Archived from groups: rec.video.desktop (More info?)
Using Quicktime 4 Pro to convert a DV file to .dv for a client for use
with Final Cut.
After the conversion the file size is reduced by almost 2/3's. This
can't be right. All it should be doing is stripping off the wrapper and
that's not that large.
Any thoughts? Any other say to do this correctly?
Thanks!
with Final Cut.
Thanks!
