Archived from groups: rec.video.desktop (
More info?)
pak.ecker@comcast.net wrote in
news:40992426.74437248@news.nj.comcast.giganews.com:
> On Wed, 05 May 2004 01:55:09 GMT, "Rich" <rich__23@earthlink.net>
> wrote:
> there is a plug on my camera that says dv, is that for firewire??
Yes, the DV plug on your camcorder is FireWire/iLink/IEEE-1394
(three names for the same thing).
> Not sure my computer has a firewire plug, is there any way to rig
> a firewire to usb?
If your notebook lacks FireWire, you can buy a PCCard (PCMCIA)
adapter. Read the computer manual or look at the connectors on the
notebook. The FireWire logo is sort of like a weird letter Y. It's a
circle with some waves emanating from it in three directions, so
that it loks like a Y, if you're not wearing your bifocals
. The
USB logo looks a little like the Greek letter psi.
Or go to Google and search, or go to a store and look at equipment.
Be sure to note the appearance of both sizes of connectors.
> Or can I use the windows xp movie maker with usb connection?
You need FireWire.
Whewn you go to buy a cable, note that FireWire can have 6-pin or 4-
pin connectors. The camera almost certanly has a 4-pin plug and the
adapter on the computer might have either.
So you'll likely want to buy a cable with a 4-pin on one end and a
6-pin on the other, or else with two 4-pin ends.
>><pak.ecker@comcast.net> wrote in message
>>news:40983173.12296726@news.nj.comcast.giganews.com...
>>> have a notebook running windows xp. have had no luck getting the
>>> "Image Mixer " software that came with it to work, either with
>>> the windows xp computer or with another computer running Windows
>>> 2000.
>>> My desire is to transfer the digital video that I have shot with
>>> the TRV 19 to computer and then be able to edit it.
>>> What programs, drivers do I need to do this ( transfer, then
>>> edit- would prefer shareware/freeware if possible)
>>> Any TRV 19 users that have already worked their way through
>>> these problems that can help me.
>>> Thanks in advance.
>>> Paul
>>I'm using a Sony, but not the same model. If you have XP then it
>>should have Microsoft Movie Maker 1 or 2 already installed, if not
>>it's free. You need a Firewire port on your XP computer. You
>>need a Firewire cable (IEEE 1394) with the proper number of pins
>>on each end, which probably did not come with your camera. Movie
>>Maker will capture from the Sony and save in AVI format. You can
>>edit, etc and save in AVI format or WMV. In any event that was
>>the fastest, most painless and cheapest way for me to start.
>>Rich
Gene E. Bloch (Gino) phone 650.966.8481
Call me letters find me at domain blochg whose dot is com
