Best way to partition 300gb System Drive?
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hello all,
I'm making the jump from a 120gb IDE drive to TWO 300gb SATA drives
(Maxtor 6B300S0 drives). I'm doing away with the IDE drives all
together, and going purely SATA.
My question is.. what is the suggested partitioning scheme when using
such a large drive as the system drive? With 80gb and 120gb drives
I've used in the past, I've simply used one big NTFS partition. But
with these 300gb drives, I imagine that isn't suggested.. and may
hinder performance when using a system partition that big.
So my question would be in two parts I guess...
1. What is the suggested way to partition the system drive?
2. For the second 300gb drive, I'm going to purely use it for storage.
Should I partition this drive into multiple partitions as well, or go
with one big 300gb partition? Keeping in mind that no programs will
ever run from this drive.
Any suggestions on this are greatly appreciated.
Thanks in advance!
Kevin G.
2 answers Last reply
More about best partition 300gb system drive
  1. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    On 4 Apr 2005 17:11:53 -0700, "Kevin G." <kgibbons04@gmail.com> wrote:
    >Hello all,
    I personally am comfortable making my C partition on my 300G drives
    around 15-20G. It's quite easy to make a image of it to a partition on
    the second drive in case C goes belly up.
    I find it easier to partition all the rest of the free space into say
    75G +/- units. I use up a lot of disk space in partitions for MPs,
    photo storage with each photo taking up 10-15G on average, photo
    scanning, C images for back up on a weekly basis and on and on.
    Everyone has their own methods their comfortable with.
    I find it fairly quick to defrag a small C partion as opposed to a
    300G one if your into defraging. In fact for the most part only C
    needs to be defraged in my setup.
    >Thanks in advance!
    >Kevin G.
  2. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    Kevin G <kgibbons04@gmail.com> wrote in message
    news:1112659913.821372.248500@g14g2000cwa.googlegroups.com...
    > 300gb SATA drives (Maxtor 6B300S0 drives). I'm doing
    > away with the IDE drives all together, and going purely SATA.
    > using such a large drive as the system drive? With 80gb and 120gb
    > drives I've used in the past, I've simply used one big NTFS partition.
    > But with these 300gb drives, I imagine that isn't suggested..
    Its fine.
    > and may hinder performance when using a system partition that big.
    Nope, should be fine.
    Its generally best to just have one partition for the entire drive.
    > it for storage. Should I partition this drive into multiple
    > partitions as well, or go with one big 300gb partition?
    Just one big partition is generally best.
    > Keeping in mind that no programs will ever run from this drive.
Partition Storage
