have you checked the manufacture website for the drivers? i never can find the disc for my printers so i just download the driver from their site, same files that are on the disc.
if your printer is wireless you can just connect the wifi network from the printer by setting it up how you normally would, or just connect it directly to the network, either way it should work just fine as long as the printer is not out of date and not supported by win8
