Yes No
Ads
Tom's Hardware > Forum > Computer Peripherals > Digital Cameras > Difficult technical question on ISO & light
Forum Computer Peripherals : Digital Cameras Difficult technical question on ISO & light
Page:    Previous 1 2 3 4 5 6 7 8 9 10 11 12 13 Next Bottom Search this thread
Archived from groups: alt.comp.periphs.dcameras,rec.photo.digital,rec.photo.equipment.35mm,rec.photo.film+labs,rec.photo.darkroom (More info?)
Let's see if I catch some guru's attention with this subject :-)
I have recently bought a Canon S50 but probably any other camera would
not change the question. It would probably be the same even with a film
camera + lab processing.
I can't understand how the following thing works:
Case a.
I take a photo by night at ISO 50 without flash. In the photo I can see
the streetlights which have white color (RGB = 255,255,255), but all the
rest is very dark.
Case b.
I take the same photo (same time and lens aperture) at ISO 400 without
flash. This time I can see everything. The streetligts are always white
at RGB = 255,255,255 .
I cannot understand how the algorithm works, and not even the physics
behind all this: how can the ratio between the luminosity of the
streetlight and the luminosity of the walls of the houses CHANGE
depending on the ISO (50 vs 400)??
One could say that the reason for this is the clipping, that is, at 400
ISO the streetlights were more luminous than RGB = 255,255,255 but they
have been clipped to that value.
But I think this is NOT the reason because if it should be, then what
would be the explanation for the fact that EVERY picture I take in a
whatever dark environment ALWAYS contains at least 1 pixel at with one
of the three components (R,G or B) at 255? It seems like there is an
algorithm which multiplies the information from the CCD until at least 1
pixel of the image reaches the maximum value (255).
BUT THEN, if such a normalizing algorithm exists, again the photos in
case a. and b. should present the same luminosity ratio between the
streetlights and the walls of the houses, while it is not like this.
So what?
Thanks in advance.
Reply to Anonymous
> Case a.
> rest is very dark.
All that is is that the light 'burned' through and was probably much higher that
what you measured in photoshop... 255 is at the limit of each color, so you got
clipped highlights. The rest of the frame was simply udnerexposed (0, or maybe
a bit more on 255).
> Case b.
Again, the streetlights are burned out and you're at the limit (in fact even
further, but it doesn't matter). But now, 3 stops more sensitivity so other
areas begin to fill in.
In an 8 bit per color case, a pixel can have a value of 0 (black) to 255 (full
saturation). When all three color elements are 0, (black); when all three color
elements are 255 it is pure white. When all 3 color elements are equal, but in
between, you get a shade of grey. When all 3 are 128, you get middle grey (18%
grey).
In you case however you had a scene with such low light that nothing registered
at ISO 50 except those parts of the scene that were very strong (too strong).
Near the lights you may have a halo area that quickly rolls from 255 down to
near 0 quickly.
At 400, you got more detail in the dark areas ... but the light was even further
beyond the sensitivity of the sensor and fully saturated.
Yep.
A scene may easilly have more range than your film or CCD/CMOS can handle. Thie
means that either one end will be over exposed and other perhaps okay; or vice
versa ... and if the scene is really wide you will have both unexcited pixels
(too dark) and saturated (clipped) pixels. This is why one strategy is to place
the highlights at the extreme right of the histogram, and let the rest fall
where it may.
There is no compressing or decompressing. The sensor can hanlde so much scene
latitude and you the photographer has to place it correctly... in auto mode,
presumably the camera does this well... presumably.
Shoot RAW, put your hightlights at the extreme right of the histogram and you
will get the most detail that the camera can record in that scene.
Cheers,
Alan
-- rec.photo.equipment.35mm user resource:
-- http://www.aliasimages.com/rpe35mmur.htm
-- e-meil: there's no such thing as a FreeLunch.--
Reply to Anonymous
Whats wrong with you? You are making this too complicated. And did you
really need to cross post this to half a dozen newsgroups?
Digital film (senor) sensitivity are equivalent to film. The higher
the ISO the more sensitive the film is to light. So the higher the ISO
on a digital camera the more sentive to light the digital sensor is.
If one setting is higher than the other its going to be more sensative
to light and therfore capture more light in the scene.
Back to your question about the street lights. Obviously it will catch
whatever has the most light in a given scene, so the streetlights will
be brighter, even washed out without detail, because they are the
brightest part of the scene, while the rest of the scene is only
somewhat visable by comparision. Think about shooting the sun. Try
shooting a sunset. You will get an opposite effect in a bright scene.
The sun will be totally bright while while the rest of the landscape
will be pitch black because the sensor cannot hold to extremes of
light.
If you are in a dark scene use a tripod with lower ISO settings. If
you shoot handheld you will either get blur or a lot of grain, with
either digial or film. Also try to avoid extremes in lighting
especailly in dark scenes as you will get white washout from bright
sources of light like streetlights.
huerew <huerew@hhh.com> wrote in message news:<clrqmc01h3p@news3.newsguy.com>...
> Case a.
> rest is very dark.
> Case b.
> So what?
> Thanks in advance.
Reply to Anonymous
I do agree this is should not have been crossposted.
Incorrect. CCD or CMOS sensors are not equal to film; one is
not equivalent to then other. There are differenent physics
and imaging properties that apply to any giving situation.
Film has the ability to _accumulate_ light and endure long
exposures or multiple exposures that can capture detail
in the dimmest of situations. Reciprocity failure is the
only factor. Silicon simply can't do this and is limited by
both exposure latitude and length of exposure.
> The higher
Digital sensors have a _nominal_ "speed" at which they
produce the best quality image. When you alter that speed
the image quality goes down. Film can be rated at a different
speeds and still produce quality results because as development
of film is altered, effective speed also alters. Also, a "slow"
film can be simply be exposed for a longer time than a faster
film, and achieve the same results. No loss in image quality.
Film can be exposed for hours. Try that with a digital sensor.
It simply one of the differences between these two imaging
mediums.
> light.
> > Case a.
> > rest is very dark.
> > Case b.
> > So what?
> > Thanks in advance.
Reply to Anonymous
In article <4181C14A.D6ECD4FA@aol.com>,
>mediums.
You really should avoid such pontifications unless you're absolutely certain
you're correct, as you aren't in this case. Canon's current DSLRs, to take
one example, manage perfectly hapilly with multi-hour exposures. The only
major problem is that holding the shutter open that long may drain the
battery.
Reply to Anonymous
> >mediums.
> battery.
uh huh... multi-hour digital. And no noise due to heat. right.
(and heat is *inherent* in digital sensor exposure...)
Show me a "multi hour" digital exposure.
Reply to Anonymous
Tom Phillips wrote:
> That's the point. If the OP wants to obtain detail in nighttime
> exposures, he might try using a suitable film and employing
> a multiple exposure technique. No digital camera can do this.
Either that or he should stop crossposting...
Reply to Anonymous
> > >mediums.
> > battery.
And I don't mean astrophotography.
The ability of the canon EOS to do astrophotography is
in part due to the employment of a larger pixel. Larger
pixels mean a better signal and less noise, *but* (also
less pixel resolution. So _pictorial_ resolution is
sacrificed for better signal and less noise. This is hardly
comparable with film, where resolution abilities is not
based on large grain size, but _small_ grain size and where
exposure and signal frequency is on a molecular level, not
a pixel level.
Reply to Anonymous
"Justín Käse" wrote:
> In Message-ID:<4181C14A.D6ECD4FA@aol.com> posted on Thu, 28 Oct 2004
> >mediums.
> I used to have a rule of thumb with ASA100 film at f5.6, a scene lit by
> full moonlight took five minutes. This would bring out (saturate) all
> the colors, and providing there was no wind, give good resolution to
> leaves and foliage.
> I haven't tried it with the digicam yet, but thinking about what's been
> discussed, there wouldn't be any reciprocity failure to worry about as
> there would be no accumulative chemistry happening,
reciprocity failure isn't due to chemistry, but related
to quantum physics...
>neither would there
> be any increased darkness penetration effect either. Guess I won't be
> throwing away all my film cameras just yet. <g>
No you shouldn't :-) In order for digital images to gather
more light, larger pixels are required. This increases
the Nyquist limitations and lessens resolution. Silver
haildes, OTOH, gain more resolution the _smaller_ the
grains are. This requires more exposure, bit only
reciprocity correction.
Reply to Anonymous
In article <4181DC73.F1671D33@aol.com>,
>Talking lighting and exposure here. And again you ignore
>nyquist. Also, on average a 400 speed 35mm film has the
>equivalent of 24 million pixels.
Oh wow, a real 35mm pixel-counter. I thought the last one of those in the
wild had died out years ago...
Reply to Anonymous
No, stupid. It's something that's been scientifically determined
by eminent photo scientists based on the number of absorbed photons.
Not that the two are equal...
Reply to Anonymous
> In Message-ID:<41820CEB.85C0F622@aol.com> posted on Fri, 29 Oct 2004
> >> >mediums.
> >> leaves and foliage.
> ...which is the basis of chemistry, no?
I suppose one could say it's photochemical. Technically
it's related to the intermittency effect, or the amount
of light available. Reciprocity failure at longer exposures
results from low irradiance of silver halides, meaning there
is too long a time -- too long a gap -- between the halide
molecules being struck with enough photons to initiate
nucleation and the formation of latent silver (photolysis;
typically three photons are required.) This is also why in
photography a 2+2 exposure does not equal a single exposure
of the same continuous length. But since silver halides can
accumulate exposure, _adding_ additional exposure (i.e.
a reciprocity correction) will compensate -- i.e., multiple
exposures are applicable.
Silicon sensors do not this, as they do not accumulate
multiple exposures and over exposure inherently begets
additional noise.
> Quantum theory is just the mind's imagination trying to comprehend
> phenomena that exceed our technical abilities of resolution.
You've lost me. Sorry.
> Counting subatomic particles smaller than the atomic probes we are
> currently limited to using, is like trying to read braille with your
> elbow.
> talk about nyquist limits. <g>
Well, nucleation occurs on a molecular level in silver
halide imaging. Silcon imaging requires a much greater
incidence of photons (photoelectrons) to generate a
signal for the same tonal "exposure."
> >>neither would there
> I thought pixel sensitivity was a function of semiconductor gain and was
> dependent on the difference between the idle state and the excited
> state, thus the astronomical use of refrigerants to chill CCDs as much
> as possible to enhance that difference.
Larger pixels help increase the gain also.
> I think it's only modern digicam sensors that use selective bias
> voltages to simulate ISO ratings for user convenience in varying
> situations, whereas astro-photographers strive for the utmost gain, and
> aren't concerned with desensitizing their equipment for "beach" pics.
I _think_ we agree.
Reply to Anonymous
In article <4182032A.D3B720F7@aol.com>,
OK, I'll take one tonight and upload it. Have to be of something indoors and
boring, I'm afraid, as there's too much light pollution where I live to do
such a long exposure outside, and the weather's pretty nasty atm as well.
Watch this space.
Reply to Anonymous
"pk" <pkim0908@gmail.com> wrote in message
news:af6200a1.0410281933.7416b5ea@posting.google.com...
Overanalysis Paralasis.
It seems that below the confusion regarding exposure is a misunderstanding
regarding the eye and film. The eye (and brain) process an image so that you
see a great range of brightness. Film is not that way. Look to the film
sensitivity chart where film's sensitivity to gradations of light is plotted
in a log curve. Better now? So simple when you get that.
Reply to Anonymous
On Fri, 29 Oct 2004 06:06:53 -0600, Tom Phillips <nospam777@aol.com>
wrote:
>Chris Brown wrote:
>> In article <418210F6.561BFC92@aol.com>,
>> >No, stupid.
>> I bet that's what you say to all the girls.
>> Your alluded to "scientific determination" doesn't match the reality
>> observed by those of us who shoot multiple systems. In said observed
>> reality, 35mm film can just about edge out 6 megapixel DSLRs at low ISO,
>***ONLY*** at typical machine print sizes. In fact, any 35mm
>image can be *enlarged* to as much as 10 times it's resolution,
>revealing additional image detail. No digital image of a similar
>pixel resolution can achieve this capability. A higher resolution
>capture is required.
>This is simply due to the fact that silver halides record
>tonal/image information on a molecular level as opposed to
>a much larger pixel. This is an inherent distinction between
>these two imaging mediums.
off track .. this only happens if the emulsion would consist of free
molecules in a monomolecular layer at 100% molecular density .. it is
not, even if microcrystaline it still is crystaline .. and hence you
do not get a 100 chemical reaction to light ..
Reply to Anonymous
- 0 +
"imbsysop" <imbsysop@yahoo.com> wrote in message
news:dhj4o0170118qehg72lt3e1fj6hf438g0m@4ax.com...
in the
Kodak quotes 24 MP as the equivalent of 35mm film, on their website.
Whether you can observe the difference in image quality is another issue.
I would accept Kodak's assessment, because I consider them qualified to make
it.
Reply to jeremy
- 0 +
On Fri, 29 Oct 2004 00:08:21 +0200, huerew <huerew@hhh.com> wrote:
>Xref: sn-us alt.comp.periphs.dcameras:58712 rec.photo.digital:1048214 rec.photo.equipment.35mm:865238 rec.photo.film+labs:76078 rec.photo.darkroom:208187
Please post to the appropriate group and only to the
appropriate group.
Regards,
John S. Douglas, Photographer - http://www.puresilver.org
Vote "No! for the status quo. Vote 3rd party !!
Reply to john
In article <41823255.BC08FE81@aol.com>,
>> The medium format does give me superior image quality to both of them, and
>> it's dramatically superior. The relative difference between the digital and
>> 35mm, in comparison, is not worth bothering with. They're both adequate for
>> an A4 print, and ropey for an A3 print.
>Never shot Kodachrome 25 or 64, I gather...
Usually Velvia 50, although I'm doing a lot more Provia 100F these days.
>The questionn is, why is this even a debate?
It's not - in the eyes of nearly everyone who regarded this as some kind of
"contest", 35mm "lost" years ago, with the previous genertion of DSLRs.
You're trotting out the sort of stuff that used to infest r.p.e.35mm and
r.p.d about 2-4 years ago. Pretty much everyone else has accepted reality
and moved on.
>For _pictorial_ imaging, film is the better medium. The
>facts bear this out.
I quite agree, you just need the film to be 6cm wide or more to compete
in the quality stakes these days.
>Digital,imaging is not photographic. It does not produce
>a photograph.
If you say so.
Reply to Anonymous
In article <26k952-5k8.ln1@narcissus.dyndns.org>,
In the meantime, here's a 30 minute one to be going on with. I downsized it
for the web, but included a 1:1 crop in part of the pic, so that you can see
just how "terrible" the noise is.
Ambient temperature was about 15C.
http://homepage.ntlworld.com/narcissus/30mins.jpg
Reply to Anonymous
In article <lhsgd.13512$ta5.12299@newsread3.news.atl.earthlink.net>,
Large film manufacturer gives optimistic interpretation of raw data
regarding own product shock! Film at eleven (no pun intended).
Reply to Anonymous
"Tom Phillips" <nospam777@aol.com> wrote in message
news:41823255.BC08FE81@aol.com...
> Photography produces a photograph. And a photograph is an
> image written on photosensitive materials by the direct
> action of light. Digital imaging is electronic and about
> as "photographic" as your television cameraman broadcasting
> to your T.V. set. Again, no photograph.
Photograph, from the greek "photo-" meaning light and "-graph" meaning
recording. Whether the recording was made photochemically and stored on
physical media or photoelectrically and stored on digital media is really
inconsequential to its status as a photograph.
Ken
Reply to Anonymous
30 minutes is not "multi hour."
CMOS sensors are an improvement over CCD sensors.
But,caveats still exist. For exmaple, it is still
a fact of electronics that the bigger the pixel the
better the signal and the less noise. Canon, in fact
states on their web site that "When photographing dark o
bjects like stars, conditions at the place of use, such
as the temperature and the length of exposure, may have
a noticeable effect on the noise level of the camera...."
Canon also recommends the EOS 10D for such imaging, on
the basis that the pixels are larger and thus produce
a better signal and less ingherent noise.
Hours and hours is what you claimed. Noise is still going
to be an issue. The issue with film is reciprocity failure,
but this is easily compensated for and there is no noise.
The fact is, due to Nyquist digital sensors suitable for
longer exposures simply are not going to match the detail
and resolution possible with film.
Reply to Anonymous
> and moved on.
Pixels are still limited by Nyquist. The garden variety
consumer digital camera uses a bayer pattern, meaning color
pixels are interpolated 4:1 to get one full color pixel.
Thus the sensor reolution does not reflect the actual image
pixel resolution. There's a long way to go before one
shot consumer digital cameras can match even 35mm film.
Now, it may look good in typical consumer prints, but to
the human eye this only requires about 6mp to achieve.
What I'm saying is the average 400 speed color film has
more resolving ability than this available, even if it's
not typically needed or used by the average consumer.
Well, I shoot 4x5. Pixels will never be able to get that
small or numerous to effectively compete there.
> >a photograph.
> If you say so.
It's not what anyone says, it's what the technology actually
does and doesn't do. It produces data, which is why it's a
_different_ imaging medium. Data is not an optical image nor
a phototgraph. Thus while an imaging medium, it's not
photographic.
Reply to Anonymous
> >> >No, stupid.
Silver hailde exposure occurs at the molecular level.
Reply to Anonymous
Quote: "the pixel size of a highly sensitive emulsion layer is
assumed to be 100 square micrometers on the basis of the fact
that a color film with an ISO 400 sensitivity and 135 format
contains 24 million pixels."
From "Progress and future prospects of silver halide photography
compared with digital imaging." Journal of Imaging Science and
Technology, vol 42, no. 1, 1998.
Not a Kodak publication. Also, a film with lesser sensitivity
(i.e., a slower film) would in fact represent a higher number
of equivalent pixels due to the finer grain and resolving
ability. As noted, in comparisons of typical machine 4x6 prints
from ISO 400 film and digital imagers, all that is needed to
satisfy the human perception of image quality is 6mp. But the
fact remains 35mm film exceeds this limited requirement.
Reply to Anonymous
> Ken
No. it means (literally) light writing, i.e., as in physically
drawing with light.
Digital sensors produce data.
Reply to Anonymous
"Dark object like stars" ??? Hmm, brown dwarfs and black holes I guess.
Reply to Anonymous
- 0 +
Lower resolution didn't stop the CDs from becoming a standard.
Same thing will happen to photography.
Digital is not at its best yet. Half my family is into professional
photography. My grandfather opened his first photo studio in 1928 and my
great-grand-father had a photo studio too.
http://www.mhf.krakow.pl/wystawy/bielec/
http://www.foto-bielec.art.pl/
(sorry the links are not in english)
So, when my aunt or my cousin tells me that she sees a difference between
the film and the digital, I believe them. This is what they do for living.
Still, it doesn't stop them from integrating the digital into their work. As
they both know that it is the future and you need to be able to take
advantage of it if you want to stay in the business.
Reply to Paul
news:4182AA2C.4460FA66@aol.com...
>> >> >> in the
>> >> >No, stupid.
>> >> ISO,
sure .. but not sure for how many molecules in the crystal ..
Reply to Anonymous
In article <4182A636.6840EF5E@aol.com>,
Reading comprehension not your forte then?
Reply to Anonymous
In article <4182ACF8.F5A99776@aol.com>,
What a nonsensical quote - film contains no pixels at all.
I wrote their own "product", not their own "publication". It's right there
in the material you quoted. Really, this doesn't have to be hard.
>ability.
I'd dearly love for this all to be true, as it would vastly improve the
results I was able to get from 35mm film. In reality, as anyone knows who
actually uses both and doesn't have an axe to grind, the suggestion that you
can get "24 megapixel" images from 35mm film, where we're talking about
similar "quality" pixels to those provided by a DSLR, is ludicrous and
doesn't come close to reflecting reality.
The position you are trying to advance in this thread does not reflect
observed reality, and that is the ultimate arbiter. When reality proves your
theory wrong, continuing to try and find new papers and calculations to
support it is a pointless waste oof your time.
Reply to Anonymous
In article <4182A902.A58F1699@aol.com>,
>> and moved on.
[snip more assertions in conflict with observed reality]
>Well, I shoot 4x5.
Perhaps you'd be happier getting with shooting your 4*5 then - you currently
seem quite obsessed with exaggerating the abilities of small format film.
Now you're getting the idea.
Consumer DSLRs and 35mm are both good for A4 prints, and passable for A3
prints of some subjects. That is "what the technology does and doesn't do".
Your mathematics is uninteresting and irrelevant.
Reply to Anonymous
news:4182AD9B.B7007F9A@aol.com...
> drawing with light.
Write, draw, or record. All meaning to take something transient and make a
more permenant record of it.
But let's say "-graph" was a strict literal translation to "writing". Are you
implying writers who use word processors aren't really writing?
Ken
Reply to Anonymous
You're right. mediocrity rules.
Sure. But it is _different_ from film and cannot do the
same things.
Digital is a tool. But it cannot replace film because
it's not film.
Reply to Anonymous
> >> >> >> in the
> >> >> >No, stupid.
> >> >> ISO,
All it requires is one to initiate photolysis.
Reply to Anonymous
The article was writen by a photo scientist, and they
do indeed use comparitive pixels as a measure based
on the number of absorbed photons per area of either
developable grains or pixel-photodetector area.
I view it as merely a comparison of the pictorial information
available. And you're right, film has no pixels. If we
instead measure that information using grains contained, even
a 35mm film has _billions_ more picture "elements" than
any digital sensor.
Reply to Anonymous
> > drawing with light.
I'm stating a fact. Digital sensors do not create a
photograph. They transmit a voltage, regenerated into
digital signals, then stored as binary data.
The ISO defines a digital still camera as producing a signal
that represents a still picture. In digital form, there is
only data. No picture. And they set the standards all digital
cameras follow.
Reply to Anonymous
Hence the words "in the meantime". I think he put that one up
to act as a not-quite-what-you-wanted preview of what's to come.
I think what you're wanting to say is the signal to noise ratio
for larger pixels is often greater than that of smaller pixels,
resulting from the deeper electron well afforded by a larger
sensing area.
Out of curiosity, do you have a website anywhere that I might
view some high detail low-light pictures you have taken? I'm
considering exploring this area of photography (even though
I'm on the digital side of things) and would like to see what
other folks have accomplished.
BJJB
Reply to Anonymous
Typical 135 format film measures 36x24 mm, for a total imaging area
of 864 square mm, or 864,000,000 square microns. Dividing this by
the quoted pixel size above yields 8,640,000 "pixels" on the 135
format film. I have no idea how the authors of that quote came up
with 24 million, which at first glance appears to be too large by
nearly a factor of three. Perhaps the authors assume some degree of
overlap between "pixels" on the emulsion layer?
BJJB
Reply to Anonymous
it's based on the number of absorbed photons per area of
developable grains, not the film dimensions. That's what
it says, anyway.
Reply to Anonymous
"per area" should tell you that the film dimensions do matter.
news:4182DD3F.2DAFE9EC@aol.com...
> it says, anyway.
Reply to Anonymous
[Hm, way too many groups, but I can't decide which ones to remove.]
Kibo informs me that Tom Phillips <nospam777@aol.com> stated that:
Yes, but the end result is quite similar for photographic purposes. In
the context of lattitude/dynamic-range (ie; the OP's problem), the only
important difference is that an electronic image sensor has a brick-wall
cut off at the highlight side of the scale, whereas most people are used
to shooting colour negative film, which is somewhat more forgiving of
highlights. OTOH, a lot of that is more to do with it being reversal
film, because people shooting positive colour film (ie; slide film) also
have to watch out for sharply cut-off highlights as, (although, IIRC,
not quite as sharply as an image sensor).
But leaving aside all the technical details, the fact is that a piece of
film & an image sensor are both devices for trapping photons & keeping
track of how /many/ photons they've trapped. They're both subject to the
same laws of physics in that regard, resulting in similar compromises.
That's incorrect. CCD & CMOS sensors accumulate electrons in a charge
well in each pixel. They can be, & often are, used for long exposures of
very dim light sources. As a bonus, their equivalent of reciprocity
failure (charge leakage) can be controlled far more easily than for
film. The tradeoff is that they pick up thermal noise, but in for really
long exposures, the sensor will be cryogenically cooled.
>> The higher
Um. There's a certain amount of truth to that, but it's not quite so cut
& dried as you are implying. The 'inherent' speed (actually sensitivity)
of a CCD/CMOS sensor is a function of a number of design factors, such
as the size of the charge well & photo-sensitised area at each pixel,
how much light is lost to the CFA (if one is used), the accuracy &
signal-to-noise ration of the sense amps, resolution/sensitivity of the
A2D converter(s), whether microlenses are used, the amount of noise
considered acceptable for the sensors intended use, etc. All of those
variables determine the maximum usable sensitivity of a particular
sensor, certainly, but that's equally true of the way a particular film
emulsion is formulated as well.
You don't think that reciprocity failure counts as "loss of quality"? -
I certainly do!
>mediums.
Well no, it's the difference between standard film & the design goals
for digital cameras sold to the general public. There is no inherent
limitation to semiconductor image sensors that makes it impossible to
design one suitable for multi-hour exposures - there's just not a very
big market for such sensors. (That said, try Googling for information on
the kinds of image sensors used for astronomy - it's fascinating what
you can do with a CCD if you're willing to spend enough money.)
W
. | ,. w , "Some people are alive only because
\|/ \|/ it is illegal to kill them." Perna condita delenda est
Reply to Anonymous
You didn't
"John" <use_net@puresilver.org> wrote in message
news:14q4o012b7gmnsp4n6jekdodmdqq33nudk@4ax.com...
> appropriate group.
> Regards,
Reply to Anonymous
Gotcha, troll. ;)
Forgot to change ID's before responding to your sock-puppet, eh?
[For everyone reading this thread, you're being trolled by this idiot.
He's trying to start up yet another of those interminable film/digital
flamewars. Too bad he screwed up while switching personas.]
W
Reply to Anonymous
- 0 +
what a load of waffle!
I suppose with Digital we must have dispensed with photons and we don't get
a representation of the intensity and frequency?
It matter nothing whether we obtain a sample of the data (the source is
data!) via chemical means or via sensor for your classification. In essence,
and as part of the fundamentals of Physics they are analogous.
As far as your continual reference to "The Nyquist" you make it sound as if
you have stumbled across some incredible, mostly understood phenomenon that
restricts Digital signal analysis and can therefore be used as a
justification for tossing out Digital Photography. Have you ever actually
done any digital signal sampling and processing? I doubt it! Even by the way
you use the term it shows you have little knowledge of it.
I can't wait until you hear of a Cepstrum!
>> Ken
> drawing with light.
Reply to bj
In article <4182C8B8.CDAEB46E@aol.com>,
I don't care if it was written by the Tooth Fairy, it's still nonsense.
Reply to Anonymous
"BJ" <noreply@noemail.com> wrote in message
news:4182c6c9_1@news.iprimus.com.au...
> what a load of waffle![...]
Good rant. I give it an 8 of 10 and can sense that had you not typed it out
at 150wpm it would be a classic.
Tom P seems to be stuck in an indefensible position. If I were him I'd
change my name to.... what is appropriate... BLANK, yes, that's an
appropriate name.
Reply to Anonymous
In article <10o62mqhd9bhnc0@news.supernews.com>, "jjs" <jjs@x.x.com>
> appropriate name.
Your wrong you idiot, and that just shows what you know,... zip zilch nada.
Several appropriate names come to mind for you, however. JJ Ass. Staffacoccus?
LF Website @ http://members.verizon.net/~gregoryblank
"To announce that there must be no criticism of the President,
or that we are to stand by the President, right or wrong,
is not only unpatriotic and servile, but is morally treasonable
to the American public."--Theodore Roosevelt, May 7, 1918
Reply to Anonymous
This conversation is over.
Suffice it to say that every photographic expert
acknowledges what you reject...
Reply to Anonymous
photoelectrons, dummy...Digital is photoelectric.
> and we don't get
> >> Ken
> > drawing with light.
Reply to Anonymous
Previous
There are 2128 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Best 24" TN-panel monitor for gaming/Movies under $225?
By revolution2718, 4 days ago:
I have that same model and am a big fan. The colors need some tweaking out of of the box,...
Best offers
Top experts
