G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hello goup, I dont know if this is the correct group to post this so
please if there is a problem inform me....
I recently bought an external USB 2.0 case to use with a 80 GB Maxtor
Hard Disk....
I pluged it into my pc and the problems started....While it recognized
it, it couldn’t find the 2 partitions and read from them..... The only
way to make it work somehow is to diasable the support for USB 2.0
from the BIOS. I have an EPOX 8RDA+ motherboard and I use Windows XP
SP2. According to the board manual all my 6 USB ports are USB 2.0 and
according to EPOX support SP2 has the drivers to support USB 2.0
connections.....
I tried the disk to three other computers with other than nvidia
nforce chipset (via, intel) and everyhting works correctly with USB
2.0.
I don’t know what to search for or where to ask since Microsoft and
EPOX seem that they cannot help me.....
Is there a possibility that there is a problem with the power supply
for the USB ports? I do not have any USB device connected....
I will wait for your comments.
Regards
D
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/PC-Storage-USB-Disk-Problem-ftopict57779.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=291415
Hard Disk....
connections.....
2.0.
Regards
D
