G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.video (More info?)
I have a Gateway computer with Windows XP Home, P4, 256MB RAM with an
Intel(R) 82845G video card. I am trying to run Roxio Easy Media Creator 7
(REMC7)
software using my computer connected to my living room RCA HDTV.
The RCA HDTV has a connection to accept a standard SVGA computer monitor
cable.
However, whenever I try to run REMC7, I get a message saying the display
settings do not meet the minimum requirement for this application and the
screen resolution must be changed to 1024 x 768 pixels or higher and color
quality to 16-bit or higher.
The problem is that I can not change these settings. I have tried using
settings in the control pannel but nothing I do seems to work. This happens
every time I try to use this software. Is there a specific driver for my RCA
MM36110 HDTV I have to
install oris there some other way correct this problem?
(REMC7)
cable.
