Strange DVD burner problem
Archived from groups: microsoft.public.windowsxp.video (More info?)
I've just tried to burn my first DVD on a SONY Vaio RX672 - this drive
has worked fine for playing DVDs and CDs as well as recording CDs in
the past. Today, I inserted a blank DVD-R to record from Adobe
Premier (while Premeier was running - at the time Premier saw the
drive and "no media inserted". After inserting the disc, I hit
"RESCAN" to have Premier find the disc. Premier then said "NO BURNER
DETECTED". From that point on, I cannot get Premier to detect the
drive, XP now shows the drive as "REMOVABLE MEDIA" and I cannot open
the door to remove the disc (the eject button does not work nor does
the MY COMPUTER EJECT command).
At this point, I'm not even sure how to remove the disc to get the
drive back. Anyone out there seen anything like this? Any and all
suggestions on how to remove the disc (short of power-down and
physically remove the drive) and / or how to get XP to recognize the
drive will be greatly appreciated.
Thanks
2 answers Last reply
More about strange burner problem
  1. Archived from groups: microsoft.public.windowsxp.video (More info?)
    ok DVD-R is the old type of disk, you need to make sure your drive supports
    it, try to use DVD+R discs, they are a newer technology, and more reliable
    "BLG" <benniegibson@mindspring.com> wrote in message
    news:831b0be1.0410030113.152667f4@posting.google.com...
    > Thanks
  2. Archived from groups: microsoft.public.windowsxp.video (More info?)
    As for ejecting the disk, do you see a small hole on the front panel of the
    disk? Insert a paper clip in there and press gently. This should force eject
    the tray.
    See this: http://www.computerhope.com/issues/ch000214.htm
    Rehan
    www.rehanfx.org - get transitions and effects for Windows MovieMaker
    > Thanks
Video DVD Burner Windows XP
