G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I was working on a system recently that was very unstable
and finally noticed that the IDE cables on both the hard
disk and the CDROM were connected at the middle connector
instead of at the end (only one hard disk and CDROM in the
system). When I plugged the end of the IDE cables into the
drives the computer immediately booted normally and ran
stable. I didn't think it mattered with IDE drives which
cable connector you used, but apparently it does. Is this a
termination issue and is it consistant?
