G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I've got an ADS Tech Pyro case...
http://www.adstech.com/support/ProductSupport.asp?productId=API-808&productName=PYRO%202.5%20Drive%20Kit
and it appears not to be powering up the HD..
thought I'd take a volt meter to it.. and see if it was putting out the
juice that the drive needs, thinking that if anything had died, it was
likely the AC power brick. unfortunately that AC brick attaches to the
back of the case with a DIN style connector and I have no clue what to
his with my volt ohm meter there..
I saw silk screened on the back of my HD where the power connector
plugs in.. a 12 V (yellow).. 2 black grounds then a 5V.
so I assume one is a 5V power on..
and the other is for giving it the 12 V it neads to run...
I'm not seeing 12V across that yellow wire to ground wire...
does that likely mean the power brick feeding the case is dead?
Thanks,
Ethan
Thanks,
Ethan
