Pinnacle Edition - Transition problems... help!
Archived from groups: rec.video.production,rec.video.desktop (More info?)
I'm running Pinnacle Liquid Edition 5.5
All of the sudden, I can no longer add ransitions between video clips
unless the transition is only 00:00:00,01 in length
I find that the little bar you can move around (not sure what its
called - please see screenshot) now has a lighter, second bar next to
it - exactly 00:00:00,01 away from it. I'm guessing these two issues
are related, but I cannot find any documentation on how to fix it.
Does anyone have any clue what I'm talking about?
Thank you in advance for any help provided...
screenshot: http://66.197.117.133/pinnacle_screenshot.gif
-=Lazzerous=-
4 answers Last reply
More about pinnacle edition transition problems help
  1. Archived from groups: rec.video.production,rec.video.desktop (More info?)
    "Lazzerous" <pmcgovern@cinch.com> skrev i en meddelelse
    news:a154ff59.0404181235.7f3d14b9@posting.google.com...
    > -=Lazzerous=-
    Hi,
    I'm not quite sure what you mean - I have never seen this before.
    You could try the pinnacle webboard:
    http://webboard.pinnaclesys.com and go to software solutions and then Liquid
    Edition and ask there.
    /Ulf
  2. Archived from groups: rec.video.production,rec.video.desktop (More info?)
    It seems to me that what you are looking at is a FULLY zoomed-in part of the
    timeline that is showing the start and finish marks on one frame. That is
    normal at this magnification.
    Quite how the screenshot relates to your transition-duration settings I am
    not sure. Perhaps you are misreading something. I assume you know that
    when you click on the transition marker and select duration you get a second
    box below the (last default) first which you can then change to whatever
    duration you require.
    Maurice Fleisher: <videoenterprises@btconnect.com>
    www.videoenterprises-uk.co.uk
    High Wycombe. UK
    This message has been scanned for viruses"Ulf Laursen"
    <remove_it_mail@uhl-video.dk> wrote in message
    news:40835e98$0$309$edfadb0f@dread11.news.tele.dk...
    > > -=Lazzerous=-
    > Hi,
    Liquid
    > /Ulf
  3. Archived from groups: rec.video.production,rec.video.desktop (More info?)
    When I extend the duration of a transition, the gray bar turns red
    past 00:00:00,01 worth of transition time...
    "Maurice Fleisher" <maurice_vidents@btconnect.com> wrote in message news:<c60aeq$alj$1@titan.btinternet.com>...
    > High Wycombe. UK
    > > > -=Lazzerous=-
    > > Hi,
    > Liquid
    > > /Ulf
  4. Archived from groups: rec.video.production,rec.video.desktop (More info?)
    The red bar indicates that you do not have enough (in your case none at all)
    overlap in your clips to accommodate the transition effect. If you think of
    it in terms of A-B roll mode you will know that clips must overlap for at
    least the length of the transition. You should physically shorten the clips
    by however long you wish the transition to take. This will give you the
    necessary overlap.....or you could do it using the trim tool to drag the
    relevant clip ends left and right. Remember, when you razor a clip on the
    timeline you do not eliminate the cut-away bits which are now hidden but can
    be extended into view on the timeline by dragging the ends, provided you can
    see a black arrow at your curser position which is an indication that there
    IS more clip available.
    High Wycombe. UK
    "Lazzerous" <pmcgovern@cinch.com> wrote in message
    news:a154ff59.0404191208.4c684e9@posting.google.com...
    the
    is
    am
    second
    > > High Wycombe. UK
    clips
    to
    > > > > -=Lazzerous=-
    > > > Hi,
    > > Liquid
    > > > /Ulf
Tuner Cards Video Pinnacle Graphics
