Archived from groups: comp.sys.ibm.pc.hardware.storage (
More info?)
Andy <kanadaiy@telus.net> wrote
>>> The motherboard of my computer has been changed to a
>>> K7S741MG/K7S741GXMG. As a result (I suspect) the sound-recording
>>> capability has been lost. The microphone produces feedback and
>>> normal sound through the speakers, but using the Sound Recorder
>>> supplied with Windows XP Prof. or another sound recording program
>>> fails to record sound. Reinstalling Windows has not helped. Any
>>> ideas what might cause this?
>> The mic can be muted in the mixer. You've likely got a different
>> mixer now if you installed from the CD that comes with the
>> motherboard, and if you didnt install that, try installing it.
>> The sound setup can be a bit complex now, there are settings in
>> the sound system in the control panel individually for the input and
>> output sides. Does the sound recorder record from any other source ?
> I don't know how to test recording from any other source. Will you
> teach me? :-(
Just get it to record a wav file being played. You
select what is recorded in the recording mixer.
> I've tested the sound recording using the Sound Hardware Test Wizard
> and got "An error occurred during DirectPlay Voice setup. The error
> code is 0x80004005," whatever that means. Further investigation of
> the Device Manager revealed that the Realtek AC'97 Audio is disabled.
> This was done by a technician due to a conflict between the digital
> outputs by the onboard sound and the SoundBlaster sound that resulted
> in no sound at all. Enabling it does not restore the sound recording
> ability, and it makes the sound entirely disappear. The voice
> recording audio recording device is SB Audigy Audio. Does this help
> you with your diagnosis?
Likely you have a considerable mess because you are trying to
use both a sound card and the motherboard onboard sound.
You sure you're actually plugging the mic into the Audigy mic socket ?
If you are, you may not have the mixer for the Audigy
properly installed and its got the mic muted when recording.
Werent you the one that had asked previously about sound cards ?
