possible to assign drive letter A to HDD ?
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
who knows ?
is there a solution fo virtual floppy based on HDD for programms that
require floppy ?
5 answers Last reply
More about possible assign drive letter
  1. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    You can do this with QSoft's ramdisk. I set mine to B:, but forget whether
    the property sheet does this or you need to use regedit.
    However, it shows up as Local Disk not Floppy Disk:
    b: = \Device\Ramdisk
    Media=Fixed, Sector=512B, Cylinders=8, Heads=2, Sectors=32, Total=256KB
    "openmind.desk.pl" <80662270a@gazeta-dot-pl.no-spam.invalid> wrote in message
    news:ee8bc$42720c46$455da0d2$2660@allthenewsgroups.com...
    > who knows ?
    > require floppy ?
  2. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    On 2005-04-29 12:28, openmind.desk.pl wrote:
    > who knows ?
    > require floppy ?
    I guess it depends on what level the floppy access is done.
    (I assume you use a windows based pc.)
    There used to be a dos command SUBST that could make a driveletter
    redirect to a directory but I haven't seen it in the later windows versions.
    I think ASSIGN will change driveletters only, unless the program has
    changed lately.
    If you actually need to access floppy drive geometry, I don't know.
    /Rolf
  3. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    >> who knows ?
    >> require floppy ?
    > versions.
    SUBST is present in Server 2003 and works fine, but it will not use a drive
    letter that is already assigned to a device.
    > changed lately.
    I don't believe that ASSIGN exists in any of the NT-derived Windows
    variants.
    > /Rolf
    --John
    to email, dial "usenet" and validate
    (was jclarke at eye bee em dot net)
  4. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    > who knows ?
    > require floppy ?
    VMware and alike give the best emulation.
    But, which programs do you need it for?
    Maybe SUBST or ramdrive are good enough?
  5. Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
    subst works fine for me
    thank you very much, you really helped me
    best regards, Piotr
Floppy Disk Hard Drives Storage
