Darn, is my Hard Disk Drive finished? Can't read it.
Last response: in Storage
Archived from groups: comp.sys.ibm.pc.hardware.storage,comp.hardware,van.forsale (More info?)
I have a 120GB Western Digital Caviar that is less than two years old. I
was rendering a movie from it when it froze and then nothing could read
it again.
The computer bios will see it, but windows can't. Can't seem to access
it in anyway, even to reformat it. It spins and seems fine....
Any idea what happened, and if it's usable? If so, how, as my operating
system won't read it. Warranty is expired.
I use GetDataBack and it has worked wonders on my old "unreadable" (by
Windows) drives.
-Chris.
>it again.
> Windows) drives.
> -Chris.
>>it again.
Cool. I don't need the data on it, I just want to be able to use it
again, as it's not an old drive.
On Thu, 11 Aug 2005 07:12:00 GMT, eb7g <eb7g@shaw.ca> wrote:
>> Windows) drives.
>> -Chris.
>>>it again.
Well, it's worth a try to try to recover it then.
I wouldnt put faith in it until you've had it running stable a while
though.
Do you have the tech to repartition and reformat yourself? Have a
mildly well versed tech buddy who can help you?
-C.
Related ressources
download the diagnostic disk from WD and run the quick and extended health
test on the drive. you can also zero fill the drive (since you don't need
the data) and verify afterward to see if there are bad sectors in the drive.
unfortunately the program does not give you the actual errors, just error
codes so you can't really tell what they are. but having this happen to the
drive once, you should avoid putting important data on it, even if it
recovers.
"eb7g" <eb7g@shaw.ca> wrote in message
news:4TCKe.186935$%K2.75849@pd7tw1no...
> > Windows) drives.
> > -Chris.
> >>it again.
"" wrote:
> "unreadable" (by
> > Windows) drives.
> > -Chris.
> years old. I
> could read
> >>it again.
> to access
> fine....
> my operating
> use it
Get back data is a good option...
has worked for me with a dead 80 gb seagate.
Easy Recovery Pro....can also be of much help....its got this option
whr you can recover data from a formatted hdd. (hvnt still got a
chance to try it tho...) hopefuly shuld work for you..as long as the
drive detects in the bios and spins...uve not run out of luck....
im soon gonna start work on a WD Caviar WD400BB dead hdd which isnt
showing up on bios...
anyone knows any software for WD for e.g DM 9.5 for seagate
cheers!
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/PC-Storage-Darn-Hard-Disk...
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=304701
You said it's less than 2yrs old and warranty's expired, all WD 120gb drives
come with a 3yr warranty, look into RMA'ing it.
I'd stay clear of any WD drives, due to past experience with them.
news:p NBKe.186006$%K2.81544@pd7tw1no...
> it again.
> all WD 120gb drives come with a 3yr warranty,
Wrong. Not when he bought it.
> look into RMA'ing it. I'd stay clear of any WD
>> old. I was rendering a movie from it when it froze and then nothing
>> could read it again.
>> access it in anyway, even to reformat it. It spins and seems fine....
>> operating system won't read it. Warranty is expired.
Rob wrote:
> if the drive is unreadable with any other tools.....
> try this
> works.. 90% of the time
depends what the failure mode is.
> freeze the bastard.. overnight
If you must give this advice at least tell people to put the HDD
in a plastic bag before putting it in the freezer.
> get ghost.. made by symantec.. a hard drive cloning utility
> install the dead hard drive back.. boot up with ghost, and let the
> cloning begins!
Using this method you may have limited time until it heats up and
stops working again.
It might be quicker to get important files off it instead of cloning
the entire drive.
Mike
thats why i mentioned in my first line " if the drive is unreadable
with any other tools "
in other words, if the drive is toast, give it a shot
On Fri, 12 Aug 2005 10:05:53 GMT, "Mike Redrobe" <mike@redrobe.net>
wrote:
>> try this
>> cloning begins!
>the entire drive.
Good choice, that's the exact one I have in mine too.
No problems with it so far.
news:EcYKe.197330$s54.70843@pd7tw2no...
> I just checked it with Partion Doctor 3.0. Turns out....every sector is
> bad. I guess it's toast.
> I bought a Seagate Barracuda 200GB instead, they have the 5 year warranty.
> thanks for your posts and emails.
> Zag wrote:
> > Or just get Spinrite.
Ask the community
