G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
I recently hooked my NEC 2500a DVD writer up to a promise ultra66 pci
controller and I've had nothing but problems with it. DVD Decrypter hangs on
"getting book type" when ever I select the NEC (but works fine with my other
2 optical drives). Also when I try to burn with the drive using Nero it has
buffer underun issues if I select any speed over 2.4x.but the weird thing is
when I do a transfer rate test using a data DVD and Nero tool kit the drive
is able to read at up to 8x. I've tried everything I can think of, I've
updated both the bios and the drivers of the controller card, I've even
installed Adaptec winaspi but nothing seems to make a difference. Any help
would be greatly appreciated.
my sys:
Athlon 64 3000+
MSI neo 2 plat.
1GB Ram
Winxp Sp2
my sys:
Athlon 64 3000+
MSI neo 2 plat.
1GB Ram
Winxp Sp2
