G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hello, I just bought an external enclosure for my 80GB Maxtor hard
disk, but I have trouble setting it up. I set the hard disk to be
master and connected the IDE Connector and Power Molex correctly to the
hard disk. However, when I turned on the power of the enclosure, it
does not work and the light didn't even turn on. I tried to disconnect
the power molex from the hard disk, and the power came back up, but the
Windows XP didn't recognize it and gave me a code 10 error. I felt that
I should connect the power molex back to the hard disk, but it does not
have power when I did that. I wonder if it is the problem of the
external enclosure or the hard disk. I already tried the hard disk with
another external enclosure, and it had the same problem.
Thank you for the help.
