G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I have two 160 gig SATA drives in a RAID 1 configuration.
The other day, I rebooted my PC and found that the RAID array had
somehow spontaneously been split into two, i.e. each drive had its own
array, each of which was listed as "Degraded".
One of the drives boots into Windows normally (although the first time I
got the message "Windows has recovered from a serious error"). The other
drive fails to boot, so clearly has become out of sync with the first
drive.
I've been advised to go into the RAID setup for the second disk and
choose the "Clear Disk" option, then rebuild the array based on the
contents of the first disk. Does anyone know how long this kind of thing
typically takes? When I tried it, there was no on-screen indication that
it was doing anything, and I couldn't hear any disk activity. It
remained like this for 5 hours before I gave up and reset.
The motherboard is a MSI K8N Neo2.
drive.
