Need help
Last response: in Windows 7
I will assume you want to recover your network security key. What type of internet connection do you have? If you have Wi-Fi just follow these steps to recover your network security key.
1. On your Home PC, that connects to your Wi-Fi Network, click on the Wi-Fi Network Icon on the taskbar.
2. Right-click on your wireless network connection and click “Properties”.
3. In the Wireless Network Properties, click on “Security” tab. You can see the Network Security Key that you entered during setup of Wi-Fi Network. But by default, it will not be in readable format.
4. To make the password readable, check the box “Show Characters” and voila your Network Key is readable!
I hope this helps!
Brett M,
Windows Outreach Team
Ok, so there are 2 cases:
1) It's your router and you forgot the password. You can hard reset it and just set it up again.
2) It's not your router and you want to acceess it's wireless network. You 're a bad bad boy :p
Ask the community
