Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hi!
For some reason one of my hard drives started to produce errors and
after correcting all the problems i took to Ontrack's Data Recovery
program to try and get some of the deleted files back.
From the Windows version, if i select any recovery type the program
exits unannounced, it just vanishes.
Undeterred i made an emergency boot disk and tried from dos! All my
drives were seen (all NTFS) and i proceeded to let the program search
though the drive in question. All was well.........
...... until we came to select a destination for the recovering data.
In the destingation dialogue box i had just A & C - the floppy and the
ramdisk!
This program works perfectly well on my laptop and though if booting
from a recovery cd i get the same problem with the dos version.
Does anyone else have this problem or does anyone know why it is
happening?
Failing that, can anyone recommend a recover program for dos which
will read/write to NTFS partitions or maybe even recover to dvd?
"Engelkott" <nomail@nomail.com> wrote in message
news:53eee1pq4ml44aa5rmbb3gnuui9i9fbc3b@4ax.com...
> Hi!
> ramdisk!
> happening?
> Thanks for any help!
> Engelkott
>You can run iRecover from a Windows boot cd (Bart PE):
>http://www.diydatarecovery.nl/irecoverpe.htm. From this environment you have
>access to NTFS, network, etc.
>Joep
