Tom's Hardware > Forum > Windows XP > Video > movie maker problem
movie maker problem
Forum Windows XP : Video - movie maker problem
Archived from groups: microsoft.public.windowsxp.video (More info?)
When I received a movie and imported it into movie maker, I only got the
opening credits, and then every clip showed just an "X" on the storyboard,
and a blank, black picture on the preview screen....same when I e mailed a
different movie to someone
Sponsored Links
that means the clips had been deleted somehow
Reply to Anonymous
Are you sending and receiving actual video or a project file from windows
movie maker 2? look at the file extension is it a .wmv or .mpeg or is it a
..mswmm ?
Reply to Tom
It means your source files haven't been copied with the movie. MovieMaker
(and PowerPoint) only uses shortcuts to your original source images and
music, so if you're using pictures from a network or website you need to copy
them across onto your hard drive. Not sure why if you saved and burned your
movie in Windows MovieMaker it didn't work - when I tried, it copied a neat
little package of source files and exe file so it would run elsewhere.
All I know is it's a real pain 'cos you have to save multiple copies of
images all over the place if you use more then one computer!!! I have to burn
stuff on my PC 'cos my laptop's not got a writer, but use all my shows from
my laptop!
Reply to Anonymous
There are 1246 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
