it stops.
It doesnt stop due to common mode ground problems.
You can make the same silly claim about say the PCI bus signals.
Reply to Anonymous
In article <1110748935.670766.280990@g14g2000cwa.googlegroups.com>, Mad
Scientist Jr <usenet_daughter@yahoo.com> writes
>The enclosure is by Bytecc:
>http://www.newegg.com/app/ViewProductDesc.asp?description=17-145-316&depa=0
And what's the chipset in it?
Rarely do people communicate; they just take turns talking.
(source unknown)
Reply to Anonymous
It's listed as:
Prolific PL3507 Combo Device (1394 ATAPI_Rev 1.00) IEEE 1394 SBP2
Device
The driver is listed as Microsoft.
http://www.geocities.com/usenet_da [...] hipset.jpg
http://www.geocities.com/usenet_da [...] etails.jpg
Reply to Anonymous
Other than turning it on for a minute to get the chipset/driver I have
not touched the drive since the crash. Do any of you know how to use
the FindNTFS or similar utility to recover the partition? NTFS stores
backups of partition tables, right? I don't trust Norton to fix this.
Reply to Anonymous
In article <1110807236.205040.43510@f14g2000cwb.googlegroups.com>, Mad
>It's listed as:
>Device
Thanks. You may find this thread of interest:
<http://groups.google.co.uk/groups?hl=en&lr=&threadm=t7GTprA%2B3vLCFw87%
40jasper.org.uk&rnum=1&prev=/groups%3Fq%3Duk.comp.homebuilt%2BMike%2BTom
linson%2BProlific%26hl%3Den%26lr%3D%26selm%3Dt7GTprA%252B3vLCFw87%2540ja
sper.org.uk%26rnum%3D1>
http://snipurl.com/deuz
(source unknown)
Reply to Anonymous
I appreciate the discussion, but what would you recommend? I have used
a similar enclosure (same silver plastic case, same fan, but it had an
oxford chipset, and noname, where this is a bytecc) and another large
WD drive for almost 3 years daily with no problems. Also I was on the
net when it happened - could it have been from a malicious attack? In
any case all I want is to recover the data and avoid this happening
again (including making more frequent backups). Are there any external
hybrid enclosures you would recommend? I am running findpart.exe all,
we will see if Svend replies or if I can figure out where to take it
from there.
> >>> In article
enclosure
to
and
and I
or
> >>>>Thanks
help). I
Norton
else
would
> >>>>be appreciated.
can
usenet
people
shows
was
are
> >>> reliable, IME.
> >>Possible.
level.
with,
> >>Ditto.
> Nope.
Reply to Anonymous
Wow, it seems the PL3507 could be the culprit...
http://www.hardwareanalysis.com/content/topic/31408/
and many more pages tell of similar problems.
Now if only I can recover the data.
Then I'll just go back to using the Oxford chipset.
Mad
> >It's listed as:
> >Device
> (source unknown)
Reply to Anonymous
You have to upgrade the firmware:
http://forums.storagereview.net/in [...] 5437&st=25
"Mad Scientist Jr" <usenet_daughter@yahoo.com> wrote in message
news:1110807236.205040.43510@f14g2000cwb.googlegroups.com...
> It's listed as:
> Device
Reply to Anonymous
many thanks... this should save me the trouble and $ of having to buy
oxford enclosures.
anyone out there who can help with findpart and recovering the
partition? svend olaf? are you out there?
i think i have gone as far as i can on my own
many thanks in advance
Reply to Anonymous
The official drivers page is at Prolific internet support center
http://tech.prolific.com.tw/visito [...] result.asp
also one person put up some drivers at
http://member.newsguy.com/~siccos/ [...] rmware.htm
One question - how do I know if I have chip version A, B or C? The
device is listed on my system as:
Reply to Anonymous
Mad Scientist Jr <usenet_daughter@yahoo.com> wrote in message
news:1110807978.591675.155250@z14g2000cwz.googlegroups.com...
I've only used Easy Recovery Pro in that situation. It works fine, but isnt
free.
Reply to Anonymous
news:1110809897.113470.80030@g14g2000cwa.googlegroups.com...
I havent seen enough failures over years to be able to recommend
any specific enclosure, and the use varys too, some only have it
turned on while doing a backup to it, others use it like a regular drive.
It isnt even that easy to monitor the drive
temp using SMART in an external drive.
> I have used a similar enclosure (same silver plastic case, same fan,
> but it had an oxford chipset, and noname, where this is a bytecc)
> and another large WD drive for almost 3 years daily with no problems.
Yeah, plenty do use them without problems.
> Also I was on the net when it happened -
Not very likely. And I use a full hardware firewall, so that cant happen.
> In any case all I want is to recover the data and avoid this
> happening again (including making more frequent backups). Are
> there any external hybrid enclosures you would recommend?
See above.
> I am running findpart.exe all, we will see if Svend replies
> or if I can figure out where to take it from there.
>> >>> In article
> enclosure
> to
> and
> and I
> or
>> >>>>Thanks
> help). I
> Norton
> else
> would
>> >>>>be appreciated.
> can
> usenet
> people
> shows
> was
> are
>> >>> reliable, IME.
>> >>Possible.
> level.
> with,
>> >>Ditto.
>> Nope.
Reply to Anonymous
Easy Recovery Pro... will look into it. I read up on various posters'
comments and it seems the prolific PL3507 chipset in my enclosure needs
firmeware update.. but there are two variants, one for chipset vrsn A
and one for chipset version B & C. I would *guess* my enclosures (i
have two, this is the first time I have had a problem) are the latter
versions since these were purchased in the past 6 mos, but that's no
guarantee, they could have sat in a warehouse for 2 yrs. Does anyone
know how to tell which version chipset you have?
Reply to Anonymous
NTFS doesn't store a backup of the partition table (actually the MBR and
extended partition *sectors*) but it's relatively simple to rebuild the table
from scratch if you know how to assess the partitions geometry. There are
several tools for the purpose, most of them are free (including RESQ, for this
purpose).
NTFS stores a backup of the boot sector, though, as the last sector of the
partition, respectively.
Regards
NetZ Computing Ltd. ISRAEL www.invircible.com www.ivi.co.il (Hebrew)
InVircible Virus Defense Solutions, ResQ and Data Recovery Utilities
Reply to Anonymous
Would TestDisk (http://www.cgsecurity.org) rebuild the partition table?
The problem I am having with FindNTFS is I have it output a list of
folders and files, but it is incomplete. For instance, "findpart all"
listed cylinder/head/sector 0, 1, 7, so I did
findntfs 5 0 1 7 file5017.txt files
which created a file that lists certain folders/files:
2005-02-27 23:50:58 <DIR> 10000000 myfolder1
2005-02-28 14:02:31 <DIR> 10000000 myfolder2
2005-03-07 23:50:18 <DIR> 10000000 myfolder3
2005-02-28 11:45:30 <DIR> 10000000 myfolder4
2005-02-28 12:44:19 <DIR> 10000000 myfolder5
2005-03-02 22:46:43 <DIR> 10000000 myfolder6
2005-02-28 13:37:47 <DIR> 10000000 myfolder7
2005-03-07 23:41:44 <DIR> 10000000 myfolder8
97691 mydata\myfolder1\
2004-11-22 20:47:50 8368128 00000020 file1.doc
2004-11-22 20:47:50 8368128 00000020 file2.doc
2004-11-22 20:48:22 8368128 00000020 file3.avi
2004-11-22 20:48:22 8368128 00000020 file4.doc
97685 mydata\myfolder2\
2004-12-05 00:41:09 28344 00000020 file5.doc
2002-11-10 11:14:44 14483456 00000020 file6.doc
2002-11-10 11:14:44 14483456 00000020 file7.doc
2002-11-10 11:14:44 14483456 00000020 file8.doc
2002-11-10 11:14:44 14483456 00000020 file9.doc
97680 mydata\myfolder7\
2004-11-22 19:55:37 8687616 00000020 file10.avi
2004-11-22 19:55:37 8687616 00000020 file11.wav
2004-11-22 19:55:59 8687616 00000020 file12.wav
2004-11-22 19:55:59 8687616 00000020 file13.wav
etc.
But while myfolder4, myfolder5 and myfolder6 appear in the list above,
they do not appear below broken out with files. And if I try generating
a dir list with
findntfs 5 0 1 7 dirs5017.txt dirs
those folders don't appear at all.
I tried searching sector 1 instead
findntfs 5 0 1 1 file5011.txt files
findntfs 5 0 1 1 dirs 5011.txt dirs
and the output files are about 1/2 the size of the sector 7 ones, and
are also missing the folders.
Also, when I try to do findpart copy, for some of the folders it
doesn't restore all the files, and for some it restores none,
outputting "no info":
Searching ... .
------Date ----Time -------Size ---Flags Name
61732 mydata\myfolder9\
2005-02-19 09:09:22 2498604 00000020 myfile14.wav No info
2005-02-19 09:11:30 2762796 00000020 myfile15.wav No info
2005-02-19 09:13:58 3203116 00000020 myfile16.avi No info
2005-02-19 09:19:00 2555948 00000020 myfile17.wav No info
2005-03-01 00:37:38 1552428 00000020 myfile18.aif No info
2005-03-03 15:01:52 1651756 00000020 myfile19.wav No info
Directories: 7650
Files: 134380
Trees: 25
Exe/dll files: 1963
Exe/dll files signature: 1952
Copied files: 0
Cluster KB: 4
MFT record used: None
Listed files MB: 102530
So it seems the folders I am trying to recover only exist in the files
list of sector 7. They are listed, so hopefully I am using findntfs
wrong or another tool can recover them. Maybe there is more information
stored elsewhere that can locate the particular directories.
Any more detailed help appreciated.
and
the table
There are
for this
> purpose).
Reply to Anonymous
I suggest you use partition table doctor.It provides very useful
functions: Backup partition table, Restore partition table, Rebuild
partition table, undelete partition,Fixboot.
see more:http://www.ptdd.com/recoverylostpartition.htm
Reply to Anonymous
Thanks to everyone who replied or made suggestions, I ended up
recovering my data using EasyRecovery Professional (www.ontrack.com)
Reply to Anonymous
There are 1129 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
