Archived from groups: rec.video.desktop (More info?)
I have a video that I am currently editing in NTSC but I will be needing to
make a PAL version too. Before going to work to make a PAL copy of my video,
I was just wondering what would happen if I played an NSTC video on a PAL
system, as in, doing no conversion at all. What would happen to the video,
or would it even play at all?
If I DO end up having to convert it, what is the easiest method? I've
checked out videohelp.com and found a process that seems a lot harder than
it should be. Are there certain required steps? I know about the framerate
and screen size. Would it work to just crop my video and adjust the
framerate to 25fps? Anything else I need to worry about? And I would be
able to use normal TDK VHS tapes too, right?
Thanks.
//cory
Thanks.
//cory
