Tom's Hardware > Forum > Windows XP > Video > dv capture to avi, sound problems
Forum Windows XP : Video - dv capture to avi, sound problems
Archived from groups: microsoft.public.windowsxp.video (More info?)
Hi, when I capture from my panasonic pv-gs120 dv link at video res of 720x480
using avi or mpeg2, the playback on my pc has a high pitched audio sound in
the background that is not on the original tape. This does not happen when I
capture using lower pixel res of 640x480 and below... any ideas? I've updated
DirectX driver and am using 1394 shielded firewire but still problems...
thanks...
Sponsored Links
Sounds like the squeal of the HOT of the monitor. Do you have a mic
connected, if so try with it out or muted. If no mic, disregard this. Later
on.
"rsnavarro98" <rsnavarro98@discussions.microsoft.com> wrote in message
news:9B35E95B-5151-4A5F-BA3A-684CD29DE68A@microsoft.com...
720x480
in
when I
updated
> thanks...
Reply to Anonymous
Hi Nick...no mic is connected, its not feedback sound, its a very high pitch
sound, like maybe the audio codec can't keep up with the xfer speed maybe
(?)... I'm just guessing, but as I said the high pitch sound only happens
when xferring from dv camcorder to pc at avi or mpeg2 mode... thanks tho...
> on.
Reply to Anonymous
There are two likely sources, the Firewire connection or the audio card. If
you are confident that your Firewire connection is functioning correctly,
look at the audio. If you are using the onboard audio, that might be the
more likely issue. Get the latest chipset drivers for your audio. Is this
machine slower than 1.6GHz (1.0 if AMD)? That could potentially contribute
if the audio system is sub-par. A remedy might be adding a PCI audio card
such as a Creative Labs Audigy, but check the audio drivers first!
The latest DirectX is 9.0c, which is built into SP2. DXDIAG will list the
version. I highly recommend 9.0c, which you may have ("updated DirectX" ) as
you indicated, because it also includes the latest DX security patches.
720x480
in
when I
updated
> thanks...
Reply to Anonymous
Hi George.. thanks for the suggestions... yes I did upgrade to DirectX 9.0c
via Windows website.. I have an HP 450n which says its a 3gig.. I'm not so
sure its an audio onboard problem; I'm thinking maybe its a audio codec
problem maybe? because if I upload the dv video to pc via avi, than burn it
directly to dvd and play it on my tv, I get the same high pitch background
noise as I hear on the pc... also, I tried 2 different firewire cables, and
still get same high pitch noise when downloading via avi or mpeg2 format,
which is the highest video resolution for capture, but no high pitch noise
when downloading via regular mpeg or lower video res...
Reply to Anonymous
Yes, this really sounds like a audio driver issue or a potential codec
issue. Especially if varies based on format via firewire. The audio is
usually processed through audio chipset. There are certain conditions like
this where the audio will also get out of sync with the video while using
firewire.
Go to the HP site and go to the support page. You can enter your model
number and get the downloads list for you computer. Download the latest
audio driver and see if it corrects your problem.
news:6955774E-BF55-4A4A-BA8A-976594AC6482@microsoft.com...
9.0c
it
and
If
correctly,
the
this
contribute
card
the
DirectX" ) as
Reply to Anonymous
That was a great suggestion George, I looked at my audio driver and it needed
an update; unfortunately, it didn't fix the high pitch sound... I guess dv
download of 178 meg/sec is too fast for my audio codec to process maybe(?)...
but then again I wouldn't think so, I just bought this HP computer brand new
4 months ago, so I was expecting the latest and greatest hardware in it...
it's a 3 gig processor with 160 gig hardrive and 512 meg ram
I just looked at my pc's Device Manager... and the audio codec manufacturer
says its a standard system device... so maybe I need to upgrade my audio
codec maybe(?)... sorry, I'm not a desktop/pc guy, I'm a network guy at
work.... so I'm not sure if that may be the problem..
also on my audio codec properties window on the properties tab, the first
codec it uses is: IMA ADPCM Audio CODEC
...there's about 10 other listed audio codecs under that one, maybe I should
push one of the other codecs to the top maybe (?)... any other suggestions
would be welcome... thanks for replying George.
> firewire.
Reply to Anonymous
Then it may be the Firewire or the audio chipset itself. What card do you
have? Your system is fast enough to even capture an analog stream and
convert it to DV with software.
news:BABBD0CB-E87A-4A35-B563-241F845B7D54@microsoft.com...
needed
maybe(?)...
new
manufacturer
should
like
using
> > firewire.
Reply to Anonymous
There are 927 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
